Any way to control Serviio's time-out behavior?
Massachute
Post Fri Jan 11, 2013 2:37 pm
When I am watching a show or stream on my TV via Serviio, and some difficulty causes it to time-out, it automatically starts up the next show/stream on the menu. Is there a way to control this behavior?
It's almost never what I want it to do -- which is to keep trying to restart the show I chose until I give up and tell it to stop (and not to go on to the next menu item, since it's not what I wanted). When this happens, I have to manually stop the next show/stream from running, go back to the item I chose in the first place, find where I was (if the problem has disappeared) and start again.
I suspect this has been asked before (hard to believe I'm the only one with this question) but I haven't been able to find a previous discussion (by searching for "timeout" in various spellings)-- so forgive me if it's been asked before.
slyguy42o
Post Fri Jan 11, 2013 7:30 pm
Re: Any way to control Serviio's time-out behavior?
I am not 100% but I think the timeout settings you are referring to are inherent to the TV itself rather than Serviio, and unfortunately most TV's out there don't allow us to change such settings.
