[SOLVED] H264/MP2 Online stream not working on Sony EX723
Maca
Post Wed Jan 09, 2013 3:38 pm
Trying to get this stream running http://195.245.118.40:7781/udp/239.2.2.1:1234
I get a blank screen, in VLC this stream works fine.
Here is my output:
 C:\Program Files\Serviio\lib>ffmpeg -i http://195.245.118.40:7781/udp/239.2.2.1:
1234
g-config
[h264 @ 02EC79A0] non-existing SPS 0 referenced in buffering period
[h264 @ 02EC79A0] non-existing PPS referenced
[h264 @ 02EC79A0] non-existing PPS 0 referenced
[h264 @ 02EC79A0] decode_slice_header error
[h264 @ 02EC79A0] no frame!
[mpegts @ 014CBD40] max_analyze_duration 5000000 reached at 5016000
[mpegts @ 014CBD40] Estimating duration from bitrate, this may be inaccurate
Input #0, mpegts, from 'http://195.245.118.40:7781/udp/239.2.2.1:1234':
  Duration: N/A, start: 41662.606333, bitrate: 64 kb/s
  Program 8426
  Program 8427
  Program 8428
  Program 8429
  Program 8430
  Program 8431
  Program 8432
  Program 8433
  Program 16905
  Program 16907
  Program 16908
  Program 16909
  Program 16911
  Program 16912
  Program 16913
  Program 16914
  Program 16915
  Program 16916
  Program 16918
  Program 16919
  Program 16921
  Program 16930
  Program 16931
  Program 16932
  Program 16933
    Stream #0:0[0x20](ita): Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stereo
, s16, 64 kb/s
    Stream #0:1[0x21]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 192
0x1080 [SAR 1:1 DAR 16:9], 53.70 fps, 50 tbr, 90k tbn, 50 tbc
  Program 16935
  Program 16936
  Program 16937
  Program 16938
  Program 16939
  Program 16940
  Program 16941
  Program 16942
  Program 16943
  Program 16944
  Program 16945
  Program 16946
  Program 16947
  Program 16948
  Program 16951
  Program 16952
Thanks for any help..
Post Wed Jan 09, 2013 3:59 pm
Re: Stream not working on Sony KDL-32EX723
This is a live stream, do you set serviio console as expected?
Maca
Post Wed Jan 09, 2013 4:58 pm
Illico wrote:This is a live stream, do you set serviio console as expected?
Yes, it's set as a live stream, it connects seems to play but the screen is blank.
Post Wed Jan 09, 2013 6:29 pm
OK, so its probably because the h264 profile level is >4.1.
Could you try to save a sample of the stream and check with MediaInfo tool, information about this media?
A workaround could be to edit the profiles.xml, Sony Bravia 2012 section, then this stream will be transcoded.
      <OnlineTranscoding>
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384" DAR="16:9" forceInheritance="true">
            <Matches container="asf" /> <!-- to support mms:// streams -->
            <Matches container="flv" />
            <Matches container="mpegts" vCodec="h264"/>
      </OnlineTranscoding>
Maca
Post Wed Jan 09, 2013 7:29 pm
Thanks for the help, heres a sample of the video checked with MediaInfo tool..
Menu ID                          : 16933 (0x4225)
Format profile                   : High@L4.0
Format settings, CABAC           : Yes
Format settings, ReFrames        : 4 frames
Duration                         : 4s 491ms
Width                            : 1920 pixels
Height                           : 1080 pixels
Display aspect ratio             : 16/9
Frame rate                       : 25.000 fps
Colorimetry                      : 4:2:0
Scan type                        : Interlaced
Scan order                       : Top Field First
Format                           : MPEG Audio
Format version                   : Version 1
Format profile                   : Layer 2
Bit rate                         : 64.0 Kbps
Channel(s)                       : 2 channels
Resolution                       : 16 bits
Video delay                      : -1s 370ms
Language                         : Italian
Maca
Post Thu Jan 10, 2013 11:53 am
I tried the profile changes you recommended, but it still didn't work.
Today I decided to update/check my codecs, I found the K lite pack and began the installation.
During the installation it found a DirectShow filter broken (filter data missing). Name: MainConcept MPEG Demultiplexer (mc_demux_mp2_ds_ax)
It removed the item from the registry and continued installing.
Not sure if it was a combination of your profile tweak and the codec fix but the stream now plays!
Post Thu Jan 10, 2013 12:21 pm
When you edit profile, you have to restart serviio service or reboot PC.
Maca
Post Thu Jan 10, 2013 2:08 pm
I see, must be the profile edit then.
Just out of interest does the Sony Bravia 2012 profile make changes to the other Sony Bravia profiles like the 2011 one then?
Post Thu Jan 10, 2013 5:12 pm
Maca wrote:...Just out of interest does the Sony Bravia 2012 profile make changes to the other Sony Bravia profiles like the 2011 one then?
If I understand your question...
If you edit the Sony 2012 profile section, the Sony Bravia 2011 will inherit of this modification too ( 2010 too).
So on all Sony bravia devices, all "mpegts/h264" online streams will be transcoded to mpeg/mpeg2video/ac3
Maca
Post Fri Jan 11, 2013 9:28 am
That makes sense.
Thanks for your help!
Users browsing this forum: Baidu [Spider] and 14 guests
