ES8000 DTS not working?
• Page 1 of 1
Hello, I changed my tv from C8000 to ES8000, I used serviio thourh sintoampli, and all ok with DTS tracks on mkv, but now dts track are read as dolby, how can I solve? (I have put profile C/D/E profile in Serviio Console)
Serviio 1.0.1 - Qnap TS-419P (8TB) - Samsung UE55C8000XP - Network cables Cat.7 for all House (no wifi)
Re: ES8000 DTS not working?
post detailed log of playing the file
Petr
Help translate Serviio
zip wrote:post detailed log of playing the file
- Code:
ffmpeg -i ***********.mkv
ffmpeg version 0.8.10, Copyright (c) 2000-2011 the FFmpeg developers
built on Dec 5 2012 02:57:35 with gcc 4.2.1
configuration: --prefix=/opt/cross-project/arm/marvell/arm-none-linux-gnueabi/libc/marvell-f/usr --enable-cross-compile --cross-prefix=arm-none-linux-gnueabi- --disable-static --enable-shared --disable-yasm --arch=arm --target-os=linux --disable-armvfp --enable-gpl --disable-encoder=snow --disable-decoder=snow
libavutil 51. 9. 1 / 51. 9. 1
libavcodec 53. 8. 0 / 53. 8. 0
libavformat 53. 5. 0 / 53. 5. 0
libavdevice 53. 1. 1 / 53. 1. 1
libavfilter 2. 23. 0 / 2. 23. 0
libswscale 2. 0. 0 / 2. 0. 0
[matroska,webm @ 0x31410] Estimating duration from bitrate, this may be inaccurate
Input #0, matroska,webm, from **************.mkv':
title : *********************
Duration: 02:03:46.43, start: 0.000000, bitrate: 3584 kb/s
Stream #0.0(eng): Video: h264 (High), yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
title : ************************
Stream #0.1(ita): Audio: dca (DTS), 48000 Hz, 6 channels (FL|FR|FC|SL|SR), s16, 768 kb/s (default)
title : Italian DTS 5.1
Stream #0.2(ita): Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s
title : Italian AC3 5.1
Stream #0.3(eng): Audio: dca (DTS-HD MA), 48000 Hz, 6 channels (FL|FR|FC|SL|SR), s16, 1536 kb/s
title : English DTS-HD MA 7.1
Stream #0.4(eng): Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s
title : English AC3 5.1
Stream #0.5(ita): Subtitle: [0][0][0][0] / 0x0000 (default)
title : Italian Regular
Stream #0.6(eng): Subtitle: [0][0][0][0] / 0x0000
title : English Regular
With C8000 worked, but I changed serviio version too changing tv, (1.0.1 to 1.1).
I have a Qnap Ts-419+
i mean the detailed log (see my signature)
Petr
zip wrote:i mean the detailed log (see my signature)
ok I put debug in log4j and restarted, played the video, and while playing changing the audio (I see 3 audio in tv menu option) but I have dolby digital in all three, here is the log while I do this:
- Code:
2013-01-16 15:54:03,275 DEBUG [WebServer] Incoming connection from /192.168.0.17:48194
2013-01-16 15:54:03,276 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.17
2013-01-16 15:54:03,278 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.17:
2013-01-16 15:54:03,278 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.17
2013-01-16 15:54:03,300 DEBUG [ContentDirectory] Browse() called for renderer UE55ES8000 (profile 7) with parameters: objectID = V_T^INI_80^V_2203, browseFlag = BrowseMetadata, filter = *, startIndex = 0, count = 1, sortCriteria =
2013-01-16 15:54:03,300 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 15:54:03,302 DEBUG [VideoDAOImpl] Reading a Video (id = 2203)
2013-01-16 15:54:03,305 DEBUG [GenreDAOImpl] Reading a Genre (id = 42)
2013-01-16 15:54:03,306 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2203)
2013-01-16 15:54:03,309 DEBUG [MediaItemDAOImpl] Getting file of media item 2203
2013-01-16 15:54:03,311 DEBUG [VideoDAOImpl] Reading a Video (id = 2203)
2013-01-16 15:54:03,312 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2203 and profile Samsung TV / player (C/D/E-series)
2013-01-16 15:54:03,313 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2382)
2013-01-16 15:54:03,315 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2203)
2013-01-16 15:54:03,316 DEBUG [MediaItemDAOImpl] Getting file of media item 2203
2013-01-16 15:54:03,318 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-01-16 15:54:04,023 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 15:54:04,883 DEBUG [WebServer] Incoming connection from /192.168.0.17:48195
2013-01-16 15:54:04,884 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.17
2013-01-16 15:54:04,885 DEBUG [ResourceTransportRequestHandler] HEAD /resource/2203/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.0.18:8895]]
2013-01-16 15:54:04,886 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.17
2013-01-16 15:54:04,888 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.0.17, Profile=Samsung TV / player (C/D/E-series)'
2013-01-16 15:54:04,889 DEBUG [ResourceDeliveryProcessor] Request for resource 2203 and type 'MEDIA_ITEM' received
2013-01-16 15:54:04,889 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2203 (local)
