BEEG - AN ADULT STREAMS VIDEO WEB RESOURCE
Post Tue Jan 08, 2013 5:00 am
Re: BEEG - AN ADULT STREAMS VIDEO WEB RESOURCE
Version 8 now posted, to fix titles and thumb extract, and add option to generate urls.
With V8 the groovy also offers a parameter genurls=1 which will cause it to generate the stream urls based on the currently known stream parameters rather than extract them with each refresh (default genurls=0). For 350 videos this reduces the url extract refresh time from 22 minutes to 1 second, however it will fail should the current stream parameters change
mqojdn
Post Tue Jan 08, 2013 7:59 am
Wouldn't it be better to have that URL generation ON by default? Thus no useless polling of Beeg servers that may lead to adding encryption and what not?
And if they would change something on the line, users would be able to disable it until you post an updated version.
gpsis
Post Tue Jan 08, 2013 2:57 pm
So what is the syntax for the genurl option? Where does it go? Sorry but we're all not programmers!
Regards!
Device: Sony Media Player SMP-N100
Win7 Dual Core 2.9GHz
3GBR
Malwarebytes Anti-Spyware
BitDefender Total Security
Serviio allowed in all security software
Post Tue Jan 08, 2013 9:21 pm
http://beeg.com/section/long-videos/1?start=1&for=50&genurls=1
First parameter always starts with ?, subsequents with &.
I will leave genurls=0 as the default because that way it will always work.
mqojdn
Post Tue Jan 08, 2013 9:58 pm
Here is a nifty idea.
The first time extractUrl is called:
- generate the link
- Add additionalInfo.put("generated", "true")
- setExpiresImmediately(true);
So when the file is actually played, Serviio would call extractUrl for a second time:
- check if getAdditionalInfo().get("generated") == true
- if so, load the page and get the link.
That way it would be fast and would always work. And no useless polling.
gpsis
Post Wed Jan 09, 2013 12:09 am
Thanks for the syntax...is this the proper use?
http://beeg.com/tag/blonde/1 &genurls=1
...or 0 as you suggest/
Regards!
3GBR
Post Wed Jan 09, 2013 12:19 am
gpsis
Post Wed Jan 09, 2013 1:51 am
OK thanks I'll keep you posted
Regards!
3GBR
Post Wed Jan 09, 2013 5:02 am
mqojdn wrote:Here is a nifty idea.
- generate the link
ABSOLUTELY BRILLIANT!!
In fact I think this might be applicable to all plugins as a solution to the problem of refreshes taking so long and defer the actual extracts to playback time.
Post Wed Jan 09, 2013 5:15 am
As suggested by mqojdn, Version 9 has been posted which eliminates the genurls option and only extracts the urls if and when when the videos played.
mqojdn
Post Wed Jan 09, 2013 9:02 am
jhb50 wrote:In fact I think this might be applicable to all plugins as a solution to the problem of refreshes taking so long and defer the actual extracts to playback time.
Beeg has the advantage that all the streams are exactly the same, and that it's not that important if those are 9 or 12 minutes long. But that wouldn't work as well for other streams.
Post Wed Jan 09, 2013 5:17 pm
- generate the link
this already happens when you set expiresImmediatelly to true (unless I didn't get what you mean). It calls extractUrl just before playing to get the latest URL
gpsis
Post Wed Jan 09, 2013 6:18 pm
Used V8 with the following syntax and (for me) it didn't work.
http://beeg.com/tag/blonde/1?genurl=1
Used V9 without the ?genurl=1 flag and still didn't work.
Rebooted computer and media player after path updates just to be certain.
Guess I should have taken some programming classes back in the '70s!
Regards!
3GBR
Post Wed Jan 09, 2013 8:21 pm
What does doesn't work mean? Use the info under my signature to post debug log etc.
mqojdn
Post Thu Jan 10, 2013 7:41 am
zip wrote:this already happens when you set expiresImmediatelly to true (unless I didn't get what you mean). It calls extractUrl just before playing to get the latest URL
The trick is that there are no online requests the first time extractUrl() is called.
Post Thu Jan 10, 2013 12:12 pm
mqojdn wrote:The trick is that there are no online requests the first time extractUrl() is called.
If it was only the first call, it would not be that big a deal. The point is that there will never be an online request, with the first call at Serviio startup or for every refresh, forced or as scheduled by default in the console. That's where the waste of resources on both the Serviio server and the source stream servers lies. The only on line request is made a playback time.
totototo
Post Sun Jan 13, 2013 5:27 pm
Hi jhb50,
It seems Beg plugin does generate URl with several different servers: it may be due to some load balancing on the server side.
However, very often URL starting by http://01.007i.net do timeout with ffmpeg process (error 1), hence files can't be played.
When URL start with http://0.video.mystreamservice.com (or other initial digit), then ffmpeg connects properly and can process files.
Could the plugin do some test on URLs and generate the most responding ones?
Thanks!
