PLUGIN WORKS SOMETIMES AND WONT SOMETIMES....WHAT'S UP?
gpsis
Post Sat Jan 05, 2013 5:25 pm
Hey guys I install a plugin about a week ago and it initially worked ok.
Went back a few days later and although the Online content folder was populated, I get an error that states the file is corrupt or it is the wrong format.
This is strange since I was attempting to view the same content that played a few days days prior.
I powered down the laptop and media player and restarted each, waited about 30 minutes or so and tried again and had the same issue.
Later that night I tried again and it worked fine, but a few days later the same issue is back...anyone got a clue?
Regards!
Device: Sony Media Player SMP-N100
Win7 Dual Core 2.9GHz
3GBR
Malwarebytes Anti-Spyware
BitDefender Total Security
Serviio allowed in all security software
Post Sat Jan 05, 2013 5:29 pm
Re: PLUGIN WORKS SOMETIMES AND WONT SOMETIMES....WHAT'S UP?
Either 1) Post in the thread realted to the plugin or 2) Tell us which plugin and online source you used otherwise there is nothing anyone could do to help
Also, if it is a plugin for a live stream, the stream may only broadcast at certain times.
gpsis
Post Sat Jan 05, 2013 6:42 pm
Got it...fyi not a live stream; a web resource.
Regards!
3GBR
