IP camera feed in online section
kiwiman2000
Post Mon Jan 14, 2013 4:38 am
Although the live streams can be used for camera feeds it dont work with
one of my cameras.. a wanscam (which seems to be same firmware as
the dericam m2) it doesnt support rtsp like the other camera I have (hd 720p)
which works with the live streams.(that one is same as dericam fw501 by looks)
the error in log seems to be it cant work out the http media and get red cross
Jpmpeg is probably the reason?
so a entry for ip cameras with http to force a transcode would help
as I can use VLC stream function to transcode in background and then
use the 127.0.0.1 port to get a mmsh feeding from it which works with
live streams.. but its not the best
as its reading the camera stream all the time and putting extra strain
on bandwidth etc and a plugin would only
access the stream when you click the link in the media server
why add ipcamera option.. very nice to see front door and outside house camera
on the big screen instead of using a APP on the android tablet :)
Post Mon Jan 14, 2013 3:10 pm
Re: IP camera feed in online section
if you have the camera stream URL, post ffmpeg -i for it
kiwiman2000
Post Tue Jan 15, 2013 12:10 am
the general url to camera
http://id:pwd@192.168.1.55:99/videostream.cgi?rate=11
I get back with what ffmpeg sees.
I suspect vlc handles its better then ffmpeg
why some media servers and camera software (like ispy) offer a VLC plugin
perhaps someone can write a plugin for vlc where can enter the url want to convert etc
ideally LIVE STREAM needs an option to feed non urls like perhaps VLC.exe params ?
kiwiman2000
Post Tue Jan 15, 2013 12:16 am
C:\Program Files\Serviio\lib>ffmpeg -i http://ID2010:PWD2010@192.168.1.
g-config
[loas @ 002CBDA0] Format loas detected only with low score of 1, misdetection po
ssible!
[loas @ 002CBDA0] Stream #0: not enough frames to estimate rate; consider increa
sing probesize
[loas @ 002CBDA0] decoding for stream 0 failed
[loas @ 002CBDA0] Could not find codec parameters (Audio: aac_latm, 0 channels,
s16)
[loas @ 002CBDA0] Estimating duration from bitrate, this may be inaccurate
http://id2010:pwd2010@192.168.1.55:99/v ... gi?rate=11: could no
Dont seem FFMPEG likes it at all
however now issue feeding it into vlc
and no issue using rtsp url on the other hd camera I have
is ffmpeg limited or buggy perhaps?
Post Tue Jan 15, 2013 5:10 pm
try this
ffmpeg -i "http://id:pwd@192.168.1.55:99/videostream.cgi?rate=11"
kiwiman2000
Post Mon Jan 21, 2013 4:24 am
it did the same.
I checked the url format in firefox.. it popped up your about to login message then clicked ok
and went in streaming fine
next I tried the url in google chrome went straight in and streamed fine
IE8 kept saying the http site not found.. typical MS always a issue
so im wondering if thats the problem.. its trying to use windows IE in serviio to
get the data
of course vlc no issue also goes in and streams
kiwiman2000
Post Mon Jan 21, 2013 4:34 am
tried this format as well worked in firefox but IE gave do you wish to find or save pop up lol
anyhow ffmpeg still gave the same error as before
http://192.168.1.55:99/videostream.cgi? ... n&pwd=blag
kiwiman2000
Post Mon Jan 21, 2013 4:38 am
I checked the source code for IE8 and it uses snapshot.cgi rather then stream for the mobile
section and runs it in a loop in js so it reads a single snap each time and updates the
webpage beats me what to try next
Tomok
Post Thu Feb 07, 2013 7:29 am
I am running some older AXIS-ip-cameras (#2100, #2120, #2420). The only possible stream-format is MJPEG with variable frame rates depending on the actual light.
Using the option
'-use_wallclock_as_timestamps 1'
FFmpeg transcodes the MJPEG stream input into MPG which can be handled by Serviio.
Example for recording from AXIS-ip-cams:
ffmpeg.exe -use_wallclock_as_timestamps 1 -re -i "http://192.168.x.xx/mjpg/video.mjpg" -target pal-dvd c:\my-output.mpg
Streaming (UDP only):
ffmpeg.exe -use_wallclock_as_timestamps 1 -re -i "http://192.168.x.xx/mjpg/video.mjpg" -target pal-dvd udp://192.168.x.xyz:6789
Serviio doesn't accept UDP-input but FFmpeg is already enclosed. How can I add '-use_wallclock_as_timestamps 1' as an option to Serviio's FFmpeg ?
Thank you in advance.
Best regards.
Post Thu Feb 07, 2013 10:31 am
Tomok wrote: How can I add '-use_wallclock_as_timestamps 1' as an option to Serviio's FFmpeg ?
