Downscale video quality
joelcd
Post Fri Jan 04, 2013 8:38 am
I have a synology NAS on which I installed Serviio DLNA server.
The goal is to access my movies stored on the NAS for all my clients xbmc (macmini, ATV, Ipad).
My IOS devices connected beings WIFI (no possibility to use a wired network) flow is too slow to play 1080p movies without lag. I therefore wish to use the functionalities of Serviio transcoding for downscale the quality of my movies on the fly.
Could you help me to create a profile ?
Thank you !
Joe
PS : Sorry for my bad english, i'm french :D
Post Fri Jan 04, 2013 11:01 am
Re: Downscale video quality
You can set max bitrate and/or max height. But I'm not sure if the MAS enough power to do any transcoding.
joelcd
Post Fri Jan 04, 2013 1:13 pm
Thank you for your quick response! ;)
Could you give me an Example of use of two parameters?
Regarding the NAS, it is a Synology DS212J with ARM processor. A fair bit but if necessary I will replace.
Post Fri Jan 04, 2013 1:35 pm
look at some of the existing profiles in both profiles.xml and application-profiles.xml
joelcd
Post Sun Jan 06, 2013 5:29 pm
I dont understand, maxHeight does not work in the TargetTranscode but MatchTranscode. Therefore not possible to change the resolution on the fly ?!
Post Mon Jan 07, 2013 3:02 pm
peter1212
Post Mon Jan 07, 2013 7:30 pm
I am in the exact same situation.
My Old fashioned xbox running xbmc4xbox isn't able to play HD (and not so HD) movies stored on my computer, and i want to transcode them to play them smoothly, that is, downscale video quality.
I'll give it a try and tell you my progress.
Mainly, what i'm looking for is to downscale all videos (*.avi) exceeding 700p of height, and 1300 Kb/s of bitrate to another smaller values.
And transcode h264 codec files (mp4) to another format, because my old xbmc4xbox is not able to play them.
Any help will be welcome.
Best regards.
peter1212
Post Mon Jan 07, 2013 9:00 pm
Hi again!
Mi first attemp is this:
   <Profile id="pelele" name="Pelele" extendsProfileId="1" alwaysEnableTranscoding="true" >
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="mp3" forceStereo="true" aSamplerate="44100" maxVBitrate="1000" maxHeight="480">
            <Matches container="*" />
This profile transcode all videos * (for testing at the moment) to mpeg/mp3 stereo with maxheight=480 and maxVbitrate to 1000. Now my xbox play smoothly the movies, even h264, but in my next attemp I'll try it to transcode only my needed files.
Best regards.
peter1212
Post Tue Jan 08, 2013 9:58 am
zip, do you know if is there an option to transcode only the videofiles what exceeds a size (maxHeight?) or a bitrate(maxVBitrate)?
i don't find the option in "matches section" of the documentation.
Post Tue Jan 08, 2013 10:21 am
no, there is not
Users browsing this forum: Baidu [Spider] and 14 guests
