Media Browser will not stream any files
Shockley
Post Thu Dec 27, 2012 2:41 am
Re: Media Browser will not stream any files
Having a similar issue and not sure what to try next. Running Serviio V1.0 on Freenas Server .
Detailed logging shows a failure of the ffmpeg command:
2012-12-27 01:58:11,910 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /mnt/Video/Movies/1__9/2012 (2009).avi
2012-12-27 01:58:11,911 DEBUG [ProcessExecutor] Starting ffmpeg -i /mnt/Video/Movies/1__9/2012 (2009).avi -y -copyts -c:v flv -b:v 1000k -r 25 -g 15 -c:a libmp3lame -b:a 32k -ar 44100 -ac 2 -map 0:0 -map 0:1 -sn -f flv /mnt/Data/Serviio/transcoding-temp-1980-flv_player-MEDIUM.stf
2012-12-27 01:58:13,043 WARN [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error.
2012-12-27 01:58:13,043 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
When I execute the command on the server, get the following. Note I had to put quotes around the file name when
freenas:/# ffmpeg -i '/mnt/Video/Movies/1__9/2012 (2009).avi' -y -copyts -c:v flv -b:v 1000k -r 25 -g 15 -c:a libmp3lame -b:a 32k -ar 44100 -ac 2 -map 0:0 -map 0:1 -sn -f flv /mnt/Data/Serviio/transcoding-temp-1980-flv_player-MEDIUM.stf
ffmpeg version 0.7.13, Copyright (c) 2000-2011 the FFmpeg developers
built on Jul 31 2012 10:03:10 with gcc 4.2.1 20070719 [FreeBSD]
configuration: --prefix=/usr/local --mandir=/usr/local/man --enable-shared --enable-gpl --enable-postproc --enable-avfilter --enable-pthreads --enable-memalign-hack --enable-runtime-cpudetect --cc=cc --extra-cflags='-I/usr/local/include/vorbis -I/usr/local/include' --extra-ldflags='-L/usr/local/lib ' --extra-libs=-pthread --disable-debug --disable-sse --disable-mmx --disable-libaacplus --disable-indev=alsa --disable-outdev=alsa --disable-libopencore-amrnb --disable-libopencore-amrwb --disable-libcelt --disable-libdirac --disable-libfaac --enable-libfreetype --enable-frei0r --disable-libgsm --disable-libmp3lame --enable-libopencv --disable-libopenjpeg --disable-librtmp --enable-libschroedinger --disable-ffplay --disable-libspeex --enable-libtheora --disable-vaapi --disable-vdpau --disable-libvo-aacenc --disable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxvid
libavutil 50. 43. 0 / 50. 43. 0
libavcodec 52.123. 0 / 52.123. 0
libavformat 52.111. 0 / 52.111. 0
libavdevice 52. 5. 0 / 52. 5. 0
libavfilter 1. 80. 0 / 1. 80. 0
libswscale 0. 14. 1 / 0. 14. 1
Input #0, avi, from '/mnt/Video/Movies/1__9/2012 (2009).avi':
Duration: 02:31:23.64, start: 0.000000, bitrate: 1293 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 640x272 [PAR 1:1 DAR 40:17], 25 tbr, 25 tbn, 25 tbc
Stream #0.1: Audio: mp3, 48000 Hz, stereo, s16, 32 kb/s
Unrecognized option 'c:v'
Any suggestions?
Post Fri Dec 28, 2012 12:25 am
did you read the thread at all? Your FFmpeg is about 2 years old, upgrade it.
Blixx
Post Tue Jan 08, 2013 4:51 pm
Dear community.
I upgraded to Serviio 1.0.1 and ran into similar problem when playing any file via mediabrowser.
Again, playing to my Samsung D works fine for all examples below, only replaying via webclient fails.
Please investigate and let me know what to tweak.
Error displayed in browser (Chrome and IE):
200, Stream not found, NetStream.Play.StreamNotFound, clip: '[Clip] 'http://111.111.111.111:23424/cds/resource/945/MEDIA_ITEM/FLV-0/MEDIUM,flv_player?authToken=0a2e70e65f124f6fba6368d9e0df7e1a''
Detailed Serviio log:
2013-01-08 19:35:48,170 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /share/Movies/The Walking Dead/The Walking Dead S03E02/The.Walking.Dead.S03E02.720p.HDTV.x264-IMMERSE.mkv
2013-01-08 19:35:48,170 DEBUG [ProcessExecutor] Starting /root/.serviio/opt/bin/[b]ffmpeg -threads auto -i /share/Movies/The Walking Dead/The Walking Dead S03E02/The.Walking.Dead.S03E02.720p.HDTV.x264-IMMERSE.mkv -y -copyts -c:v flv -b:v 1000k -maxrate:v 1000k -bufsize:v 1000k -vf scale=854:480 -r 24000/1001 -g 15 -c:a libmp3lame -b:a 192k -ar 44100 -ac 2 -map 0:0 -map 0:1 -sn -f flv /tmp/Serviio/transcoding-temp-950-flv_player-MEDIUM.stf[/b]
2013-01-08 19:35:49,183 WARN  [ProcessExecutor] Process /root/.serviio/opt/bin/ffmpeg has a return code of 139! This is a possible error.
