No files found
Givo
Post Fri Jan 11, 2013 11:45 pm
No files found
Hello guys,
I just installed Serviio on my Ubuntu 11.10 machine and its running fine as I can connect via Ipod and Xbox but I cannot see any of my media files.
Cheers.
Logs below are fresh then I connect with my Ipod and look for media.
Wouldn't let me post all of it so I deleted the ID stuff (xbox etc).
Cheers!
2013-01-11 18:34:51,218 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2013-01-11 18:34:51,227 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-11 18:34:51,227 INFO  [MediaServer] Serviio DLNA media streaming server v 1.1 (rev. 6ba0dd933a8e+)
2013-01-11 18:34:51,227 INFO  [MediaServer] Petr Nejedly 2009-2012
2013-01-11 18:34:51,227 INFO  [MediaServer] http://www.serviio.org
2013-01-11 18:34:51,227 INFO  [MediaServer] Java 1.6.0_24-Sun Microsystems Inc.
2013-01-11 18:34:51,227 INFO  [MediaServer] OS Linux i386 3.0.0-12-generic-pae
2013-01-11 18:34:51,227 INFO  [MediaServer] File encoding: US-ASCII
2013-01-11 18:34:51,228 INFO  [MediaServer] Headless mode enabled: true
2013-01-11 18:34:51,228 INFO  [MediaServer] User: root
2013-01-11 18:34:51,228 INFO  [MediaServer] User home dir: /root
2013-01-11 18:34:51,228 INFO  [MediaServer] Temp dir: /tmp
2013-01-11 18:34:51,228 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-11 18:34:51,361 INFO  [WebServer] Socket buffer set to 65535 bytes
2013-01-11 18:34:51,362 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-01-11 18:34:51,400 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-01-11 18:34:51,400 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-01-11 18:34:51,414 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-01-11 18:34:51,421 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2013-01-11 18:34:52,209 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2013-01-11 18:34:52,211 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2013-01-11 18:34:52,212 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2013-01-11 18:34:52,213 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2013-01-11 18:34:52,213 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2013-01-11 18:34:52,214 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2013-01-11 18:34:52,214 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2013-01-11 18:34:52,215 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2013-01-11 18:34:52,216 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2013-01-11 18:34:52,217 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2013-01-11 18:34:52,218 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2013-01-11 18:34:52,218 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2013-01-11 18:34:52,219 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2013-01-11 18:34:52,230 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2013-01-11 18:34:52,241 DEBUG [LicenseValidator] Validating license file (339 bytes)
2013-01-11 18:34:52,321 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-11 18:34:52,321 INFO  [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2013-01-11 18:34:52,599 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2013-01-11 18:34:59,942 INFO  [Device] Created UPnP Device with UUID: 4efc7d48-9fca-3edb-83c7-691ad71e3f55, bound address: 192.168.2.14
2013-01-11 18:34:59,961 INFO  [PluginCompilerThread] Looking for plugins at /serviio-1.1/plugins
2013-01-11 18:34:59,962 INFO  [PluginCompilerThread] Started looking for plugins
2013-01-11 18:34:59,972 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path ffmpeg
2013-01-11 18:34:59,972 INFO  [UpdateChecker] Checking if a new version is available
2013-01-11 18:34:59,983 DEBUG [ProcessExecutor] Starting ffmpeg
2013-01-11 18:35:00,058 DEBUG [DCRawWrapper] Invoking DCRAW to check if it exists of path dcraw
2013-01-11 18:35:00,061 DEBUG [ProcessExecutor] Starting dcraw
2013-01-11 18:35:00,071 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "dcraw": java.io.IOException: error=2, No such file or directory
2013-01-11 18:35:00,072 WARN  [MediaServer] DCRAW not found. Support for raw image files will be missing.
