Strange HDD access
Mroziu
Post Wed Jan 02, 2013 11:03 pm
Strange HDD access
Hi
I was trying to solve constant HDD led blinking issue and stared ProcessMonitor session profiling for file system access.
I was surprised that Serviio is trying to access file system every 5 seconds! Log is below:
23:45:56,5499918 ServiioService.exe 2340 CreateFile C:\Program Files\Serviio\config\META-INF\services\javax.xml.parsers.DocumentBuilderFactory PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
23:45:56,5500858 ServiioService.exe 2340 CreateFile C:\Program Files\Serviio\bin\META-INF\services\javax.xml.parsers.DocumentBuilderFactory PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
23:45:56,5502511 ServiioService.exe 2340 CreateFile C:\Program Files\Serviio\config\java\lang\META-INF\services\javax.xml.parsers.DocumentBuilderFactory PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
23:45:56,5503388 ServiioService.exe 2340 CreateFile C:\Program Files\Serviio\bin\java\lang\META-INF\services\javax.xml.parsers.DocumentBuilderFactory PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
23:45:56,5511601 ServiioService.exe 2340 CreateFile C:\Program Files\Serviio\config\META-INF\services\javax.xml.datatype.DatatypeFactory PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
23:45:56,5512477 ServiioService.exe 2340 CreateFile C:\Program Files\Serviio\bin\META-INF\services\javax.xml.datatype.DatatypeFactory PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
23:45:56,5514091 ServiioService.exe 2340 CreateFile C:\Program Files\Serviio\config\java\lang\META-INF\services\javax.xml.datatype.DatatypeFactory PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
23:45:56,5514935 ServiioService.exe 2340 CreateFile C:\Program Files\Serviio\bin\java\lang\META-INF\services\javax.xml.datatype.DatatypeFactory PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
23:45:56,5525683 ServiioConsole.exe 2476 CreateFile C:\Program Files\Serviio\config\META-INF\services\javax.xml.parsers.DocumentBuilderFactory PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
23:45:56,5526635 ServiioConsole.exe 2476 CreateFile C:\Program Files\Serviio\bin\META-INF\services\javax.xml.parsers.DocumentBuilderFactory PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
23:45:56,5528358 ServiioConsole.exe 2476 CreateFile C:\Program Files\Serviio\config\java\lang\META-INF\services\javax.xml.parsers.DocumentBuilderFactory PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
23:45:56,5529285 ServiioConsole.exe 2476 CreateFile C:\Program Files\Serviio\bin\java\lang\META-INF\services\javax.xml.parsers.DocumentBuilderFactory PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
23:45:56,5535194 ServiioConsole.exe 2476 CreateFile C:\Program Files\Serviio\config\META-INF\services\javax.xml.datatype.DatatypeFactory PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
23:45:56,5536134 ServiioConsole.exe 2476 CreateFile C:\Program Files\Serviio\bin\META-INF\services\javax.xml.datatype.DatatypeFactory PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
23:45:56,5537778 ServiioConsole.exe 2476 CreateFile C:\Program Files\Serviio\config\java\lang\META-INF\services\javax.xml.datatype.DatatypeFactory PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
23:45:56,5538673 ServiioConsole.exe 2476 CreateFile C:\Program Files\Serviio\bin\java\lang\META-INF\services\javax.xml.datatype.DatatypeFactory PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
It would be nice if that could be solved :)
Except this i have to say that Serviio is awesome job ;)
Post Thu Jan 03, 2013 12:08 am
Re: Strange HDD access
It looks like it might be a folder permission problem.
Post Thu Jan 03, 2013 1:23 pm
this looks like some low level Java checks, which I have no control over
Mroziu
Post Thu Jan 03, 2013 10:48 pm
My guess is that some objects are serialized to/from XML that have no custom wrapper class and that why java is searching serialization details in file system. That is what is sometimes done in other languages/libraries.
Specifying a custom serialization wrapper class could solve the problem, but that is just a lucky guess (since I never wrote single line in java ;))
