Remote access Synology Ds213
duronde
Post Tue Jan 01, 2013 9:22 pm
I have installed serviio-server on Synology DS213. The Console on an Windows XP. It works.
I put the shared Folders with "\\192.x.x.x\video". When i want to save, the share Folders change to "/volume1/homes/serviio/\\192.x.x.x\videos"
How can ich change it?
Thank you for help
duronde
patters
Post Wed Jan 02, 2013 5:13 pm
Re: Remote access Synology Ds213
You're adding your shared folders in Windows notation, but your Serviio server is Linux remember. So you need to express that share as /volume1/videos
duronde
Post Wed Jan 02, 2013 9:04 pm
Thank you patters,
but the notation is not the problem.
The shared folder is "192.x.x.x/videos/"
If I save the folder, the folder changes to "/volume1/homes/serviio/192.x.x.x/videos".
The videos are in the folder "192.x.x.x./videos" and not in the folder "/volume1/homes/serviio/192.x.x.x/videos".
Have you an idea, how i could save der right folder? Is it possible to change the folder directly, without remote access?
Thank you for Help.
Duronde
patters
Post Fri Jan 04, 2013 1:24 am
duronde wrote:The shared folder is "192.x.x.x/videos/"
A Linux folder path must contain a / at the beginning. Your storage volume on the NAS is /volume1. So to me it looks like your folder notation is the problem.
If you're asking about using Serviio on the NAS to serve content that's actually on a different computer then I doubt that's even possible without mounting the share in Linux first.
duronde
Post Sat Jan 05, 2013 3:21 pm
Yes it is right aboute the "/" at the beginning of a share in linux systems.
I don´t no why the folders changes from "/192.x.x.x./videos" to "/volume1/homes/serviio/192.x.x.x/videos",
but i have solved the problem at follows.
I put a softlink in the DNAS-folder "/volume1/homes/serviio/" with a link to the "video" folder on the NAS.
Now i can do in the serviio console the folder "videos", when i save it, the folder change to "/volume1/homes/serviio/videos".
At least the serviioserver find the videofiles.
Thank you for all help which i found in this forum.
Duronde
chesh
Post Tue Jan 08, 2013 4:57 pm
I have also installed on DS213, followed the instructions verbatim from the serviio site http://pcloadletter.co.uk/2012/01/25/se ... o-package/. Installed consol only on XP machine. Success all the way to trying to add my libraries. No matter what path I try, it does not seem that any files are found. Both lights are red. The path I am using is /volume1/video and /volume1/music. In I have given Serviio User r/w access to both shared folders. Any thoughts on what I might be missing?
chesh
Post Wed Jan 09, 2013 2:12 pm
duronde wrote:Yes it is right aboute the "/" at the beginning of a share in linux systems.
Duronde
How do you create this "softlink"? I am hoping this might solve my problem as well.
