which video & metadata organizer for serviio ??
audioscavenger
Post Sat Jan 12, 2013 9:04 pm
hello
I wonder, there are plenty of media organizers, mainly for XBMC, but not only.
which one do you use for serviio ?
I recently tested MCM / Media Center Master, which produces XBMC compatible nfo (XML), but incompatible posters :
I read in the FAQ that serviio is seeking for "Video: dvdcover.jpg, movie.jpg, name including "poster".jpg, {media_file_name}.jpg"
MCM is producing instead : folder.jpg and {media_file_name}.tbn
If I understand, none of these are suitable for serviio.
which media organizer can you advise me ?
Or should I ask for a feature for serviio to scan for user poster mask naming ?
thks
serviio 1.1 for Thecus N5550 x86_64
DeanoX
Post Sun Jan 13, 2013 10:38 pm
Re: which video & metadata organizer for serviio ??
Ember (http://ember.purplepig.net/) can be configured for {media_file_name}.jpg amongst many others - Which is what I use with multiple videos per directory.
Select "<movie>.jpg" for the Poster file naming option under the "Files and Sources" Section of the "Movies" tab within settings.
Zyxel NSA325 running Serviio 1.1 | Sony Bravia 2011 KDL-24EX320 / KDL-40EX723
Users browsing this forum: No registered users and 49 guests
