Serviio seems to be using a lot of resources
hexeta
Post Mon Jan 14, 2013 3:36 pm
Currently according to Task Manager it's using 124,000K.
A few minutes ago it was over 140,000K and I'm not using it at all!
Is this normal, as it's crippling my PC, especially when I'm browsing and there is a scan running!
slyguy42o
Post Mon Jan 14, 2013 5:43 pm
Re: Serviio seems to be using a lot of resources
which process are you referring to?
hexeta
Post Mon Jan 14, 2013 5:47 pm
Fortunately, I still have it highlighted!
It's ServiioService, user: System currently settled at around 122,000K
slyguy42o
Post Mon Jan 14, 2013 6:32 pm
I just ran through each of my servers, #1 85mb #2 90mb #3 109mb
So your number doesn't seem too far off from the average usage.. it seems to bounce around a bit but I suspect that depends on what it's doing i.e idle, refreshing library, ect.
hexeta
Post Mon Jan 14, 2013 6:41 pm
Thanks for alaying my fears!
I only noticed because I was working in Internet explorer with about 8/9 tabs open, when my weekly AVG scan started......and I stopped!
That's when I looked at Task Manager to see what was happening and Serviio must have been scurrying around refreshing the library or something, as you said!
So no worrys!
Thanks again. :)
