Help creating a profile for Panasonic BD player DMP-BD85
spectre73
Post Tue Dec 28, 2010 6:19 am
Need help creating a profile for Panasonic BD player DMP-BD85 with hacked firmware so I can play .mkv files
The only profile that works is the DirectTV HD-DVR one with the .mkv files but the image is too streched verticaly and
it cannot play Divx or AVI files and that's with transcoding enabled
It plays .mkv and DIvx files fine on burned CD's
Post Tue Dec 28, 2010 10:15 am
Re: Help creating a profile for Panasonic BD player DMP-BD85
spectre73
Post Tue Dec 28, 2010 11:18 am
Device Spy does not show my bluray player in the list even if I am in my dlna menu in my bluray player
Post Tue Dec 28, 2010 12:42 pm
Looks like it cannot play mkv natively (via DLNA). DirecTV profile transcodes it into mpeg2.
spectre73
Post Tue Dec 28, 2010 1:03 pm
Yeah and when I play the .mkv the image is too wide vertically and sometimes stutters and even stop playing after a while and that's not because of my PC I
have a core 2 duo e6600 with 4 gb ram and win 7 x64
Is there a way to transcode it better ?
Also I cannot pause or fast forward
Post Tue Dec 28, 2010 1:19 pm
you can try enabling detailed log, look for the ffmpeg command it uses for the transcode, execute it manually and see what output file you get. Then we can try changing the parameters of the command to produce a better file.
spectre73
Post Wed Dec 29, 2010 1:24 pm
2010-12-29 06:27:51,508 DEBUG [WebServer] Incoming connection from /192.168.0.22:1485
2010-12-29 06:27:51,512 DEBUG [ResourceTransportRequestHandler] GET /resource/30/MEDIA_ITEM/MPEG_PS_NTSC HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-, HOST: 192.168.0.12:8895, transferMode.dlna.org: Streaming, getcontentFeatures.dlna.org: 1, ]
2010-12-29 06:27:51,513 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.22, Profile=DirecTV HD-DVR'
2010-12-29 06:27:51,513 DEBUG [ResourceTransportRequestHandler] Request for resource 30 and type 'MEDIA_ITEM' received
2010-12-29 06:27:51,514 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 30)
2010-12-29 06:27:51,515 DEBUG [VideoDAOImpl] Reading a Video (id = 30)
2010-12-29 06:27:51,515 DEBUG [VideoDeliveryEngine] Delivering item '30' for client 'IPAddress=/192.168.0.22, Profile=DirecTV HD-DVR'
2010-12-29 06:27:51,515 DEBUG [VideoDeliveryEngine] Delivering file 'tl-polar.mkv' using transcoding
2010-12-29 06:27:51,516 DEBUG [VideoDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.0.22, Profile=DirecTV HD-DVR'
2010-12-29 06:27:51,516 DEBUG [MediaItemDAOImpl] Getting file of media item 30
2010-12-29 06:27:51,518 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode file: C:\FILMS\The.Polar.Express.2004.1080p.BluRay.x264-TiMELORDS\tl-polar\tl-polar.mkv
2010-12-29 06:27:51,518 DEBUG [ProcessExecutor] Starting C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe -threads 1 -i C:\FILMS\The.Polar.Express.2004.1080p.BluRay.x264-TiMELORDS\tl-polar\tl-polar.mkv -y -vcodec mpeg2video -b 8192k -maxrate 8192k -bufsize 5097k -r 24.39 -g 15 -copyts -acodec copy -ac 2 -sn -f vob C:\Windows\TEMP\Serviio\transcoding-temp-30-MPEG2PS.stf
2010-12-29 06:27:52,018 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file tl-polar.mkv: MPEG_PS_PAL
2010-12-29 06:27:52,019 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file tl-polar.mkv: MPEG_PS_NTSC
2010-12-29 06:27:52,019 DEBUG [VideoDeliveryEngine] Sending transcoding stream
2010-12-29 06:27:52,019 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 30) as read
2010-12-29 06:27:52,210 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2010-12-29 06:27:52,212 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 9000000000
2010-12-29 06:27:52,213 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2010-12-29 06:27:52,213 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-12-29 06:27:52,213 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/mpeg, TimeSeekRange.dlna.org: npt=0-5996/5996, Date: Wed, 29 Dec 2010 11:27:52 GMT, Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-12-29 06:27:54,483 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2010-12-29 06:27:54,499 DEBUG [WebServer] Incoming connection from /192.168.0.22:1486
