PS3 - Targeting Constrained Baseline Profile
firefox15
Post Sun Dec 30, 2012 8:22 pm
Hello Everyone,
I have a file that will not play on the PS3, either from Serviio or from a USB stick. While it plays in my Sony Blu-Ray player without an issue from both Serviio and a USB stick, the PS3 has a problem with it. Since it didn't play from a USB stick, I forced it to transcode in the PS3 profile by adding the following, and then it worked fine:
<Matches container="*" vCodec="h264" levelGreaterThan="4.1" />
However, this obviously has the side effect of transcoding all h264 video that is higher than level 4.1, not just those with the "high" and "main" profiles as originally specified in the profile. The video is question uses the Constrained Baseline Profile, so I tried to target it with the following code, but it appears that "baseline" only matches the actual Baseline Profile, not the CBP.
<Matches container="*" vCodec="h264" profile="baseline" levelGreaterThan="4.1" />
Obviously, this doesn't transcode the video since it isn't the actual Baseline Profile, and I get an error message that "The Data is Corrupted" when I try to play it. Short of using vFourCC to isolate it a little more, I'm not sure of the best transcoding configuration in this case. As of now, I'm just using the first statement to transcode all profiles, but I would prefer if I could isolate it a little more. I appreciate any guidance you can provide.
C:\Users\xxxxxxx>"C:\Program Files\Serviio\lib\ffmpeg.exe" -i "D:\ServerFolder
s\TV Shows\Fullmetal Alchemist - Brotherhood\Fullmetal Alchemist Brotherhood - 2
7 - Interlude Party.mp4"
g-config
[mov,mp4,m4a,3gp,3g2,mj2 @ 0187BD80] max_analyze_duration 5000000 reached at 500
5005
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'D:\ServerFolders\TV Shows\Fullmetal Alc
hemist - Brotherhood\Fullmetal Alchemist Brotherhood - 27 - Interlude Party.mp4'
    major_brand     : M4V
    minor_version   : 0
    compatible_brands: M4V mp42isom
    title           : Interlude Party
    artist          : Fullmetal Alchemist: Brotherhood
    album_artist    : Fullmetal Alchemist: Brotherhood
    album           : Fullmetal Alchemist: Brotherhood, Season 2, Pt. 1
    genre           : Animation
    track           : 1
    disc            : 1/1
    gapless_playback: 0
    date            : 2010-12-28T08:00:00Z
    copyright       : ┬⌐ Hiromu Arakawa/FA Project, MBS.  Licensed by FUNimation
® Productions, Ltd. All Rights Reserved.
    description     : Visions of the past play out by a warming fire as Hohenhei
m reflects on the unavoidable follies of man: the pain that comes with a loving
family; the hidden truths of alchemy; and the roots and results of war.
    show            : Fullmetal Alchemist: Brotherhood
    episode_id      : 27
    season_number   : 2
    episode_sort    : 1
    media_type      : 10
    synopsis        : Visions of the past play out by a warming fire as Hohenhei
    comment         : Uploader: nextday
  Duration: 00:24:38.31, start: 0.000000, bitrate: 1533 kb/s
    Stream #0:0(eng): Audio: aac (mp4a / 0x6134706D), 44100 Hz, stereo, s16, 125
 kb/s
      handler_name    : Apple Sound Media Handler
    Stream #0:1(eng): Video: h264 (Constrained Baseline) (avc1 / 0x31637661), yu
v420p, 640x480 [SAR 4:3 DAR 16:9], 1402 kb/s, 23.98 fps, 23.98 tbr, 2997 tbn, 59
94 tbc
      handler_name    : Apple Video Media Handler
    Stream #0:2: Video: mjpeg, yuvj444p, 600x600 [SAR 72:72 DAR 1:1], 90k tbr, 9
0k tbn, 90k tbc
Post Mon Dec 31, 2012 5:08 pm
Re: PS3 - Targeting Constrained Baseline Profile
Hi, it's not possible to match on constrained baseline in 1.1, just added it for future 1.2
firefox15
Post Mon Dec 31, 2012 6:02 pm
Great, thank you. I'll just transcode all H.264 videos with a level above 4.1 in the meantime then.
