Does Serviio support MP3 ID3 2.4 tags?
• Page 1 of 1
For my MP3 files, I use ID3 v2.4 tags, and when browsing the Serviio, I noticed that the genre of the songs show up as a numeric number instead of text like in other programs (iTune, VLC etc). Appears that Serviio's metadata extractor for MP3 files is not handling the ID3 v2.4 tags correctly. (I tried ID3 v2.3 and they seems to be working). All the tags are converted and added through iTune, but they do show up in VLC correctly, so I don't think it's an issue with the tags themselves. Is this a known problem? I searched through the forums and did not find anyone else having the same problem.
Re: Does Serviio support MP3 ID3 2.4 tags?
They should be supported. Can you send me one song to my email address and I'll have a look.
Petr
Help translate Serviio
Send you a couple samples. Hopefully it will help you track down if it's a issue on my end or Serviio has a bug handling ID3 v2.4 tags. Let me know your results.
Thanks, fixed now for 1.2
Petr
• Page 1 of 1
Users browsing this forum: No registered users and 59 guests