2010-12-29 06:27:54,503 DEBUG [ResourceTransportRequestHandler] GET /resource/30/MEDIA_ITEM/MPEG_PS_NTSC HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-, HOST: 192.168.0.12:8895, transferMode.dlna.org: Streaming, getcontentFeatures.dlna.org: 1, ]
2010-12-29 06:27:54,503 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.22, Profile=DirecTV HD-DVR'
2010-12-29 06:27:54,504 DEBUG [ResourceTransportRequestHandler] Request for resource 30 and type 'MEDIA_ITEM' received
2010-12-29 06:27:54,504 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 30)
2010-12-29 06:27:54,504 DEBUG [VideoDAOImpl] Reading a Video (id = 30)
2010-12-29 06:27:54,505 DEBUG [VideoDeliveryEngine] Delivering item '30' for client 'IPAddress=/192.168.0.22, Profile=DirecTV HD-DVR'
2010-12-29 06:27:54,505 DEBUG [VideoDeliveryEngine] Delivering file 'tl-polar.mkv' using transcoding
2010-12-29 06:27:54,506 DEBUG [VideoDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.0.22, Profile=DirecTV HD-DVR'
2010-12-29 06:27:54,506 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file tl-polar.mkv: MPEG_PS_PAL
2010-12-29 06:27:54,506 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file tl-polar.mkv: MPEG_PS_NTSC
2010-12-29 06:27:54,506 DEBUG [VideoDeliveryEngine] Sending transcoding stream
2010-12-29 06:27:54,506 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 30) as read
2010-12-29 06:27:54,508 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2010-12-29 06:27:54,508 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 9000000000
2010-12-29 06:27:54,508 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2010-12-29 06:27:54,508 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-12-29 06:27:54,508 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/mpeg, TimeSeekRange.dlna.org: npt=0-5996/5996, Date: Wed, 29 Dec 2010 11:27:54 GMT, Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-12-29 06:28:22,578 DEBUG [WebServer] I/O error: Connection reset
2010-12-29 06:29:18,060 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2010-12-29 06:29:29,739 DEBUG [WebServer] Incoming connection from /192.168.0.22:4579
2010-12-29 06:29:29,741 DEBUG [ResourceTransportRequestHandler] GET /resource/30/MEDIA_ITEM/MPEG_PS_NTSC HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=80.152-, HOST: 192.168.0.12:8895, transferMode.dlna.org: Streaming, getcontentFeatures.dlna.org: 1, ]
2010-12-29 06:29:29,742 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.22, Profile=DirecTV HD-DVR'
2010-12-29 06:29:29,742 DEBUG [ResourceTransportRequestHandler] Request for resource 30 and type 'MEDIA_ITEM' received
2010-12-29 06:29:29,742 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 30)
2010-12-29 06:29:29,743 DEBUG [VideoDAOImpl] Reading a Video (id = 30)
2010-12-29 06:29:29,744 DEBUG [VideoDeliveryEngine] Delivering item '30' for client 'IPAddress=/192.168.0.22, Profile=DirecTV HD-DVR'
2010-12-29 06:29:29,744 DEBUG [VideoDeliveryEngine] Delivering file 'tl-polar.mkv' using transcoding
2010-12-29 06:29:29,744 DEBUG [VideoDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.0.22, Profile=DirecTV HD-DVR'
2010-12-29 06:29:29,744 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file tl-polar.mkv: MPEG_PS_PAL
2010-12-29 06:29:29,744 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file tl-polar.mkv: MPEG_PS_NTSC
2010-12-29 06:29:29,744 DEBUG [VideoDeliveryEngine] Sending transcoding stream
2010-12-29 06:29:29,745 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 3644237638
2010-12-29 06:29:29,745 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2010-12-29 06:29:29,745 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-12-29 06:29:29,745 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/mpeg, TimeSeekRange.dlna.org: npt=80-5996/5996, Date: Wed, 29 Dec 2010 11:29:29 GMT, Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-12-29 06:29:33,217 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
spectre73
Post Thu Dec 30, 2010 12:13 am
What are the commands I can use with ffmpeg and where do I put them so serviio use them ?
