Online sources are not availalbles
roccop
Post Sat Jan 05, 2013 12:42 pm
I tried to insert a lot of links, but from Sony TV and Denon AVR I can't see Online folder from Serviio.
In addition starting from today my Serviio have a "new" device on table: 192.168.0.2
This is my PC/Serviio server... why now Serviio found my PC?
Example:
$ ffmpeg -i rtsp://lm02.everyon.tv:1935/ptv/phd59
ffmpeg version git-2013-01-04-ddeb299 Copyright (c) 2000-2013 the FFmpeg developers
built on Jan 4 2013 22:41:51 with gcc 4.7 (Ubuntu/Linaro 4.7.2-2ubuntu1)
configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-libvpx --enable-librtmp --enable-libxvid
libavutil 52. 13.100 / 52. 13.100
libavcodec 54. 85.101 / 54. 85.101
libavformat 54. 59.103 / 54. 59.103
libavdevice 54. 3.102 / 54. 3.102
libavfilter 3. 30.104 / 3. 30.104
libswscale 2. 1.103 / 2. 1.103
libpostproc 52. 2.100 / 52. 2.100
[h264 @ 0x2fd7180] RTP: missed 2 packets
Last message repeated 1 times
[h264 @ 0x2fd7180] RTP: missed 3 packets
[rtsp @ 0x2fc6960] Estimating duration from bitrate, this may be inaccurate
Input #0, rtsp, from 'rtsp://lm02.everyon.tv:1935/ptv/phd59':
title : rtmp://111.118.21.76:1935/ptv/_definst_/phd59
Duration: N/A, start: 0.149000, bitrate: N/A
Stream #0:0: Audio: aac, 48000 Hz, stereo, fltp
Stream #0:1: Video: h264 (Constrained Baseline), yuv420p, 720x480 [SAR 32:27 DAR 16:9], 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc
I'm using:
Serviio 1.1
Linux Mint
Sony HX855
Deno AVR 213
roccop
Post Wed Jan 09, 2013 1:22 pm
Re: Online sources are not availalbles
No one who can help me? :(
slyguy42o
Post Wed Jan 09, 2013 4:11 pm
you may want to include the logs from your server so we can see what's going on.
Make sure you have detailed logging enabled and post a copy of your server logs.
roccop
Post Wed Jan 09, 2013 4:17 pm
Oh thanks a lot :)
Can you please tell me how to enable detailed log?
slyguy42o
Post Wed Jan 09, 2013 6:50 pm
roccop
Post Wed Jan 09, 2013 7:31 pm
2013-01-09 20:22:09,143 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2013-01-09 20:22:09,234 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-09 20:22:09,234 INFO  [MediaServer] Serviio DLNA media streaming server v 1.1 (rev. 6ba0dd933a8e+)
2013-01-09 20:22:09,234 INFO  [MediaServer] Petr Nejedly 2009-2012
2013-01-09 20:22:09,234 INFO  [MediaServer] http://www.serviio.org
2013-01-09 20:22:09,234 INFO  [MediaServer] Java 1.7.0_09-Oracle Corporation
2013-01-09 20:22:09,234 INFO  [MediaServer] OS Linux amd64 3.5.0-17-generic
2013-01-09 20:22:09,234 INFO  [MediaServer] File encoding: UTF-8
2013-01-09 20:22:09,235 INFO  [MediaServer] Headless mode enabled: true
2013-01-09 20:22:09,235 INFO  [MediaServer] User: rocco
2013-01-09 20:22:09,235 INFO  [MediaServer] User home dir: /home/rocco
2013-01-09 20:22:09,235 INFO  [MediaServer] Temp dir: /tmp
2013-01-09 20:22:09,235 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-09 20:22:09,516 INFO  [WebServer] Socket buffer set to 65535 bytes
2013-01-09 20:22:09,525 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-01-09 20:22:09,599 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-01-09 20:22:09,600 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-01-09 20:22:09,630 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-01-09 20:22:09,663 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2013-01-09 20:22:11,301 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2013-01-09 20:22:11,302 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2013-01-09 20:22:11,303 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2013-01-09 20:22:11,303 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2013-01-09 20:22:11,304 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2013-01-09 20:22:11,305 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2013-01-09 20:22:11,306 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2013-01-09 20:22:11,306 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2013-01-09 20:22:11,307 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2013-01-09 20:22:11,307 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2013-01-09 20:22:11,308 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2013-01-09 20:22:11,308 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2013-01-09 20:22:11,309 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2013-01-09 20:22:11,327 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2013-01-09 20:22:11,339 DEBUG [LicenseValidator] Validating license file (339 bytes)
2013-01-09 20:22:11,664 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-09 20:22:11,665 INFO  [MediaServer] License: FREE
