Arte.tv (France)
Post Thu Jan 12, 2012 5:49 pm
Arte.tv (France)
Source type : Online RSS/Atom feed
Source URL (ex:*) : http://videos.arte.tv/fr/do_delegate/vi ... ew,rss.xml
Media type : Video
Arte.groovy
Version 1.0
(5.04 KiB) Downloaded 2354 times
* List of video feed : http://videos.arte.tv/fr/videos/meta/in ... 23978.html
For Deutch, edit plugin and change variable:
final PREFERRED_LANG = 'de';
ayour
Post Fri Aug 03, 2012 1:40 am
Re: Arte.tv (France)
Not working. mybe need to be updated. Thanks.
ayour
Post Fri Aug 03, 2012 3:08 am
sorry, after verification, works but buffering every two minutes.
Post Fri Aug 03, 2012 6:48 pm
ayour wrote:sorry, after verification, works but buffering every two minutes.
That could be due to network traffic (Arte server or your FAI ).
ayour
Post Sat Jan 05, 2013 2:09 pm
Thanks for your work Illico.
I'm trying to change prefered video qualility to Sd (by edditing the arte.groovy). It works 2 minutes, and stopped. What I'm doing wrong.
My network speed is only 2.5 Mo, I have to use Sd quality. I'm in Canada. the plugin works but some video with HD doesn't work very well. Can you help me.
Sorry for my english.
Thank you.
Post Sat Jan 05, 2013 2:35 pm
You have to change prefered video quality in serviio console. What is the source url used?
ayour
Post Sun Jan 06, 2013 3:26 pm
I still have the same problem.
Thinks
Post Sun Jan 06, 2013 6:14 pm
Illico wrote:What is the source url used?
ayour
Post Sun Jan 06, 2013 9:08 pm
mchomicz
Post Sat Feb 08, 2014 4:06 pm
This feed: http://videos.arte.tv/fr/do_delegate/vi ... ew,rss.xml seems to result in 2 minute video previews when parsed by Serviio. Doe anybody know of any other feed which would include full length Arte videos?
Thank you,
Micaehl
bonswouar
Post Wed Feb 19, 2014 6:33 pm
This plugin can't work, all Arte videos are secured : the stream is fetching another stream every ** seconds, so you can't rip the full length video.
Illico are you sure it did work ?!
Post Thu Feb 20, 2014 5:36 pm
bonswouar wrote:Illico are you sure it did work ?!
I did not use it for a long time.
I will check if I get time. But if someone else could have a look too, no problem.
Ektar
Post Wed Aug 06, 2014 5:08 pm
Arte.tv (France)
Is this plugin no longer viable?
If it still works, please post the URL's needed.
therebel22
Post Sun Nov 02, 2014 12:28 pm
This plugin works : Here new RSS URL for ARTE :
http://www.arte.tv/sites/fr/services/flux-rss/
zbob
Post Mon Jan 19, 2015 9:30 pm
Hello
I have tried to connect to the following Arte RSS link (Arte+7)
http://www.arte.tv/papi/tvguide-flow/fe ... layer=true
But it does not work; no errors in the serviio logs
Can anybody help me to make this plugin work ?
Thanks a lot
guyome
Post Thu May 21, 2015 5:10 pm
I have exactly the same bug (no videos/no errors ether) with some other programs (tracks, journal,...) Is there some way to debug it ?
Return to Available plugins
Users browsing this forum: No registered users and 115 guests
