No Sound on Sony KDL-40ex723 online streams
blokey
Post Sun Dec 23, 2012 8:19 pm
Re: No Sound on Sony KDL-40ex723 online streams
I also tested the supported formats with device info and it looks identical to the one posted.
newborn
Post Sun Dec 23, 2012 8:20 pm
blokey wrote:I'm here to help too. From what I remember it is an FLV with mp3 mono audio. I have been testing lots of streams and video files. Also found I had some issues with avi files (xvid with mp4a audio), using the sony2011us fixed that issue. More than happy to test anything you want.
Basically I think they'll want the debug for every single instance you've listed, they provide the hard facts so to speak ;)
blokey
Post Sun Dec 23, 2012 8:29 pm
I can do, that is actaully how I tracked down the issue in the first place with Skysportsplus, that and the fact it worked with the BDP profile but not the sony2011 one. I wasn't really asking anyone to fix it for me, I had found the solution, just wanted to share the love! :) As I said though, if you want me to test anything else, i'll quite happily do that.
NX3
Post Sun Dec 23, 2012 9:19 pm
Illico, version 1.1 fixed online audio for aac for example HD Trailers as covered in this thread:
viewtopic.php?f=11&t=6858&start=20
The issue raised in this thread is a new / different. AV Media Controller in resouces using Sony Bravia 2011 profile reports this:
http://192.168.1.101:8895/resource/1000000080001899/MEDIA_ITEM/AVC_TS_MP_SD_MPEG1_L3_ISO-0/ORIGINAL
70000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000
640x360
Post Mon Dec 24, 2012 8:39 am
NX3 wrote:Illico, version 1.1 fixed online audio for aac for example HD Trailers as covered in this thread:
70000
640x360
Yes, issue raised in beta test was also include in 1.1 version by mime-type renaming.AVC_TS_MP_SD_MPEG1_L3_ISO -> AVC_TS_HD_24_AC3_ISO
But the previous "newborn" ffmpeg -i result raised a flv/h264/mp3 stream, but with a mono mp3 audio track (Don't know if sony device support this).
Then serviio with Sony profile remuxed this into mpegts/h264/mp3 stream, I suppose that serviio will identify this as AVC_TS_MP_SD_MPEG1_L3 mime-type.
Then Sony profile rename the mime-type as one supported by device : AVC_TS_HD_24_AC3.
So one test you can do "newborn" is to install Intel tool (AV Media Controller), a new device will appear in serviio console (with IP address where Intel tool is installed), you can change the profile from "Generic" to "Sony Bravia".
Then browse with AV Media Controller the online stream with problem and check the resources list provided to the device, then post here the result please.
newborn
Post Mon Dec 24, 2012 4:03 pm
Resource 1
http://192.168.1.14:8895/resource/1000000710001719/MEDIA_ITEM/AVC_TS_MP_SD_MPEG1_L3_ISO-0/ORIGINAL
76375
640x360
Resource 2
http://192.168.1.14:8895/resource/1000000710001719/MEDIA_ITEM/AVC_TS_MP_SD_MPEG1_L3_ISO-1/ORIGINAL
76375
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_50_AC3_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000
640x360
Resource 3
http://192.168.1.14:8895/resource/1000000710001719/MEDIA_ITEM/AVC_TS_MP_SD_MPEG1_L3_ISO-2/ORIGINAL
76375
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_60_AC3_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000
640x360
Resource 4
http://192.168.1.14:8895/resource/1000000710001719/MEDIA_ITEM/AVC_TS_MP_SD_MPEG1_L3_ISO-3/ORIGINAL
76375
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_EU_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000
640x360
Resource 5
http://192.168.1.14:8895/resource/1000000710001719/COVER_IMAGE
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000
Confirmed picture and no sound coming from TV on the above.
blokey
Post Wed Dec 26, 2012 7:03 pm
Just to confirm, i have been testing out various files/streams that I have available. I found that with my fix most files play fine except for some you tube links (no sound) and some local mp4 files (playback not available). I have found that adding my fix, the fix that illico suggested and selecting the 2011US profile i can play all the files I currently have available. Would it be an idea to create small simple video files of all different types to test against the profiles? I know this wouldn't help with the online streams but it would allow us to test the major ones.
newborn
Post Sat Dec 29, 2012 11:44 am
bump as I finally updated my post above. Happy Holidays..
newborn
Post Sat Dec 29, 2012 1:53 pm
Illico I just tried your fix again, and I got the service to load this time, it made no difference though to the audio. I then added(in addition to your's) blokey's fix to the section:
<OnlineTranscoding>
<Video targetContainer="mpegts" forceInheritance="true"> <!-- do not transcode to ac3 -->
<Matches container="mp4" />
<Matches container="flv" vCodec="h264"
contentType="vod" />
<Matches container="applehttp" vCodec="h264" />
<Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384" DAR="16:9" forceInheritance="true">
<Matches container="asf" /> <!-- to support mms:// streams -->
<Matches container="flv" />
</OnlineTranscoding>
Within the Sony2012 profile.
Just to go into a bit of background that I'm not sure if Blokey went into the detail of, his fix appears to be lifted from the Sony BD Player profile.
<OnlineTranscoding>
<Video targetContainer="mpegts"> <!-- dont transcode to ac3 -->
<Matches container="flv" vCodec="h264" contentType="vod" /> <!-- exclude live flv streams which crash the renderer -->
<Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384">
EDIT: Oh sorry... forgot to add, doing the above indeed sorts the sound out!
newborn
Post Sat Dec 29, 2012 2:03 pm
blokey wrote:Also had some issues with screen being squeltched vertically. Changing the following in sony2012 fixed this
to
<Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384" forceInheritance="true">
and that works too! Thought i'd share it.
I only just noticed this on the coolsports plugin which I got working today, but you're right in the instance of that plugin its very squelched. I've not tried this particular fix of yours yet but I imagine it will sort that out.. thanks.
Edit: sounds like a similar fix on http://forum.serviio.org/viewtopic.php?f=11&t=8529 thread this fellow has just raised. I didn't know of this Sony Homestream until he mentioned it, interesting.
Post Wed Jan 02, 2013 10:48 am
Zip, what is the difference between contentType=vod, live and any?
Previous