You can't
Tomok
Post Thu Feb 07, 2013 11:18 pm
> You cant
too bad! I hope you will do it sometime ... :-)
My workaround (WinXP-SP3) for the meantime:
1. Transcoding IP-cam-MJPEG-stream --> MPG via UDP:
ffmpeg.exe -use_wallclock_as_timestamps 1 -re -i "http://192.168.2.xx/mjpg/video.mjpg" -filter:v yadif -target pal-dvd udp://192.168.2.yyy:6789
('-filter:v yadif' is a deinterlacing option)
2. Restreaming UDP --> TCP:
vlc.exe udp://@192.168.2.yyy:6789 --sout #std{mux=ts,access=http,dst=127.0.0.1:8081}
Running both programms Serviio picks the IP-cam's stream online at http://127.0.0.1:8081 and 'transports' it to my TV for hours without any crash.
Thank you very much for Serviio ! Best regards.
mpi
Post Mon Feb 25, 2013 3:33 pm
I'm having similar issue with Dericam 502W (h264), I can't manage to enable in online feed.
here is the debug log
2013-02-28 22:24:16,377 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtsp://user:pass@IP_ADDR:81. It might not play.
java.io.IOException: org.serviio.library.local.metadata.extractor.InvalidMediaFormatException: Unknown video width.
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:291)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:209)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:102)
Caused by: org.serviio.library.local.metadata.extractor.InvalidMediaFormatException: Unknown video width.
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:415)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:89)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:127)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:268)
   ... 2 more
Here is ffmpeg info.
$ ./ffmpeg -i "rtsp://user:pass@IP_ADDR:81"
  built on Jul 10 2012 22:12:54 with gcc 4.0.1 (Apple Inc. build 5493)
  configuration: --enable-static --disable-shared --bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-librtmp --enable-pthreads --disable-mmx --extra-ldflags=-L/tmp/static/lib --extra-cflags=-I/tmp/static/include --extra-libs=-lpolarssl
[rtsp @ 0x13ad000] UDP timeout, retrying with TCP
[rtsp @ 0x13ad000] Could not find codec parameters (Video: h264)
[rtsp @ 0x13ad000] Estimating duration from bitrate, this may be inaccurate
Guessed Channel Layout for  Input Stream #0.1 : mono
Input #0, rtsp, from 'rtsp://user:pass@IP_ADDR:81':
    title           : h264 stream by H.264/MJPEG RTSP stream(IPCamera_Logo)
  Duration: N/A, start: 0.000000, bitrate: 64 kb/s
    Stream #0:0: Video: h264, 90k tbr, 90k tbn, 180k tbc
    Stream #0:1: Audio: pcm_mulaw, 8000 Hz, mono, s16, 64 kb/s
Thanks for any help!
Tomok
Post Sun Mar 10, 2013 8:43 am
please keep in mind that I am doing a pre-transcoding outside Serviio to generate my own MPG-online-stream (older AXIS-IP-cams support MJPEG only).
As kiwiman2000 has mentioned before this additional process continuously consumes CPU-power – whether Serviio is used or not.
Btw:
Using the RTP protocol the additional VLC restreaming (UDP -> TCP) can be avoided.
______________________________
Example ‘A’: 1 x MJPG-IP-cam (AXIS):
ffmpeg.exe -use_wallclock_as_timestamps 1 -i http://192.168.1.85/mjpg/video.mjpg -target pal-dvd -f rtp rtp://127.0.0.1:8085
Serviio 1.2 accepts ‘rtp://127.0.0.1:8085’ as ‘live stream’.
_______________________________
Example ‘B’: 3 x MJPG-IP-cams (AXIS) (cam ‘…85’ with FFmpeg-based deinterlacing):
ffmpeg.exe -use_wallclock_as_timestamps 1 -i http://192.168.2.83/mjpg/video.mjpg -use_wallclock_as_timestamps 1 -i http://192.168.2.85/mjpg/video.mjpg -use_wallclock_as_timestamps 1 -i http://192.168.2.81/mjpg/video.mjpg -map 0 -target pal-dvd -f rtp rtp://127.0.0.1:8083 -map 1 -filter:v yadif -target pal-dvd -f rtp rtp://127.0.0.1:8085 -map 2 -target pal-dvd -f rtp rtp://127.0.0.1:8081
Serviio 1.2 accepts ‘rtp://127.0.0.1:8081’, ‘rtp://127.0.0.1:8083’ and ‘rtp://127.0.0.1:8085’ as three independent ‘live streams’.
The IP-cams also supply JPG-snapshots on request:
http://192.168.2.83/jpg/image.jpg
But I don’t know how to successfully use this URL as an ‘image online resource’.
Help & improvements are welcome :) …
Return to Feature requests
