Samsung UE46ES6710, DLNA and 50fps MTS/BDAV/AVC not working
Roettgpa
Post Mon Jan 14, 2013 6:11 pm
Hello!
I have the servio server/console v.1.1 running on a Win7 PC. I stream Audio, Pictures and Video to a Samsung UE46ES6710 via DLNA. All video/sound/image files work fine EXCEPT one specific high def. video format, 1080 50p MTS(details below). Unfortunately this is THE format I used in the past year for my private videos...
Transcoding is enabled on the console and the profile used is "Samsung TV/Player (C/D/E-series).
When I try to play this format on the TV, it displays a "Framerate 50 not supported" error.
So I assume this is a TV set limitation (?) as these video files work fine on my PC.
I was assuming the Transcoding engine of Serviio would convert these files to a lower fps rate if needed based on the profile. But this does not seem to happen.
I tested a similar file (same format, same container) but with 25fps and it worked fine by the way.
Can anybody help me about how I could play these files on the TV? Do I have to create a new "profile"? Any other "trick" I am missing?
The full detail of the video file is shown below and also Attached as text file.
Thanks in advance!!
PS: I tested many DLNA servers over the last weeks and Serviio is definitely the best one! Solving my problem above would make it perfect!
File details:
Complete name : D:\Videos\Test\test mit 50p.MTS
Format : BDAV
Format/Info : Blu-ray Video
File size : 69.5 MiB
Duration : 23s 948ms
Overall bit rate : 24.3 Mbps
Maximum Overall bit rate : 28.0 Mbps
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.2
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=3, N=24
Codec ID : 27
Duration : 23s 480ms
Bit rate mode : Variable
Bit rate : 23.0 Mbps
Maximum bit rate : 26.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.222
Stream size : 64.3 MiB (93%)
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 129
Duration : 23s 552ms
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : -40ms
Stream size : 1.08 MiB (2%)
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Duration : 22s 976ms
test mit 50p txt.txt
(4.84 KiB) Downloaded 648 times
Post Tue Jan 15, 2013 5:17 pm
Re: Samsung UE46ES6710, DLNA and 50fps MTS/BDAV/AVC not work
you can't select files to transcode based on FPS. So you'd have to setup transcoding of all mpegts/h264 files to mpeg2, which will be very CPU intensive (you have HD videos). Try the DirecTV profile if it works.
Roettgpa
Post Tue Jan 15, 2013 8:37 pm
Hi Petr!
Thanks for your answer. Unfortunately the DirectTV Profile also gives me the same error. So I am afraid I will have to "manualy" transcode all fiels with a different program.
Thanks anyway.