Post Tue Jan 01, 2013 2:34 pm
It should actually match the baseline profile now. Does the video really have level > 4.1?
firefox15
Post Tue Jan 01, 2013 2:44 pm
Honestly, I'm not sure. I'm only assuming it does since adding the following forces it to transcode. What is the best way of finding that information? Could it still be 4.1 or below with this statement?
Post Tue Jan 01, 2013 8:40 pm
look at MediaInfo output for the file, it'll tell you the profile.
firefox15
Post Tue Jan 01, 2013 9:07 pm
Baseline@L3.0. Assuming that is version 3.0, I'm not sure why adding the code to the profile causes it to encode since it should only be targeting levels above 4.1.
Post Wed Jan 02, 2013 3:12 pm
According to you it doesn't transcode, which seems right.
firefox15 wrote:However, this obviously has the side effect of transcoding all h264 video that is higher than level 4.1, not just those with the "high" and "main" profiles as originally specified in the profile. The video is question uses the Constrained Baseline Profile, so I tried to target it with the following code, but it appears that "baseline" only matches the actual Baseline Profile, not the CBP.
So your baseline level 3 video will not be matched by this line (it only matches files with level 4.2 and above). To transcode all baseline files try:
<Matches container="*" vCodec="h264" profile="baseline" />
firefox15
Post Thu Jan 03, 2013 12:26 am
No dice, but thanks for the suggestion. Same message that the data is corrupt. While you are correct that "<Matches container="*" vCodec="h264" profile="baseline" levelGreaterThan="4.1" />" doesn't transcode it, I also mentioned that "<Matches container="*" vCodec="h264" levelGreaterThan="4.1" />" causes it to transcode. As such, I have to believe that either 1) I'm not reading the level correctly from MediaInfo or 2) the level detection isn't working properly in Serviio. Either way, it doesn't appear to be matching on the CBP since "<Matches container="*" vCodec="h264" profile="baseline" levelGreaterThan="4.1" />" doesn't cause it to transcode, but removing the profile on the line transcodes it.
Post Thu Jan 03, 2013 1:28 pm
Yes, levelGreaterThan is only used when profile is specified (http://www.serviio.org/index.php?option ... icle&id=24).
BUt you are saying that even if it transcodes it still doesn't play? Can you see some FFmpeg errors in the log?
firefox15
Post Thu Jan 03, 2013 1:36 pm
Oh, I see. I didn't realize that levelGreaterThan is ignored if a profile isn't specified. That would explain quite a bit then. As such, we can conclude that the following will transcode the file:
<Matches container="*" vCodec="h264" />
However, the following will not transcode:
Perhaps I'm not being clear, and for that I apologize. Any time the file is transcoded, it plays fine. The problem comes when the file is not transcoded, and that only happens when the matching is incorrect. It appears that this file's CBP isn't being matched to the baseline profile. I'll try to restart the Serviio service and try it again, but I know it didn't work last night when I tried it.
Post Thu Jan 03, 2013 5:27 pm
firefox15 wrote:However, the following will not transcode:
It should. It should match any container with h264 baseline videos. Constrained baseline == baseline in 1.1. Make sure there is nothing before this rule that would be picked first.
firefox15
Post Fri Jan 04, 2013 4:43 am
Just tried it again, and no dice. It transcodes fine with the following (although you mentioned level is ignored without a profile):
The following does not transcode:
I do not see anything that this video file would be matching on earlier in the transcoding profile, but maybe I'm just missing it. If it helps, this is the entire PS3 section from my profile list:
   <Profile id="4" name="Playstation 3" extendsProfileId="1">
    <!-- http://manuals.playstation.net/document/en/ps3/current/video/filetypes.html
       The following types of files can be played under  (Video).
