Detect if media is streamiing
vlowe
Post Thu Jan 03, 2013 3:17 pm
I am wondering if it possible to check if serviio is streaming/playing media or if it is idle?
I am running on ubuntu and have a bash script which is scheduled to run every minute, it contains an rsync which occasionally transfers large files and IF streaming can cause the playback to suffer and jump.
I want to check if serviio is streaming something and if it is, don't run the rsync.
Thanks,
Vince
Post Thu Jan 03, 2013 4:54 pm
Re: Detect if media is streamiing
Not possible ATM
vlowe
Post Fri Jan 04, 2013 1:11 pm
no worries, modified the script to check eth0 tx speed in kb/s, and only run sync if under 50kb/s
r-win
Post Fri Jan 04, 2013 5:27 pm
I think using lsof -p <Serviio pid> would be a better way. If Serviio is streaming a file, it'll show up with lsof.
Something like:
lsof $(ppid serviio)
should give you the info you need when running bash. Note: when he library is updated, files may show up here as well.
Linksys WRT320N | Samsung PS-50C7700 | Microsoft XBOX 360 | Windows 8.1 | Linux Ubuntu 13.04
vlowe
Post Fri Jan 04, 2013 5:43 pm
cheers.
would also be nice to be able to call a script once serviio starts to stream. So can stop rsync and some less important procceses to ensure an uninterrupted playback.
r-win
Post Fri Jan 04, 2013 5:45 pm
I agree, with some arguments, so I can log the view on trakt.tv ;-)
Users browsing this forum: No registered users and 60 guests