PS: did figure that out after thinking I had transcoding issues with some (most) files and not others. see post there: viewtopic.php?f=7&t=8858&p=61146#p61146
Post Mon Jan 14, 2013 5:09 am
You need to post a debug log. V9 of the plugin only generates urls to video.mystreamservice.com and will only get the link from the beeg if that link fails. Perhaps you did not restart Serviio after you loaded V9.
totototo
Post Mon Jan 14, 2013 8:38 am
Here you go
2013-01-14 09:19:56,690 DEBUG [PluginCompilerThread] Starting plugin Beeg.groovy compilation
2013-01-14 09:19:56,917 INFO  [PluginCompilerThread] Added Web Resouce plugin Beeg (Beeg.groovy), version: 9
2013-01-14 09:20:19,075 DEBUG [FeedItemUrlExtractor] Beeg: Finished extraction of url: ContentURLContainer [fileType=VIDEO, contentUrl=http://12.video.mystreamservice.com/480p/8899033.mp4, thumbnailUrl=http://cdn.anythumb.com/236x177-8899033.jpg, expiresImmediately=true, cacheKey=beeg480p, live=false, ]
2013-01-14 09:20:19,075 DEBUG [WebResourceParser] Added resource item 7: 'In the kitchen' (http://12.video.mystreamservice.com/480p/8899033.mp4)
2013-01-14 09:25:48,933 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://12.video.mystreamservice.com/480p/8899033.mp4: AVC_TS_MP_HD_AC3_ISO
2013-01-14 09:25:48,933 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000030008624 and profile Generic DLNA profile
2013-01-14 09:26:17,545 DEBUG [VideoDeliveryEngine] Delivering file 'http://12.video.mystreamservice.com/480p/8899033.mp4' using transcoding
2013-01-14 09:26:17,546 DEBUG [AbstractTranscodingDeliveryEngine] No other client uses transcoding job of file 'transcoding-temp-1000000030014122-1-ORIGINAL.stf', will stop the job
2013-01-14 09:26:17,546 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-1000000030014122-1-ORIGINAL.stf'
2013-01-14 09:26:17,546 DEBUG [ProcessExecutor] Stopping external process: Thread[Thread-55,5,main]
2013-01-14 09:26:17,547 DEBUG [ProcessUtils] Sending kill -9 to the Unix process: 444
2013-01-14 09:26:17,547 DEBUG [ProcessExecutor] Starting kill -9 444
2013-01-14 09:26:17,589 WARN  [ProcessExecutor] Process /Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg has a return code of 137! This is a possible error.
2013-01-14 09:26:17,590 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2013-01-14 09:26:17,594 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2013-01-14 09:26:17,653 DEBUG [TranscodingJobListener] Deleted temp file '/var/folders/zt/_0b272cj20lfyfpnp8h7knrh0000gn/T/Serviio/transcoding-temp-1000000030014122-1-ORIGINAL.stf': true
2013-01-14 09:26:17,653 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.3.11, Profile=Generic DLNA profile'
2013-01-14 09:26:17,654 DEBUG [VideoDeliveryEngine] Extracting new URL for the expired feed item
2013-01-14 09:26:17,654 DEBUG [FeedItemUrlExtractor] Beeg: Starting extraction of url for item: In the kitchen
2013-01-14 09:26:17,654 DEBUG [FeedItemUrlExtractor] Beeg: Extracting url
2013-01-14 09:26:18,103 DEBUG [FeedItemUrlExtractor] Beeg: Finished extraction of url: ContentURLContainer [fileType=VIDEO, contentUrl=http://01.007i.net/480p/8899033.mp4, thumbnailUrl=http://cdn.anythumb.com/236x177-8899033.jpg, expiresImmediately=true, cacheKey=beeg_8899033, live=false, ]
2013-01-14 09:26:18,103 DEBUG [VideoDeliveryEngine] Successfully set new URL for the feed item
2013-01-14 09:26:18,104 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: http://01.007i.net/480p/8899033.mp4
2013-01-14 09:26:18,104 DEBUG [ProcessExecutor] Starting /Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg -analyzeduration 10000000 -fflags +genpts -threads auto -i http://01.007i.net/480p/8899033.mp4 -y -copyts -c:v copy -bsf:v h264_mp4toannexb -c:a ac3 -b:a 384k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts /var/folders/zt/_0b272cj20lfyfpnp8h7knrh0000gn/T/Serviio/transcoding-temp-1000000030007515-1-ORIGINAL.stf
2013-01-14 09:26:18,291 WARN  [ProcessExecutor] Process /Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg has a return code of 1! This is a possible error.
2013-01-14 09:26:18,295 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
it seems initial web ressource parser is correct, but then when actual playback is requested something goes wrong, file is polled again from sever, and this time with "wrong" server.
Does it help?
Post Mon Jan 14, 2013 3:53 pm
The plugin is doing as it should. It is generating the default url at refresh time but loading the url that beeg says it wants you to use at playback time. I will add a usegen=1 option which will ignore the new beeg url and always use the default url to play the files.
Return to Available plugins
Users browsing this forum: No registered users and 57 guests