       Memory Stick Video Format
        - MPEG-4 SP (AAC LC)
        - H.264/MPEG-4 AVC High Profile (AAC LC)
        - MPEG-2 TS(H.264/MPEG-4 AVC, AAC LC)
       MP4 file format
       MPEG-1 (MPEG Audio Layer 2)
       MPEG-2 PS (MPEG2 Audio Layer 2, AAC LC, AC3(Dolby Digital), LPCM)
       MPEG-2 TS (MPEG2 Audio Layer 2, AC3(Dolby Digital), AAC LC)
       MPEG-2 TS (H.264/MPEG-4 AVC, AAC LC)
       AVI
        - Motion JPEG (Linear PCM)
        - Motion JPEG (mu-Law)
       AVCHD (.m2ts / .mts)
       DivX
       WMV
        - VC-1(WMA Standard V2) -->
      <Detection>
         <HttpHeaders>
            <X-AV-Client-Info>.*PLAYSTATION 3.*</X-AV-Client-Info>
         </HttpHeaders>
      </Detection>
      <MediaFormatProfiles>
         <MediaFormatProfile mime-type="video/x-ms-wmv">VC1_ASF_AP_L1_WMA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">VC1_ASF_AP_L2_WMA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">VC1_ASF_AP_L3_WMA</MediaFormatProfile>
         <!-- (Added by Alex) Fix for certain MP4 files which do not render correctly, probably a mime-type problem -->
         <MediaFormatProfile mime-type="video/mp4" name="">MPEG4_P2_MP4_ASP_AAC</MediaFormatProfile>
      </MediaFormatProfiles>
         <!-- Transcode all h264 video with HIGH/MAIN > Level 4.1 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
            <!-- (Added by Alex) The Baseline profile > Level 4.1 isn't supported either, so force a transcode -->
            remux MKV with any video to MPEG2TS and possibly change audio to ac3, also AVI and FLV with H264
         <Video targetContainer="mpegts" >
            <Matches container="wtv" />
            <Matches container="asf" vCodec="mpeg2video"/> <!--  dvr-ms -->
         <!-- all other unplayable files just transcode to mpeg2 -->
         <Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video" aBitrate="384">
            <Matches container="flv" />
            <Matches container="ogg" />
            <Matches container="3gp" />
            <Matches container="asf" vCodec="mpeg1video"/> <!--  dvr-ms -->
            <Matches container="asf" vCodec="vc1" aCodec="wmapro"/> <!-- only 2 channel audio is natively supported -->
            <Matches container="asf" vCodec="wmv2"/>
            <Matches container="rm" />
         <Audio targetContainer="lpcm" aSamplerate="48000">
            <Matches container="flac" />
            <Matches container="adts" />
         </Audio>
      <OnlineTranscoding>
            <Matches container="mp4"/>
             <Matches container="applehttp" vCodec="h264"/>
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3">
            <Matches container="asf"/> <!-- to support mms:// streams -->
         <!-- PS3 doesn't like mp3 with unlimited duration (eg online mp3 streams or streams transcoded into mp3 -->
            <Matches container="mp3"/>
            <Matches container="flv"/>
         </Audio>
      </OnlineTranscoding>
Post Fri Jan 04, 2013 11:20 am
Just to try:
<Matches container="mp4" vCodec="h264" profile="baseline" />
firefox15
Post Fri Jan 04, 2013 1:04 pm
Sorry, no luck.
Post Fri Jan 04, 2013 3:07 pm
Can you try to remove the file, force refresh, add it again, force refresh
all with detailed log
It should show which profile Serviio found when the file is again added
firefox15
Post Fri Jan 04, 2013 3:16 pm
Assuming I understand you correctly, should I just put the file in a specific folder and add it to the library? I have the root folder in Serviio, and if I remove it and re add it, I'm guessing it will show up thousands of videos in the log. Just want to make it easier to go through.
Post Sat Jan 05, 2013 1:32 pm
You can add it to another folder, yes.
firefox15
Post Sat Jan 05, 2013 3:02 pm
I tried to copy it to another folder and add that folder in Serviio, but I'm not seeing the log file reflecting it as such. This is all I could find. Am I doing something wrong?