2013-01-11 18:35:00,080 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-01-11 18:35:00,111 INFO  [WebServer] WebServer starting on port 8895
2013-01-11 18:35:00,119 DEBUG [DiscoveryManager] UPNP device 4efc7d48-9fca-3edb-83c7-691ad71e3f55 (192.168.2.14) is available
2013-01-11 18:35:00,119 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-01-11 18:35:00,120 INFO  [EventDispatcher] Starting EventDispatcher
2013-01-11 18:35:00,129 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address 192.168.2.14, timeout = 0
2013-01-11 18:35:00,130 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-01-11 18:35:00,132 INFO  [RendererSearchSender] Searching for Renderer devices, will multicast on 1 NICs
2013-01-11 18:35:00,134 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2013-01-11 18:35:00,137 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth0 (eth0) and address 192.168.2.14, timeout = 0
2013-01-11 18:35:00,154 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2013-01-11 18:35:00,163 DEBUG [DiscoveryAdvertisementNotifier] Found 1 network interfaces to advertise on
2013-01-11 18:35:00,164 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.2.14, timeout = 0
2013-01-11 18:35:00,166 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 4efc7d48-9fca-3edb-83c7-691ad71e3f55
2013-01-11 18:35:00,168 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.2.14:34841
2013-01-11 18:35:00,168 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.14
2013-01-11 18:35:00,193 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.2.14:34841
2013-01-11 18:35:00,193 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.14
2013-01-11 18:35:00,195 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.2.14:34841
2013-01-11 18:35:00,195 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.14
2013-01-11 18:35:01,988 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2013-01-11 18:35:03,109 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.2.100:50770
2013-01-11 18:35:03,109 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2013-01-11 18:35:03,114 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.2.100:50770
2013-01-11 18:35:03,114 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2013-01-11 18:35:03,117 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.2.100:50770
2013-01-11 18:35:04,499 DEBUG [WebServer] Incoming connection from /192.168.2.100:60500
2013-01-11 18:35:04,501 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2013-01-11 18:35:04,504 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 4efc7d48-9fca-3edb-83c7-691ad71e3f55 from 192.168.2.100 (headers = [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.2.14:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7600.16385 DLNADOC/1.50])
2013-01-11 18:35:04,505 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2013-01-11 18:35:04,512 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.2.14:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7600.16385 DLNADOC/1.50]
2013-01-11 18:35:04,514 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2013-01-11 18:35:04,697 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2013-01-11 18:35:04,726 DEBUG [WebServer] Incoming connection from /192.168.2.100:60501
2013-01-11 18:35:04,729 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2013-01-11 18:35:04,729 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2013-01-11 18:35:06,109 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.2.100:50770
2013-01-11 18:35:06,110 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2013-01-11 18:35:06,113 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.2.100:50770
2013-01-11 18:35:06,113 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2013-01-11 18:35:06,114 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.2.100:50770
2013-01-11 18:35:06,162 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2013-01-11 18:35:10,167 DEBUG [DiscoveryAdvertisementNotifier] Found 1 network interfaces to advertise on
2013-01-11 18:35:10,167 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.2.14, timeout = 0
2013-01-11 18:35:10,168 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 4efc7d48-9fca-3edb-83c7-691ad71e3f55
2013-01-11 18:35:11,990 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2013-01-11 18:35:20,169 DEBUG [DiscoveryAdvertisementNotifier] Found 1 network interfaces to advertise on
2013-01-11 18:35:20,169 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.2.14, timeout = 0
2013-01-11 18:35:20,176 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 4efc7d48-9fca-3edb-83c7-691ad71e3f55
2013-01-11 18:35:21,996 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:33 (advertisement duration is 1800 sec.)