2013-01-16 15:54:04,889 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2203)
2013-01-16 15:54:04,891 DEBUG [VideoDAOImpl] Reading a Video (id = 2203)
2013-01-16 15:54:04,893 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2203, format MATROSKA and profile Samsung TV / player (C/D/E-series)
2013-01-16 15:54:04,894 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2013-01-16 15:54:04,894 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-mkv,Content-Length: 32834233498,Date: Wed, 16 Jan 2013 15:54:04 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 15:54:04,907 DEBUG [WebServer] Incoming connection from /192.168.0.17:48196
2013-01-16 15:54:04,908 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.17
2013-01-16 15:54:04,909 DEBUG [ResourceTransportRequestHandler] GET /resource/2203/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,Host: 192.168.0.18:8895]]
2013-01-16 15:54:04,910 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.17
2013-01-16 15:54:04,912 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.0.17, Profile=Samsung TV / player (C/D/E-series)'
2013-01-16 15:54:04,913 DEBUG [ResourceDeliveryProcessor] Request for resource 2203 and type 'MEDIA_ITEM' received
2013-01-16 15:54:04,913 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2203 (local)
2013-01-16 15:54:04,913 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2203)
2013-01-16 15:54:04,915 DEBUG [VideoDAOImpl] Reading a Video (id = 2203)
2013-01-16 15:54:04,917 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2203, format MATROSKA and profile Samsung TV / player (C/D/E-series)
2013-01-16 15:54:04,918 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2203 (local)
2013-01-16 15:54:04,918 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2203)
2013-01-16 15:54:04,920 DEBUG [VideoDAOImpl] Reading a Video (id = 2203)
2013-01-16 15:54:04,922 DEBUG [VideoDeliveryEngine] Delivering item '2203' for client 'IPAddress=/192.168.0.17, Profile=Samsung TV / player (C/D/E-series)'
2013-01-16 15:54:04,923 DEBUG [VideoDeliveryEngine] Delivering file '*********.mkv' in native format
2013-01-16 15:54:04,923 DEBUG [MediaItemDAOImpl] Getting file of media item 2203
2013-01-16 15:54:04,926 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2203) as read
2013-01-16 15:54:04,952 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 15:54:04,952 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 32834233498
2013-01-16 15:54:04,953 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 15:54:04,953 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 32834233498,Date: Wed, 16 Jan 2013 15:54:04 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 0-32834233497/32834233498,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,MediaInfo.sec: SEC_Duration=7426000;]]
2013-01-16 15:54:05,021 DEBUG [WebServer] I/O error: Connection reset
2013-01-16 15:54:05,025 DEBUG [WebServer] Incoming connection from /192.168.0.17:48197
2013-01-16 15:54:05,026 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.17
2013-01-16 15:54:05,027 DEBUG [ResourceTransportRequestHandler] GET /resource/2203/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=32834041027-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.0.18:8895]]
2013-01-16 15:54:05,028 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.17
2013-01-16 15:54:05,030 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.0.17, Profile=Samsung TV / player (C/D/E-series)'
2013-01-16 15:54:05,030 DEBUG [ResourceDeliveryProcessor] Request for resource 2203 and type 'MEDIA_ITEM' received
2013-01-16 15:54:05,031 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2203 (local)
2013-01-16 15:54:05,031 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2203)
2013-01-16 15:54:05,032 DEBUG [VideoDAOImpl] Reading a Video (id = 2203)
2013-01-16 15:54:05,040 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2203, format MATROSKA and profile Samsung TV / player (C/D/E-series)
2013-01-16 15:54:05,041 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2203 (local)
2013-01-16 15:54:05,041 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2203)
2013-01-16 15:54:05,043 DEBUG [VideoDAOImpl] Reading a Video (id = 2203)
2013-01-16 15:54:05,047 DEBUG [VideoDeliveryEngine] Delivering item '2203' for client 'IPAddress=/192.168.0.17, Profile=Samsung TV / player (C/D/E-series)'
2013-01-16 15:54:05,048 DEBUG [VideoDeliveryEngine] Delivering file '*********.mkv' in native format
2013-01-16 15:54:05,048 DEBUG [MediaItemDAOImpl] Getting file of media item 2203
2013-01-16 15:54:05,049 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2203) as read
2013-01-16 15:54:05,074 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 15:54:05,074 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 192471
