[SOLVED] Problem with transcoding *.avi files (highbitrate)
Sergey
Post Sat Jan 12, 2013 7:12 pm
I have a problem with transcoding *.avi files. The files with audio bitrate more then 224 kbit/sec (audio codecs: AC 3 ACM Codec and Lame MP 3) do not trascoded with Serviio. And play not by TV Sony. When bitrate less or = 224 kbit/sec, I have no problem.
Can you help with good advice?
TV Sony Bravia (2011)
NAS Synology 213 DSM 4.1
Serviio PRO 1.1 (Testing)
slyguy42o
Post Mon Jan 14, 2013 5:30 pm
Re: a problem with transcoding *.avi files (high bitrate
I would try to add aBtrate as described here
http://www.serviio.org/index.php?option ... icle&id=24
Sergey
Post Mon Jan 14, 2013 9:17 pm
Unfortunately, І am not programmer. I tried to understand ... but it is very difficult for me. May be can you explain more simply decision?
slyguy42o
Post Mon Jan 14, 2013 11:39 pm
here are a couple of articles that should be able to help
this describes the basic process of editing a profile
http://www.serviio.org/index.php?option ... icle&id=16
this goes through settings you can change for the profile
In short you need to figure out what profile is being used, you can look this up via the status tab in the console
Then you open profiles.xml and find the section that applies and make the change, your final edited line should look something like this.
<Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video" aBitrate="128">
Sergey
Post Wed Jan 16, 2013 6:46 pm
Thank you for advice. I just changed profile and transcoding works.
Users browsing this forum: Majestic-12 [Bot] and 12 guests