2013-01-05 09:58:24,217 DEBUG [LibraryUpdatesCheckerThread] Looking for removed playlist files in repository: D:\Temp Serviio
2013-01-05 09:58:24,217 DEBUG [PlaylistDAOImpl] Reading Playlists for Repository (id = 7)
2013-01-05 09:58:24,217 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: D:\Temp Serviio
2013-01-05 09:58:24,217 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 7)
2013-01-05 09:58:24,217 DEBUG [MediaItemDAOImpl] Getting file of media item 1611
2013-01-05 09:58:24,217 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1611) and extractor EMBEDDED
2013-01-05 09:58:24,217 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1611) and extractor COVER_IMAGE_IN_FOLDER
2013-01-05 09:58:24,217 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 1)
2013-01-05 09:58:24,226 DEBUG [RepositoryDAOImpl] Marking Repository 1 as scanned with current timestamp
2013-01-05 09:58:24,227 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 2)
2013-01-05 09:58:24,228 DEBUG [RepositoryDAOImpl] Marking Repository 2 as scanned with current timestamp
2013-01-05 09:58:24,228 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 3)
2013-01-05 09:58:24,229 DEBUG [RepositoryDAOImpl] Marking Repository 3 as scanned with current timestamp
2013-01-05 09:58:24,229 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 4)
2013-01-05 09:58:24,231 DEBUG [RepositoryDAOImpl] Marking Repository 4 as scanned with current timestamp
2013-01-05 09:58:24,231 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 5)
2013-01-05 09:58:24,231 DEBUG [RepositoryDAOImpl] Marking Repository 5 as scanned with current timestamp
2013-01-05 09:58:24,232 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 6)
2013-01-05 09:58:24,232 DEBUG [RepositoryDAOImpl] Marking Repository 6 as scanned with current timestamp
2013-01-05 09:58:24,233 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 7)
2013-01-05 09:58:24,233 DEBUG [RepositoryDAOImpl] Marking Repository 7 as scanned with current timestamp
2013-01-05 09:58:26,603 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.2.8:64707
2013-01-05 09:58:26,603 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.8
2013-01-05 09:58:29,601 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.2.8:64707
2013-01-05 09:58:29,601 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.8
2013-01-05 09:58:32,601 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.2.8:64707
2013-01-05 09:58:32,602 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.8
2013-01-05 09:58:35,643 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.2.8:64707
2013-01-05 09:58:35,643 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.8
2013-01-05 09:58:38,642 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.2.8:64707
2013-01-05 09:58:38,642 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.8
2013-01-05 09:58:41,642 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.2.8:64707
2013-01-05 09:58:41,642 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.8
2013-01-05 09:58:50,033 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-01-05 09:58:50,033 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-01-05 09:59:26,608 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.2.8:64707
2013-01-05 09:59:26,608 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.8
2013-01-05 09:59:27,583 DEBUG [DiscoveryAdvertisementNotifier] Found 1 network interfaces to advertise on
2013-01-05 09:59:27,583 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth4 (Realtek PCIe GBE Family Controller) and address 192.168.2.2, timeout = 0
2013-01-05 09:59:27,583 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c5a8f887-8949-3e9f-a9ff-b88282874507
2013-01-05 09:59:29,586 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.2.8:64707
2013-01-05 09:59:29,586 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.8
2013-01-05 09:59:32,601 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.2.8:64707
2013-01-05 09:59:32,601 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.8
2013-01-05 09:59:35,633 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.2.8:64707
2013-01-05 09:59:35,633 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.8
2013-01-05 09:59:38,636 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.2.8:64707
2013-01-05 09:59:38,636 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.8
2013-01-05 09:59:41,636 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.2.8:64707
2013-01-05 09:59:41,636 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.8
2013-01-05 09:59:50,049 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-01-05 09:59:50,049 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
Post Sat Jan 05, 2013 7:52 pm
Did you check to search for video files in that folder?
