Songs stop playing on Samsung BDP While others play.
mikeM24
Post Sat Jan 05, 2013 6:55 pm
I have searched on this site for this answer without avail. So, I am posting this question:
(First, I love Serviio !)
Some songs (MP3 & M4a's) begin playing, (so I doubt its a codec issue) then stop, with the message
" The file you've selected is not currently supported"
But it plays a minute or so??? Whats that mean? Baffles me..
If it were to play a file, why does it go so far then quit ? :o
System:
Windows 7 Ultimate Service Pack 1 32-bit OS
Serviio (latest version)
HP dc5100 Small form factor.
4GB Ram
Wired LAN 1GB speed.
Cat 5 cabling
Direct to Ethernet switch (no hops)
Metadata is correct
Post Sat Jan 05, 2013 7:50 pm
Re: Songs stop playing on Samsung BDP While others play.
maybe corrupted files?
mikeM24
Post Sat Jan 05, 2013 8:16 pm
I will check them on the PC....
mikeM24
Post Mon Jan 07, 2013 3:35 pm
Nope, not corrupt, it works with windows 7 media player on a networked laptop...
So, Serviio serves the file correctly.
I guess its out of your hands... :)
it's Samsung's thing...
I will try the profile settings to see if it helps.
