HAHASPORT - A DYNAMIC SPORTS STREAMS WEB RESOURCE
Re: HAHASPORT - A DYNAMIC SPORTS STREAMS WEB RESOURCE
Dear jhb! You're a genius. CPU is now at a very low level. Thank you.
I have the feeling that the plugin doesn't show now live events. Maybe the webformat has been changed again.
Right. Version 18 posted to support revised web format
Thank you again!
Posted Version 19 to correct a refresh timing error.
I think the problem is now the same as yesterday.
They are all working fine for me.
Did you try with hahasport football? I have problem with it.
Yes it worked fine.. check your debug log to make sure it says hahasport parsing with V19. Sometimes Serviio does not accept the update when you copy it into the plugin folder and you need to restart.
Version 20 posted. Groovy tuned to run faster, coolsport source extracts updated.
Thank you. It's perfect now.
Version 21 posted with Liveall source change
Hi everyone, I am hoping someone can help me. I seem to be only having issue with hahasport feeds and this is what I get repeatedly in the log file.
2013-01-25 18:02:36,086 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Cannot parse resource from http://www.hahasport.com. Message: No plugin for web resource http://www.hahasport.com has been found.
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:179)
Most obviously I have the .groovy plugin in the right directory and I have stopped and restarted the service and the server itself to no avail.
I gotta have my sports..
Help..
Ok well if you put the webresource url as http://www.hahasport.com it does not work and I get the error message in log.
But when I changed the webresource as one of the sub ones like http://www.hahasport.com/c-4.html then it works!!
is this expected behavior??
Jeera911 wrote:Hi everyone, I am hoping someone can help me. I seem to be only having issue with hahasport feeds and this is what I get repeatedly in the log file.
I gotta have my sports..Help..
For now Use http://www.hahasport.com/
I will fix it in the next version.
For the life of me I can not get the estream param to work:
http://www.hahasport.com/c-8.html?refresh=30&estreams=9
only ever shows 1 but on the actual www.hahasport.com shows multiple feeds................
There are only 3 golf feed items, and the current plugin version only decodes the first one.
Can that be updated? I ask as last night there were 3 feeds for the U.S. PGA, and at least the first two were different (same channel, but different feeds)....
If not, so be it, still a great resouce.
Version 22 posted with new source feeds and ips.
This is a major upgrade of the plugin and features a new quick refresh capability as described in the wiki at http://wiki.serviio.org/doku.php?id=quick_refresh.
This makes it practical to do refreshes frequently using the refresh parameter and keep the list of items up to date without the overhead of re-extracting the existing items. Refreshes that previously took many minutes are now done in one or two seconds.
