Speed ?
peterpm
Post Tue Jan 01, 2013 3:21 pm
Speed ?
For test purposes on same FreeBSD box(using jails) I installed
- Serviio 1.0.1
- Serviio 1.1
-MiniDLNA
-MediaTomb
And on anotehr Windows Box
- UniversalmediaServer
- PS Media Server
After I switch on TV MiniDLNA show up first, Servio 1.0 a few seconds after it and in about 2 min maybe Serviio 1.1. Then the rest.
I do not care about the rest as I want to use Serviio, but do you know why Serviio 1.1 show so much after Serviio 1.0.1 on my Samsung UES6300 ?
Thanks,
Peter
Post Tue Jan 01, 2013 9:22 pm
Re: Speed ?
The enderer, when turned on, sends a DISCOVERY SSDP message, with MX header including value of max. seconds to respond. Serviio will respond in random number of seconds given by interval <0, MX>. So this might be different every time you turn on the TV.
peterpm
Post Wed Jan 02, 2013 6:50 am
Re: Speed ?
The problem is that 1.0 always wins(is notably faster) :-)
Is there any setting I can change ?
Thanks,
Peter
Post Wed Jan 02, 2013 1:35 pm
Re: Speed ?
enable detailed log and compare what both versions do at the time (and some seconds later) of starting the TV.
peterpm
Post Wed Jan 09, 2013 5:39 am
Re: Speed ?
FYI: The problems comes from FreeBSd jails & multicast. It is a FreeBSD issue. However the strange thing is that Serviio 1.0.1 works like charm for me, so I stick to it for now :-)