2013-01-08 19:35:49,183 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2013-01-08 19:35:49,673 DEBUG [DiscoveryAdvertisementNotifier] Found 1 network interfaces to advertise on
2013-01-08 19:35:49,674 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 111.111.111.111, timeout = 0
2013-01-08 19:35:49,677 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 858ec0d6-0fa1-36cf-a361-6ca61f5b1ab0
2013-01-08 19:35:51,653 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:00 (advertisement duration is 1800 sec.)
2013-01-08 19:35:55,813 WARN  [ServiioStatusService] IOException occured. Returning error code 500 to the REST layer. Message: FFmpeg execution failed
2013-01-08 19:35:55,814 DEBUG [ServiioStatusService] Detailed exception:
   at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:47)
   at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:133)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:95)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:120)
   at org.serviio.delivery.ResourceDeliveryProcessor.retrieveResource(ResourceDeliveryProcessor.java:217)
   at org.serviio.delivery.ResourceDeliveryProcessor.handleGETRequest(ResourceDeliveryProcessor.java:205)
   at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:88)
   at org.serviio.upnp.service.contentdirectory.rest.resources.server.CDSRetrieveMediaServerResource.deliver(CDSRetrieveMediaServerResource.java:79)
   at sun.reflect.GeneratedMethodAccessor20.invoke(Unknown Source)
   at java.lang.reflect.Method.invoke(Method.java:601)
   at org.restlet.resource.ServerResource.doHandle(ServerResource.java:449)
   at org.restlet.resource.ServerResource.get(ServerResource.java:645)
   at org.restlet.resource.ServerResource.doHandle(ServerResource.java:527)
   at org.restlet.resource.ServerResource.doNegotiatedHandle(ServerResource.java:587)
   at org.restlet.resource.ServerResource.doConditionalHandle(ServerResource.java:299)
   at org.serviio.restlet.AbstractProEditionServerResource.doConditionalHandle(AbstractProEditionServerResource.java:35)
   at org.serviio.upnp.service.contentdirectory.rest.resources.server.AbstractCDSServerResource.doConditionalHandle(AbstractCDSServerResource.java:51)
   at org.serviio.upnp.service.contentdirectory.rest.resources.server.AbstractRestrictedCDSServerResource.doConditionalHandle(AbstractRestrictedCDSServerResource.java:53)
   at org.restlet.resource.ServerResource.handle(ServerResource.java:846)
   at org.restlet.resource.Finder.handle(Finder.java:510)
   at org.restlet.routing.Filter.doHandle(Filter.java:156)
   at org.restlet.routing.Filter.handle(Filter.java:203)
   at org.restlet.routing.Router.doHandle(Router.java:497)
   at org.restlet.routing.Router.handle(Router.java:737)
   at org.restlet.engine.application.StatusFilter.doHandle(StatusFilter.java:151)
   at org.restlet.engine.ChainHelper.handle(ChainHelper.java:111)
   at org.restlet.engine.application.ApplicationHelper.handle(ApplicationHelper.java:72)
   at org.restlet.Application.handle(Application.java:391)
   at org.restlet.Component.handle(Component.java:388)
   at org.restlet.Server.handle(Server.java:488)
   at org.restlet.engine.http.connector.BaseServerHelper.handle(BaseServerHelper.java:158)
   at org.restlet.engine.http.connector.BaseServerHelper.handleInbound(BaseServerHelper.java:167)
   at org.restlet.engine.http.connector.BaseHelper.handleNextInbound(BaseHelper.java:418)
   at org.restlet.engine.http.connector.Connection.readMessages(Connection.java:696)
   at org.restlet.engine.http.connector.Controller$2.run(Controller.java:95)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
   at java.lang.Thread.run(Thread.java:722)
Output on Putty (with original call from logfiles):
[/share/MD0_DATA/.qpkg/Serviio] #
<r 44100 -ac 2 -map 0:0 -map 0:1 -sn -f flv /tmp/Serviio/transcoding-temp-950-flv_player-MEDIUM.stf
ffmpeg version 0.8.10, Copyright (c) 2000-2011 the FFmpeg developers
  built on Oct 21 2012 02:44:40 with gcc 4.2.1