2013-01-11 18:35:26,168 INFO  [FeedUpdaterThread] Started looking for information about online resources
2013-01-11 18:35:26,168 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-01-11 18:35:26,174 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-01-11 18:35:26,176 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-01-11 18:35:26,192 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-01-11 18:35:26,197 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-01-11 18:35:26,214 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2013-01-11 18:35:26,198 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-01-11 18:35:26,218 DEBUG [PlaylistDAOImpl] Reading all Playlists
2013-01-11 18:36:09,111 DEBUG [WebServer] I/O error: Connection reset
2013-01-11 18:36:26,253 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-01-11 18:36:26,254 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-01-11 18:37:26,255 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-01-11 18:37:26,255 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-01-11 18:38:26,257 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-01-11 18:38:26,257 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-01-11 18:38:55,745 DEBUG [DiscoveryAdvertisementNotifier] Found 1 network interfaces to advertise on
2013-01-11 18:38:55,745 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.2.14, timeout = 0
2013-01-11 18:38:55,746 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 4efc7d48-9fca-3edb-83c7-691ad71e3f55
2013-01-11 18:38:57,564 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:04:13 (advertisement duration is 1800 sec.)
2013-01-11 18:39:26,259 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-01-11 18:39:26,259 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-01-11 18:40:26,252 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-01-11 18:40:26,259 DEBUG [PlaylistDAOImpl] Reading all Playlists
2013-01-11 18:40:26,261 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-01-11 18:40:26,261 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-01-11 18:41:26,262 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-01-11 18:41:26,262 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-01-11 18:41:53,490 DEBUG [WebServer] Incoming connection from /192.168.2.110:49427
2013-01-11 18:41:53,492 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:41:53,493 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 4efc7d48-9fca-3edb-83c7-691ad71e3f55 from 192.168.2.110 (headers = [Host: 192.168.2.14:8895,Content-Length: 0])
2013-01-11 18:41:53,494 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:41:53,495 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.2.14:8895,Content-Length: 0]
2013-01-11 18:41:53,495 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:41:53,501 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2013-01-11 18:41:54,921 DEBUG [WebServer] Incoming connection from /192.168.2.110:49437
2013-01-11 18:41:54,923 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:41:54,923 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 4efc7d48-9fca-3edb-83c7-691ad71e3f55 from 192.168.2.110 (headers = [Host: 192.168.2.14:8895,Content-Length: 0])
2013-01-11 18:41:54,924 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.2.14:8895,Content-Length: 0]
2013-01-11 18:41:54,925 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:41:54,926 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2013-01-11 18:41:56,187 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:ContentDirectory:1 from address /192.168.2.110:51622
2013-01-11 18:41:56,187 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:41:56,188 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:AVTransport:1 from address /192.168.2.110:51622
2013-01-11 18:41:56,188 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:41:56,189 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.2.110:51622
2013-01-11 18:41:57,242 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:ContentDirectory:1 from address /192.168.2.110:51622
2013-01-11 18:41:57,242 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:41:57,243 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.2.110:51622
2013-01-11 18:41:57,258 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:AVTransport:1 from address /192.168.2.110:51622
2013-01-11 18:41:57,258 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:41:57,778 DEBUG [WebServer] Incoming connection from /192.168.2.110:49443
2013-01-11 18:41:57,866 DEBUG [WebServer] Incoming connection from /192.168.2.110:49445
2013-01-11 18:41:57,867 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:41:57,868 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 4efc7d48-9fca-3edb-83c7-691ad71e3f55 from 192.168.2.110 (headers = [Host: 192.168.2.14:8895,Content-Length: 0])
2013-01-11 18:41:57,868 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:41:57,868 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.2.14:8895,Content-Length: 0]
2013-01-11 18:41:57,869 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:41:57,871 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2013-01-11 18:41:58,200 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:ContentDirectory:1 from address /192.168.2.110:51622
2013-01-11 18:41:58,200 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:41:58,201 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.2.110:51622
2013-01-11 18:41:58,202 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:AVTransport:1 from address /192.168.2.110:51622
2013-01-11 18:41:58,202 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:41:59,200 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:ContentDirectory:1 from address /192.168.2.110:51622
2013-01-11 18:41:59,200 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:41:59,201 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.2.110:51622
2013-01-11 18:41:59,201 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:AVTransport:1 from address /192.168.2.110:51622
2013-01-11 18:41:59,201 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:41:59,746 DEBUG [WebServer] Incoming connection from /192.168.2.110:49451
2013-01-11 18:41:59,750 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:41:59,751 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 4efc7d48-9fca-3edb-83c7-691ad71e3f55 from 192.168.2.110 (headers = [Host: 192.168.2.14:8895,Content-Length: 0])
2013-01-11 18:41:59,751 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:41:59,751 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.2.14:8895,Content-Length: 0]
2013-01-11 18:41:59,752 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:41:59,755 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2013-01-11 18:42:02,913 DEBUG [WebServer] Incoming connection from /192.168.2.110:49456