2013-01-09 20:22:11,665 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-09 20:22:12,009 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2013-01-09 20:22:12,058 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2013-01-09 20:22:12,492 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-01-09 20:22:12,493 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2013-01-09 20:22:12,772 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2013-01-09 20:22:12,773 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2013-01-09 20:22:12,967 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2013-01-09 20:22:12,967 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2013-01-09 20:22:13,201 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-01-09 20:22:13,203 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2013-01-09 20:22:13,348 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2013-01-09 20:22:13,350 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2013-01-09 20:22:13,441 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2013-01-09 20:22:13,442 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2013-01-09 20:22:13,776 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2013-01-09 20:22:13,777 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2013-01-09 20:22:13,791 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2013-01-09 20:22:13,792 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2013-01-09 20:22:14,257 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2013-01-09 20:22:14,258 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2013-01-09 20:22:14,704 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2013-01-09 20:22:14,705 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2013-01-09 20:22:14,872 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2013-01-09 20:22:14,872 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2013-01-09 20:22:14,976 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2013-01-09 20:22:14,976 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2013-01-09 20:22:14,992 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2013-01-09 20:22:14,992 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2013-01-09 20:22:15,078 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2013-01-09 20:22:15,080 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2013-01-09 20:22:15,112 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2013-01-09 20:22:15,112 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2013-01-09 20:22:15,254 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2013-01-09 20:22:15,256 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2013-01-09 20:22:15,320 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2013-01-09 20:22:15,321 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2013-01-09 20:22:15,473 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2013-01-09 20:22:15,474 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2013-01-09 20:22:15,677 INFO  [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2013-01-09 20:22:15,678 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2013-01-09 20:22:15,747 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2013-01-09 20:22:15,748 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2013-01-09 20:22:15,786 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2013-01-09 20:22:15,787 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2013-01-09 20:22:16,091 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2013-01-09 20:22:16,092 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011
2013-01-09 20:22:16,131 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2013-01-09 20:22:16,133 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2013-01-09 20:22:16,174 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2013-01-09 20:22:16,176 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2013-01-09 20:22:16,228 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2013-01-09 20:22:16,229 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2013-01-09 20:22:16,280 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2013-01-09 20:22:16,281 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonySTR
2013-01-09 20:22:16,356 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2013-01-09 20:22:16,357 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonyCMT
2013-01-09 20:22:16,401 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2013-01-09 20:22:16,445 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2013-01-09 20:22:16,449 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2013-01-09 20:22:16,630 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2013-01-09 20:22:16,632 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo
2013-01-09 20:22:16,765 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2013-01-09 20:22:16,765 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile wp8
2013-01-09 20:22:16,863 INFO  [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2013-01-09 20:22:17,069 INFO  [Device] Created UPnP Device with UUID: c41c5514-0d79-3774-967b-023b9e31d01f, bound address: 192.168.0.2
2013-01-09 20:22:17,140 INFO  [PluginCompilerThread] Looking for plugins at /home/rocco/serviio-1.1/plugins
2013-01-09 20:22:17,141 INFO  [PluginCompilerThread] Started looking for plugins
2013-01-09 20:22:17,142 INFO  [UpdateChecker] Checking if a new version is available
2013-01-09 20:22:17,146 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path ffmpeg
2013-01-09 20:22:17,148 DEBUG [ProcessExecutor] Starting ffmpeg
2013-01-09 20:22:17,155 DEBUG [PluginCompilerThread] Starting plugin Castalba.groovy compilation
2013-01-09 20:22:18,413 DEBUG [DCRawWrapper] Invoking DCRAW to check if it exists of path dcraw
2013-01-09 20:22:18,414 DEBUG [ProcessExecutor] Starting dcraw
2013-01-09 20:22:18,416 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "dcraw": error=2, File o directory non esistente
2013-01-09 20:22:18,416 WARN  [MediaServer] DCRAW not found. Support for raw image files will be missing.
