[SOLVED] Error in logs
francob
Post Sun Jan 06, 2013 12:47 am
Hi, Serviio this evening decided to notify loop of errors in log file:
ERROR [DiscoverySSDPMessageListener] Cannot open multicast socket,will try again
java.net.BindException: Address already in use
at java.net.PlainDatagramSocketImpl.bind0(Native Method)
at java.net.PlainDatagramSocketImpl.bind(PlainDatagramSocketImpl.java:91)
at java.net.DatagramSocket.bind(DatagramSocket.java:372)
at java.net.MulticastSocket.bind(MulticastSocket.java:162)
at java.net.MulticastSocket.<init>(MulticastSocket.java:147)
at java.net.MulticastSocket.<init>(MulticastSocket.java:112)
at org.serviio.util.MultiCastUtils.startMultiCastSocketForListening(MultiCastUtils.java:40)
at org.serviio.upnp.discovery.DiscoverySSDPMessageListener.run(DiscoverySSDPMessageListener.java:88)
at java.lang.Thread.run(Thread.java:680)
Never happened before. I didn't installed any eyeconnect or something else. I tried to force IP address (my mac ip addess) in the "State" tab under the recognized devices but no success.
Nothing changes before this error in my computer: no new apps nor services.
How can I solve it? Thanks in advance,
slyguy42o
Post Sun Jan 06, 2013 5:42 am
Re: Error in logs
have you rebooted recently? it looks like you may have a copy already running or a hung up instance maybe.
francob
Post Sun Jan 06, 2013 8:58 pm
Re: Error in logs
Thanks, needed to reboot.
I tried the Logout action, but it didn't work.
Now everything is ok.
francob
Post Sat Jan 12, 2013 9:13 pm
Re: [SOLVED] Error in logs
Argh... it happens again! And now even if I close Serviio regularly from the serviio consolle, logout and login, or reboot, the error continues to appear in the log file!
How to stop it?
Activity Monitor doesn't show any serviio service...
Thanks in advance
Post Tue Jan 15, 2013 5:26 pm
Re: Error in logs
Do you have any other UPnP server? E.G. EyeConnect?
francob
Post Thu Jan 17, 2013 8:50 pm
Re: Error in logs
Nope, but I discovered how the error appears.
If uTorrent (specifically nor tcp or udp is 1900 port) is opened before Serviio, Serviio generates the error, viceversa if Serviio is opened before uTorrent, and then open this program, the error doesn't appear at all. Seems like uTorrent uses 1900 port for other uses.
Post Thu Jan 17, 2013 10:11 pm
ok. they use it for UPnP (opening ports I guess), but they should not block it exclusively for them.
slyguy42o
Post Thu Jan 17, 2013 10:36 pm
you could downgrade utorrent to version 2.2.1 which should omit all that media server junk they bundled in the 3.x versions.