2013-01-11 18:42:02,920 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:02,921 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.2.110:
2013-01-11 18:42:02,921 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:03,061 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-11 18:42:03,106 DEBUG [WebServer] Incoming connection from /192.168.2.110:49457
2013-01-11 18:42:03,108 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:03,109 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.2.110:
2013-01-11 18:42:03,109 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:03,112 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-11 18:42:03,115 DEBUG [WebServer] Incoming connection from /192.168.2.110:49458
2013-01-11 18:42:03,281 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:03,282 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.2.110:
2013-01-11 18:42:03,282 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:03,301 DEBUG [ContentDirectory] Browse() called for renderer Unrecognized device (profile 1) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 200, sortCriteria =
2013-01-11 18:42:03,303 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-11 18:42:03,336 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2013-01-11 18:42:03,338 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=0, titleKey=pc5dczc_media_library, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = null
2013-01-11 18:42:03,355 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A, titleKey=audio, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-01-11 18:42:03,357 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_A, titleKey=artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-11 18:42:03,360 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,366 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,369 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,374 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,376 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=AL_A, titleKey=album_artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-11 18:42:03,379 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,383 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,385 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForAlbumArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,387 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,391 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-11 18:42:03,393 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=local_default
2013-01-11 18:42:03,397 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-11 18:42:03,401 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioGenresByNameCommand, containerClass=MUSIC_GENRE, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,403 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForGenreCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,407 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_C, titleKey=composers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-11 18:42:03,410 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,413 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposersForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=COM, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,417 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForComposerCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,420 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForComposerAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,422 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-11 18:42:03,426 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,429 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForInitialCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,431 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_R, titleKey=random, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-01-11 18:42:03,435 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListRandomSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=no_cache
2013-01-11 18:42:03,438 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-11 18:42:03,441 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioPlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,444 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForPlaylistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,447 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-01-11 18:42:03,451 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2013-01-11 18:42:03,454 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_S, titleKey=All songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2013-01-11 18:42:03,457 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,460 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_AS, titleKey=Artist Songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2013-01-11 18:42:03,464 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsByNameCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART_S, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,468 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,471 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_ALB, titleKey=All albums, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2013-01-11 18:42:03,475 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,479 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,482 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I, titleKey=image, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-01-11 18:42:03,485 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_A, titleKey=albums, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-11 18:42:03,489 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListFlatImageFoldersByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,496 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForFolderCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,499 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-11 18:42:03,503 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=local_default