  configuration: --prefix=/opt/cross-project/arm/marvell/arm-none-linux-gnueabi/libc/marvell-f/usr --enable-cross-compile --cross-prefix=arm-none-linux-gnueabi- --disable-static --enable-shared --disable-yasm --arch=arm --target-os=linux --disable-armvfp --enable-gpl --disable-encoder=snow --disable-decoder=snow
  libavutil    51.  9. 1 / 51.  9. 1
  libavformat  53.  5. 0 / 53.  5. 0
  libavdevice  53.  1. 1 / 53.  1. 1
  libavfilter   2. 23. 0 /  2. 23. 0
Expected number for threads but found: auto
Output on Putty (with some modifications on the call):
[/share/MD0_DATA/.qpkg/Serviio] # ffmpeg -threads 1 -i "/share/Movies/The Walking Dead/The Walking Dead S03E02/The.Walking.Dead.S03E02.720p.HDTV.>
[matroska,webm @ 0x31410] Estimating duration from bitrate, this may be inaccurate
Input #0, matroska,webm, from '/share/Movies/The Walking Dead/The Walking Dead S03E02/The.Walking.Dead.S03E02.720p.HDTV.x264-IMMERSE.mkv':
  Duration: 00:42:37.51, start: 0.000000, bitrate: 384 kb/s
    Stream #0.0(eng): Video: h264 (High), yuv420p, 1280x720, PAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s (default)
Again without option c:v:
<x264-IMMERSE.mkv" -y -copyts flv -b:v 1000k -maxrate:v 1000k -bufsize:v 1000k -vf scale=854:480 -r 24000/1001 -g 15 -c:a libmp3lame -b:a 192k -a>
[NULL @ 0x381b0] Unable to find a suitable output format for 'flv'
flv: Invalid argument
No matter what I tweak on the call, it doesn't seem to satisfy FFMPEG. The version I use has been compiled from up to date sources in October 2012 (see version numbers in output).
I hope some1 does know what to do. But on the other hand, web streaming is nice to have for me and even without it Serviio will be the server of choice.
Regards
Post Tue Jan 08, 2013 5:07 pm
It may have been built recently(ish), but it was build using an old version of the source.
You will need a newever version. Either from a package or by building from source.
Post Tue Jan 08, 2013 5:42 pm
Your FFmpeg version is 0.8.10, it's probably 1 year old.
Blixx
Post Tue Jan 08, 2013 8:12 pm
I'll run a new make with the sources from the download page and let you know on the results.
Blixx
Post Thu Jan 10, 2013 3:26 pm
New package, streaming still does not work. Different error messages on calling FFMPEG:
[/] # /root/.serviio/opt/bin/ffmpeg -threads 1 -i "/share/MD0_DATA/Movies/HD T>
ffmpeg version N-42368-gbf53863-Serviio_Qnap Copyright (c) 2000-2012 the FFmpeg                                           developers
  built on Dec 20 2012 20:31:36 with gcc 4.2.3
  configuration: --arch=arm --enable-armv5te --prefix=/root/.serviio/opt --extra                                          -cflags=-I/opt/include --extra-ldflags=-L/opt/lib --enable-static --disable-shar                                          ed --enable-pic --disable-ffplay --disable-ffserver --enable-pthreads --enable-l                                          ibmp3lame --enable-libshine --enable-librtmp --disable-encoder=zmbv --extra-vers                                          ion=Serviio_Qnap
Input #0, asf, from '/share/MD0_DATA/Movies/HD The Dark/23street.The_Dark.PPV-HD                                          .german.wmv':
    WMFSDKVersion   : 12.0.7600.16385
    WMFSDKNeeded    : 0.0.0.0000
    WM/EncodingTime : 3080956
    IsVBR           : 0
    MediaFoundationVersion: 2.112
  Duration: 01:28:00.00, start: 0.000000, bitrate: 6203 kb/s
    Stream #0:0: Audio: wmapro (b[1][0][0] / 0x0162), 44100 Hz, stereo, flt, -1                                           kb/s
    Stream #0:1: Video: vc1 (Advanced) (WVC1 / 0x31435657), yuv420p, 1280x720, 6                                          000 kb/s, SAR 1:1 DAR 16:9, 25 tbr, 1k tbn, 1k tbc
[graph 0 input from stream 0:1 @ 0xea2360] w:1280 h:720 pixfmt:yuv420p tb:1/1000                                           fr:25/1 sar:1/1 sws_param:flags=2
[output stream 0:0 @ 0xe98890] No opaque field provided
[Parsed_scale_0 @ 0xea2220] w:1280 h:720 fmt:yuv420p sar:1/1 -> w:854 h:480 fmt:                                          yuv420p sar:1280/1281 flags:0x4
[graph 1 input from stream 0:0 @ 0xed3eb0] tb:1/44100 samplefmt:flt samplerate:4                                          4100 chlayout:0x3