2013-01-16 15:54:05,075 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 15:54:05,076 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 192471,Date: Wed, 16 Jan 2013 15:54:05 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 32834041027-32834233497/32834233498,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 15:54:05,157 DEBUG [WebServer] Incoming connection from /192.168.0.17:48198
2013-01-16 15:54:05,158 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.17
2013-01-16 15:54:05,159 DEBUG [ResourceTransportRequestHandler] GET /resource/2203/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=6289-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.0.18:8895]]
2013-01-16 15:54:05,160 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.17
2013-01-16 15:54:05,161 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.0.17, Profile=Samsung TV / player (C/D/E-series)'
2013-01-16 15:54:05,162 DEBUG [ResourceDeliveryProcessor] Request for resource 2203 and type 'MEDIA_ITEM' received
2013-01-16 15:54:05,162 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2203 (local)
2013-01-16 15:54:05,162 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2203)
2013-01-16 15:54:05,164 DEBUG [VideoDAOImpl] Reading a Video (id = 2203)
2013-01-16 15:54:05,166 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2203, format MATROSKA and profile Samsung TV / player (C/D/E-series)
2013-01-16 15:54:05,167 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2203 (local)
2013-01-16 15:54:05,167 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2203)
2013-01-16 15:54:05,169 DEBUG [VideoDAOImpl] Reading a Video (id = 2203)
2013-01-16 15:54:05,171 DEBUG [VideoDeliveryEngine] Delivering item '2203' for client 'IPAddress=/192.168.0.17, Profile=Samsung TV / player (C/D/E-series)'
2013-01-16 15:54:05,171 DEBUG [VideoDeliveryEngine] Delivering file '*********.mkv' in native format
2013-01-16 15:54:05,172 DEBUG [MediaItemDAOImpl] Getting file of media item 2203
2013-01-16 15:54:05,173 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2203) as read
2013-01-16 15:54:05,196 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 15:54:05,196 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 32834227209
2013-01-16 15:54:05,197 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 15:54:05,197 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 32834227209,Date: Wed, 16 Jan 2013 15:54:05 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 6289-32834233497/32834233498,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 15:54:06,280 DEBUG [WebServer] Incoming connection from /192.168.0.17:57132
2013-01-16 15:54:06,284 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.17
2013-01-16 15:54:06,286 DEBUG [ResourceTransportRequestHandler] HEAD /resource/2203/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2013-01-16 15:54:06,286 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.17
2013-01-16 15:54:06,288 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.0.17, Profile=Samsung TV / player (C/D/E-series)'
2013-01-16 15:54:06,289 DEBUG [ResourceDeliveryProcessor] Request for resource 2203 and type 'MEDIA_ITEM' received
2013-01-16 15:54:06,289 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2203 (local)
2013-01-16 15:54:06,289 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2203)
2013-01-16 15:54:06,291 DEBUG [VideoDAOImpl] Reading a Video (id = 2203)
2013-01-16 15:54:06,293 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2203, format MATROSKA and profile Samsung TV / player (C/D/E-series)
2013-01-16 15:54:06,293 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2203)
2013-01-16 15:54:06,295 DEBUG [MediaItemDAOImpl] Getting file of media item 2203
2013-01-16 15:54:06,298 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2013-01-16 15:54:06,298 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-mkv,Content-Length: 32834233498,Date: Wed, 16 Jan 2013 15:54:06 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2013-01-16 15:54:56,264 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-01-16 15:54:56,265 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
It plays it natively, so any change you see would be down to the TV.
Petr
zip wrote:It plays it natively, so any change you see would be down to the TV.
I changed audio with tv, in the previous samsung (ue55c8000) all working good, now it plays only dolby andnot dts through ampli!
I am having a similar problem i have 2 Samsung tvs and when i stream a DTS movie it plays in dolby digital. the DTS option on both tvs' sound menu is there but greyed out i can only select dolby digital or PCM
my samungs are a LA32D550 and a UA46ES5600
• Page 1 of 1
