Loading when playing .mkv files
chachu19
Post Fri Jan 04, 2013 7:08 pm
Currently connecting to serviio 1.1 wirelessly through my Samsung 55ES8000 TV.
I have setup the profile for Samsun Tv c/d/e.
Whenever I play mkv files, over 4g, the movie plays but has a loading every 10-20 seconds, and then continues to play.
Is this due to my connection or possible pc issue?
PC is AMD 1055t - 6core and 8 gb of ram. 9800 gtx video card.
Here is the output from media info for one of the files:
Format : Matroska
Format version : Version 2
File size : 5.59 GiB
Duration : 1h 45mn
Overall bit rate : 7 621 Kbps
Encoded date : UTC 2012-10-12 17:04:54
Writing application : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep 2 2012 15:37:04
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 45mn
Bit rate : 5 960 Kbps
Nominal bit rate : 6 298 Kbps
Width : 1 280 pixels
Height : 534 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.364
Stream size : 4.37 GiB (78%)
Writing library : x264 core 125 r2200 999b753
Encoding settings : cabac=1 / ref=2 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=hex / subme=4 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-1 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=20 / rc=abr / mbtree=1 / bitrate=6298 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 1h 45mn
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.11 GiB (20%)
Language : English
Default : Yes
Forced : No
Any help would be greatly appreciation.
Thanks for your time.
r-win
Post Sat Jan 05, 2013 7:13 am
I think you mean 54g? Can you try a cable, to rule the wireless connection out?
Linksys WRT320N | Samsung PS-50C7700 | Microsoft XBOX 360 | Windows 8.1 | Linux Ubuntu 13.04