2013-01-09 20:22:18,434 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-01-09 20:22:18,523 INFO  [WebServer] WebServer starting on port 8895
2013-01-09 20:22:18,527 DEBUG [DiscoveryManager] UPNP device c41c5514-0d79-3774-967b-023b9e31d01f (192.168.0.2) is available
2013-01-09 20:22:18,527 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-01-09 20:22:18,527 INFO  [EventDispatcher] Starting EventDispatcher
2013-01-09 20:22:18,527 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-01-09 20:22:18,529 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address 192.168.0.2, timeout = 0
2013-01-09 20:22:18,552 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2013-01-09 20:22:18,552 INFO  [RendererSearchSender] Searching for Renderer devices, will multicast on 1 NICs
2013-01-09 20:22:18,556 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth0 (eth0) and address 192.168.0.2, timeout = 0
2013-01-09 20:22:18,567 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2013-01-09 20:22:18,572 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.2:35055
2013-01-09 20:22:18,572 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.2
2013-01-09 20:22:18,623 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.2:35055
2013-01-09 20:22:18,624 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.2
2013-01-09 20:22:18,624 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.2:35055
2013-01-09 20:22:18,626 DEBUG [DiscoveryAdvertisementNotifier] Found 1 network interfaces to advertise on
2013-01-09 20:22:18,626 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.0.2, timeout = 0
2013-01-09 20:22:18,627 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c41c5514-0d79-3774-967b-023b9e31d01f
2013-01-09 20:22:19,080 INFO  [PluginCompilerThread] Added Web Resouce plugin Castalba (Castalba.groovy), version: 1
2013-01-09 20:22:19,080 DEBUG [PluginCompilerThread] Starting plugin PennyArcade.groovy compilation
2013-01-09 20:22:19,310 INFO  [PluginCompilerThread] Added Feed plugin PennyArcade (PennyArcade.groovy), version: 1
2013-01-09 20:22:19,310 DEBUG [PluginCompilerThread] Starting plugin TurboTVIndia.groovy compilation
2013-01-09 20:22:19,476 INFO  [PluginCompilerThread] Added Web Resouce plugin turbotv.in (TurboTVIndia.groovy), version: 1
2013-01-09 20:22:19,476 DEBUG [PluginCompilerThread] Starting plugin USTREAM.groovy compilation
2013-01-09 20:22:19,566 INFO  [PluginCompilerThread] Added Web Resouce plugin ustream.tv (USTREAM.groovy), version: 1
2013-01-09 20:22:19,566 DEBUG [PluginCompilerThread] Starting plugin ReutersCom.groovy compilation
2013-01-09 20:22:19,599 INFO  [PluginCompilerThread] Added Feed plugin ReutersCom (ReutersCom.groovy), version: 1
2013-01-09 20:22:19,599 DEBUG [PluginCompilerThread] Starting plugin Gulli.groovy compilation
2013-01-09 20:22:19,635 INFO  [PluginCompilerThread] Added Feed plugin Gulli (Gulli.groovy), version: 1
2013-01-09 20:22:19,635 DEBUG [PluginCompilerThread] Starting plugin Channel4od.groovy compilation
2013-01-09 20:22:19,890 INFO  [PluginCompilerThread] Added Web Resouce plugin 4OD (UK only) (Channel4od.groovy), version: 1
2013-01-09 20:22:19,890 DEBUG [PluginCompilerThread] Starting plugin Sopcast.groovy compilation
2013-01-09 20:22:19,985 INFO  [PluginCompilerThread] Added Web Resouce plugin Sopcast (Sopcast.groovy), version: 1
2013-01-09 20:22:19,985 DEBUG [PluginCompilerThread] Starting plugin PBS.groovy compilation
2013-01-09 20:22:20,026 INFO  [PluginCompilerThread] Added Feed plugin PBSURLExtractor (PBS.groovy), version: 1
2013-01-09 20:22:20,026 DEBUG [PluginCompilerThread] Starting plugin APVideo.groovy compilation
2013-01-09 20:22:20,081 INFO  [PluginCompilerThread] Added Web Resouce plugin APVideo (APVideo.groovy), version: 1
2013-01-09 20:22:20,082 DEBUG [PluginCompilerThread] Starting plugin TED.groovy compilation
2013-01-09 20:22:20,136 INFO  [PluginCompilerThread] Added Web Resouce plugin TED (TED.groovy), version: 1
2013-01-09 20:22:20,136 DEBUG [PluginCompilerThread] Starting plugin AnOriant.groovy compilation