2013-01-11 18:42:03,506 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_Y, titleKey=year, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-11 18:42:03,510 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,514 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,521 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_T, titleKey=month, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-11 18:42:03,526 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,529 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationMonthsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=MON, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,532 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationMonthAndYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,537 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-11 18:42:03,540 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagePlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,544 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForPlaylistCommand, containerClass=null, itemClass=PHOTO, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,547 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-01-11 18:42:03,550 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2013-01-11 18:42:03,554 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_AI, titleKey=All images, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2013-01-11 18:42:03,558 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListAllImagesCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,561 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V, titleKey=video, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-01-11 18:42:03,565 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-11 18:42:03,569 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,574 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForInitialCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,578 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_M, titleKey=movies, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-11 18:42:03,581 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosByNameCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,586 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_S, titleKey=series, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-11 18:42:03,589 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeriesByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SER, recursive=false, cacheRegion=local_resetafterplay
2013-01-11 18:42:03,592 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeasonsForSeriesCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SSN, recursive=false, cacheRegion=local_resetafterplay
2013-01-11 18:42:03,597 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListEpisodesForSeriesSeasonCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2013-01-11 18:42:03,602 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-11 18:42:03,607 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=local_default
2013-01-11 18:42:03,610 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LV, titleKey=last_viewed, class=CONTAINER, cacheRegion=local_resetafterplay, browsable = null, editable = true
2013-01-11 18:42:03,614 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastViewedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2013-01-11 18:42:03,618 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LA, titleKey=last_added, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-11 18:42:03,623 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastAddedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,626 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-11 18:42:03,631 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoGenresByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,635 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForGenreCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,639 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_A, titleKey=actors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-11 18:42:03,644 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,648 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,653 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForActorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,656 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_D, titleKey=directors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-11 18:42:03,660 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,665 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,671 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForDirectorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,676 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_P, titleKey=producers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-11 18:42:03,679 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,683 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducersForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,689 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForProducerCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,693 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-11 18:42:03,699 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoPlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,702 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForPlaylistCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-11 18:42:03,706 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-01-11 18:42:03,711 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2013-01-11 18:42:03,732 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2013-01-11 18:42:03,744 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-11 18:42:03,883 DEBUG [WebServer] Incoming connection from /192.168.2.110:49459
2013-01-11 18:42:03,885 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:03,886 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.2.110:
2013-01-11 18:42:03,886 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:03,890 DEBUG [ContentDirectory] Browse() called for renderer Unrecognized device (profile 1) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = *, startIndex = 3, count = 200, sortCriteria =
2013-01-11 18:42:03,891 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-11 18:42:03,893 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-11 18:42:05,102 DEBUG [WebServer] Incoming connection from /192.168.2.110:49464
2013-01-11 18:42:05,104 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:05,105 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.2.110:
2013-01-11 18:42:05,106 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:05,109 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-11 18:42:05,122 DEBUG [WebServer] Incoming connection from /192.168.2.110:49465
2013-01-11 18:42:05,124 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:05,125 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.2.110:
2013-01-11 18:42:05,125 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:05,131 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-11 18:42:05,132 DEBUG [WebServer] Incoming connection from /192.168.2.110:49466
2013-01-11 18:42:05,133 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:05,133 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.2.110:
2013-01-11 18:42:05,137 DEBUG [ContentDirectory] Browse() called for renderer Unrecognized device (profile 1) with parameters: objectID = A, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 200, sortCriteria =