[flv @ 0xeda630] impossible bitrate constraints, this will fail
Output #0, flv, to '/share/MD0_DATA/.qpkg/Serviio/tmp/Serviio/transcoding-temp-1                                          250-flv_player-MEDIUM.stf':
    IsVBR           : 0
    encoder         : Lavf54.15.102
    Stream #0:0: Video: flv1 ([2][0][0][0] / 0x0002), yuv420p, 854x480 [SAR 1280                                          :1281 DAR 16:9], q=2-31, 1000 kb/s, 1k tbn, 25 tbc
    Stream #0:1: Audio: mp3 ([2][0][0][0] / 0x0002), 44100 Hz, stereo, flt, 32 k                                          b/s
Stream mapping:
  Stream #0:1 -> #0:0 (vc1 -> flv)
  Stream #0:0 -> #0:1 (wmapro -> libmp3lame)
frame=    3 fps=0.0 q=2.0 size=       0kB time=00:00:00.00 bitrate=   0.0kbits/s                                          frame=    6 fps=5.1 q=2.0 size=       0kB time=00:00:00.00 bitrate=   0.0kbits/s                                          frame=    9 fps=5.3 q=2.0 size=       0kB time=00:00:00.00 bitrate=   0.0kbits/s                                          frame=   12 fps=5.4 q=2.0 size=       0kB time=00:00:00.00 bitrate=   0.0kbits/s                                          Multiple frames in a packet from stream 0
Segmentation fault
A different video file leads to this:
[/] # /root/.serviio/opt/bin/ffmpeg -threads 1 -i "/share/MD0_DATA/Movies/Star Trek Deep Space 9/Star Trek DS9 Season 5/>
  configuration: --arch=arm --enable-armv5te --prefix=/root/.serviio/opt --extra-cflags=-I/opt/include --extra-ldflags=-L/opt/lib --enable-static --disable-shared --enable-pic --disable-ffplay --disable-ffserver --enable-pthreads --enable-libmp3lame --enable-libshine --enable-librtmp --disable-encoder=zmbv --extra-version=Serviio_Qnap
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/share/MD0_DATA/Movies/Star Trek Deep Space 9/Star Trek DS9 Season 5/Star Trek DS9 S05e02 the ship.mp4':
    major_brand     : isom
    minor_version   : 1
    compatible_brands: isomavc1
    creation_time   : 1940-01-12 18:26:21
  Duration: 00:45:27.43, start: 0.000000, bitrate: 292 kb/s
    Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 576x432 [SAR 1:1 DAR 4:3], 242 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc
      handler_name    : GPAC ISO Video Handler
    Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, s16, 47 kb/s
      creation_time   : 1940-01-12 18:26:24
      handler_name    : GPAC ISO Audio Handler
[graph 0 input from stream 0:0 @ 0xea2930] w:576 h:432 pixfmt:yuv420p tb:1/24000 fr:24000/1001 sar:1/1 sws_param:flags=2
[output stream 0:0 @ 0xea2980] No opaque field provided
[graph 1 input from stream 0:1 @ 0xeb7d90] tb:1/48000 samplefmt:s16 samplerate:48000 chlayout:0x3
[auto-inserted resampler 0 @ 0xe98e40] chl:stereo fmt:s16 r:48000Hz -> chl:stereo fmt:s16 r:44100Hz
[flv @ 0xeb65b0] impossible bitrate constraints, this will fail
Output #0, flv, to '/share/MD0_DATA/.qpkg/Serviio/tmp/Serviio/transcoding-temp-625-flv_player-MEDIUM.stf':
    major_brand     : isom
    minor_version   : 1
    Stream #0:0(und): Video: flv1 ([2][0][0][0] / 0x0002), yuv420p, 576x432 [SAR 1:1 DAR 4:3], q=2-31, 1000 kb/s, 1k tbn, 23.98 tbc
    Stream #0:1(und): Audio: mp3 ([2][0][0][0] / 0x0002), 44100 Hz, stereo, s16, 48 kb/s
Stream mapping:
  Stream #0:0 -> #0:0 (h264 -> flv)
  Stream #0:1 -> #0:1 (aac -> libmp3lame)
Segmentation fault0 q=2.0 size=       0kB time=00:00:00.00 bitrate=   0.0kbits/s
All in all, I haven't found a single file playing via Chrome. Maybe there are some weird video/audio codec combinations deep within my library who will work, but the vast majority does actually play really well via Samsung D.
Regards
Post Thu Jan 10, 2013 4:22 pm
Did you build FFMpeg statically or dynamically? This looks like either an old FFMpeg bug (in case it points to old shared libs) or something in your environment preventing executing the command. Try googling for 'ffmpg segmentation error on Ubuntu', you're not alone.
Previous
Users browsing this forum: Baidu [Spider], Google [Bot] and 5 guests