2013-01-09 20:22:20,162 INFO  [PluginCompilerThread] Added Feed plugin AnOriant (AnOriant.groovy), version: 1
2013-01-09 20:22:20,868 DEBUG [PluginCompilerThread] Starting plugin IPlayer.groovy compilation
2013-01-09 20:22:21,016 INFO  [PluginCompilerThread] Added Feed plugin BBC iPlayer (UK only) (IPlayer.groovy), version: 1
2013-01-09 20:22:21,016 DEBUG [PluginCompilerThread] Starting plugin CNN.groovy compilation
2013-01-09 20:22:21,086 INFO  [PluginCompilerThread] Added Feed plugin CNN (CNN.groovy), version: 1
2013-01-09 20:22:21,086 DEBUG [PluginCompilerThread] Starting plugin Coolsport.groovy compilation
2013-01-09 20:22:21,143 INFO  [PluginCompilerThread] Added Web Resouce plugin coolsport (Coolsport.groovy), version: 9
2013-01-09 20:22:21,143 DEBUG [PluginCompilerThread] Starting plugin LiveFeeds.groovy compilation
2013-01-09 20:22:21,191 INFO  [PluginCompilerThread] Added Feed plugin LiveFeeds (LiveFeeds.groovy), version: 1
2013-01-09 20:22:21,191 DEBUG [PluginCompilerThread] Starting plugin Syfy.groovy compilation
2013-01-09 20:24:37,569 DEBUG [WebResourceParser] Added resource item 157: ''Dorm life'' (http://0.video.mystreamservice.com/480p/6022073.mp4)
2013-01-09 20:24:37,569 DEBUG [FeedItemUrlExtractor] Beeg: Starting extraction of url for item: 'That\'s why I\'ve paid for Amy Brooke tonight'
2013-01-09 20:24:38,137 DEBUG [FeedItemUrlExtractor] Beeg: Finished extraction of url: ContentURLContainer [fileType=VIDEO, contentUrl=http://0.video.mystreamservice.com/480p/7224235.mp4, thumbnailUrl=http://cdn.anythumb.com/236x177-7224235.jpg, expiresImmediately=false, cacheKey=beeg480p, live=false, ]
2013-01-09 20:28:26,051 DEBUG [LibraryAdditionsCheckerThread] Found file 'IMG_4805.JPG', checking if it's already in the Library
2013-01-09 20:28:26,051 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item IMG_4805.JPG
2013-01-09 20:28:26,051 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /media/Disco_Dati/Immagini/Foto/Vacanze/Svezia_2009/IMG_4805.JPG, ignore case: false
2013-01-09 20:28:26,051 DEBUG [MediaItemDAOImpl] Media item IMG_4805.JPG already exists in DB
Post Thu Jan 10, 2013 8:48 am
Do you have a good version of ffmpeg ?
http://wiki.serviio.org/doku.php?id=build_ffmpeg_linux
roccop
Post Thu Jan 10, 2013 8:57 am
Illico wrote:Do you have a good version of ffmpeg ?
I think yes, because after my problem I already tried to re-install it... but why, did you see some problems about my ffmpeg?
How can I check it?
Why, now my PC is a DLNA hardware (my PC is my Serviio Server) ???
Post Thu Jan 10, 2013 9:04 am
To check, post the output of
ffmpeg -version
Post Thu Jan 10, 2013 9:07 am
Your version seems good...librtmp is enable.
You have a dcraw library error (missed).
Don't have any more idea...
khurram23
Post Thu Jan 10, 2013 2:45 pm
Have you tried to play the online stream using your PC instead of your TV?
Try using VLC on your computer to see if the online sources show up.
Dropbox - Get 500MB bonus space.
My pre-compiled FFMPEG, X264 packages for Linux/Ubuntu - Dropbox
roccop
Post Thu Jan 10, 2013 6:43 pm
Illico wrote:Your version seems good...librtmp is enable.
$ ffmpeg -version
How can I fix it?
Using VLC some of this link works fine...
Why Serviio have my PC 192.168.0.2 in the devices table?
khurram23
Post Thu Jan 10, 2013 7:09 pm
You probably opened a media player on your computer (like VLC) which serviio picked up as a possible renderer.
roccop
Post Thu Jan 10, 2013 7:31 pm
khurram23 wrote:You probably opened a media player on your computer (like VLC) which serviio picked up as a possible renderer.
Oh yes, I used VLC... but each of you have PC on the table?
khurram23
Post Thu Jan 10, 2013 8:35 pm
Try this to get your dcraw fixed... i have not tested this as I am not near a Linux box... but should work.
$ sudo apt-get install gcc libjpeg62-dev liblcms1-dev
$ wget http://www.cybercom.net/~dcoffin/dcraw/dcraw.c
$ gcc -o dcraw -O4 dcraw.c -lm -ljpeg -llcms
$ sudo cp ./dcraw /usr/bin/dcraw
Users browsing this forum: Baidu [Spider], Google [Bot] and 17 guests