2013-01-11 18:42:05,138 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-11 18:42:05,146 DEBUG [PersonDAOImpl] Retrieving number of person initials for role ARTIST
2013-01-11 18:42:05,197 DEBUG [PersonDAOImpl] Retrieving number of person initials for role ALBUM_ARTIST
2013-01-11 18:42:05,202 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for AUDIO [No_Restriction]
2013-01-11 18:42:05,236 DEBUG [GenreDAOImpl] Retrieving number of genres for AUDIO
2013-01-11 18:42:05,296 DEBUG [PersonDAOImpl] Retrieving number of person initials for role COMPOSER
2013-01-11 18:42:05,306 DEBUG [MusicTrackDAOImpl] Retrieving number of music track initials [No_Restriction]
2013-01-11 18:42:05,337 DEBUG [MusicTrackDAOImpl] Retrieving number of random music tracks [No_Restriction]
2013-01-11 18:42:05,382 DEBUG [PlaylistDAOImpl] Retrieving number of playlists for AUDIO [No_Restriction]
2013-01-11 18:42:05,409 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for AUDIO [No_Restriction]
2013-01-11 18:42:05,439 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for AUDIO [No_Restriction]
2013-01-11 18:42:05,464 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-11 18:42:05,710 DEBUG [WebServer] Incoming connection from /192.168.2.110:49467
2013-01-11 18:42:05,713 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:05,714 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.2.110:
2013-01-11 18:42:05,714 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:05,717 DEBUG [ContentDirectory] Browse() called for renderer Unrecognized device (profile 1) with parameters: objectID = A, browseFlag = BrowseDirectChildren, filter = *, startIndex = 9, count = 200, sortCriteria =
2013-01-11 18:42:05,717 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-11 18:42:05,720 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-11 18:42:08,011 DEBUG [WebServer] Incoming connection from /192.168.2.110:49472
2013-01-11 18:42:08,021 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:08,022 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.2.110:
2013-01-11 18:42:08,022 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:08,026 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-11 18:42:08,039 DEBUG [WebServer] Incoming connection from /192.168.2.110:49473
2013-01-11 18:42:08,042 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:08,043 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.2.110:
2013-01-11 18:42:08,043 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:08,054 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-11 18:42:08,056 DEBUG [WebServer] Incoming connection from /192.168.2.110:49474
2013-01-11 18:42:08,057 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:08,058 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.2.110:
2013-01-11 18:42:08,058 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:08,064 DEBUG [ContentDirectory] Browse() called for renderer Unrecognized device (profile 1) with parameters: objectID = A_T, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 200, sortCriteria =
2013-01-11 18:42:08,065 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-11 18:42:08,066 DEBUG [MusicTrackDAOImpl] Retrieving list of music track initials (from=0, count=200) [No_Restriction]
2013-01-11 18:42:08,089 DEBUG [MusicTrackDAOImpl] Retrieving number of music track initials [No_Restriction]
2013-01-11 18:42:08,092 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-01-11 18:42:08,094 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-11 18:42:13,975 DEBUG [WebServer] Incoming connection from /192.168.2.110:49475
2013-01-11 18:42:13,987 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:13,988 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.2.110:
2013-01-11 18:42:13,988 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:13,992 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-11 18:42:14,007 DEBUG [WebServer] Incoming connection from /192.168.2.110:49476
2013-01-11 18:42:14,011 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:14,011 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.2.110:
2013-01-11 18:42:14,012 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:14,015 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-11 18:42:14,016 DEBUG [WebServer] Incoming connection from /192.168.2.110:49477
2013-01-11 18:42:14,018 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:14,019 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.2.110:
2013-01-11 18:42:14,019 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.110
2013-01-11 18:42:14,024 DEBUG [ContentDirectory] Browse() called for renderer Unrecognized device (profile 1) with parameters: objectID = A_G, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 200, sortCriteria =
2013-01-11 18:42:14,024 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-11 18:42:14,025 DEBUG [GenreDAOImpl] Retrieving list of genres for AUDIO (from=0, count=200)
2013-01-11 18:42:14,050 DEBUG [GenreDAOImpl] Retrieving number of genres for AUDIO
2013-01-11 18:42:14,054 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-01-11 18:42:14,058 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-11 18:42:26,264 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-01-11 18:42:26,264 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-01-11 18:43:10,657 DEBUG [DiscoveryAdvertisementNotifier] Found 1 network interfaces to advertise on
2013-01-11 18:43:10,657 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.2.14, timeout = 0
2013-01-11 18:43:10,657 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 4efc7d48-9fca-3edb-83c7-691ad71e3f55
2013-01-11 18:43:12,482 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:22 (advertisement duration is 1800 sec.)
khurram23
Post Sat Jan 12, 2013 2:22 am
Re: No files found
Have you added content?
Open Console : /path/to/serviio/bin/serviio-console.sh
Library tab > Shared Folders > Add Local > Find where your media is > Make sure the check box under Video is enabled for the location you just added.
Click Save
Wait a min or so, try again.
Dropbox - Get 500MB bonus space.
My pre-compiled FFMPEG, X264 packages for Linux/Ubuntu - Dropbox
Givo
Post Sat Jan 12, 2013 4:12 am
Re: No files found
khurram23 wrote:Have you added content?
I think so, Ive put it in the library folder?
khurram23 wrote:Open Console : /path/to/serviio/bin/serviio-console.sh
Its running yes.
khurram23 wrote:Library tab > Shared Folders > Add Local > Find where your media is > Make sure the check box under Video is enabled for the location you just added.
I don't understand? Check boxes? I am running Ubuntu Server.
Cheers.
Exit: Got it working by installing the web interface as said above.