Post Thu Dec 30, 2010 7:44 pm
in the above, this for example:
spectre73
Post Thu Dec 30, 2010 11:44 pm
What do I do with the resulting file ? Serviio will still use the same old command so where do I tell serviio to use another ffmpeg command ?
your not very helpful with your short responses
Post Fri Dec 31, 2010 5:04 pm
Use something like this to create c:\file.mpg:
C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe -threads 1 -i C:\FILMS\The.Polar.Express.2004.1080p.BluRay.x264-TiMELORDS\tl-polar\tl-polar.mkv -y -vcodec mpeg2video -b 8192k -maxrate 8192k -bufsize 5097k -r 24.39 -g 15 -copyts -acodec copy -ac 2 -sn -f vob C:\file.mpg
We cannot tell Serviio to change the ffmpeg command now, but we could work out what needs to be done for a next version.
sorry mate, I'm on my holidays and I'm stealing time I'd rather spend somewhere else than on the forum.. also the connection here is crap so it takes me 2 hours to go through all the new posts
spectre73
Post Fri Dec 31, 2010 6:27 pm
what do I do with this file ? try to play it with my bluray player through dlna ?
can't you just change internet provider ?
scrambler
Post Fri Dec 31, 2010 6:36 pm
You are being seriously rude spectre73.
Zip is doing an amazing job with this FREEware developping and supporting users all by himself you could be a little less agressive...
Zip, you should enjoy your vacation, just post "AWAY until xxx " at the top of the forum, and we will help each other as much as we can until you are back :)
Thanks for the great work man!
Post Fri Dec 31, 2010 8:00 pm
Yes, or on your PC to check if it has the proper aspect ratio and whatever you need.
I'm on HOLIDAYS, at a mountain cottage, stealing a neighbour's unsecured wi-fi connection, so no
spectre73
Post Sat Jan 01, 2011 3:24 am
It gives me alot of errors:
[vob @ 03030050]buffer underflow i=1 bufi=2550 size=2560
[vob @ 03030050]buffer underflow i=1 bufi=2390 size=2560
Last message repeated 8 times
[vob @ 03030050]packet too large, ignoring buffer limits to mux it
[vob @ 03030050]buffer underflow i=1 bufi=2230 size=2560
Last message repeated 9 times
frame= 7798 fps= 26 q=2.0 size= 187372kB time=324.88 bitrate=4724.7kbits/s dup=
[vob @ 03030050]buffer underflow i=1 bufi=2070 size=2560
[vob @ 03030050]buffer underflow i=1 bufi=2455 size=2560
[vob @ 03030050]buffer underflow i=1 bufi=2295 size=2560
[vob @ 03030050]buffer underflow i=1 bufi=2135 size=2560
[vob @ 03030050]buffer underflow i=1 bufi=2502 size=2560
[vob @ 03030050]buffer underflow i=1 bufi=2342 size=2560
[vob @ 03030050]buffer underflow i=1 bufi=2182 size=2560
[vob @ 03030050]buffer underflow i=1 bufi=2407 size=2560
frame= 7800 fps= 26 q=2.0 Lsize= 187486kB time=324.96 bitrate=4726.4kbits/s dup
=7 drop=0
video:159669kB audio:25402kB global headers:0kB muxing overhead 1.304804%
Post Sat Jan 01, 2011 5:56 pm
OK, but did it produce c:\file.mpg ? Can you play that file in a player on PC?
spectre73
Post Sat Jan 01, 2011 9:21 pm
yes and the aspect ratio seems good on the pc so maybe my bd player needs a special command for the aspect ratio and for the pause and play and also it stops playing sometimes
Post Sat Jan 01, 2011 10:09 pm
can you now add this file into Serviio's library and play that (without transcoding) to check that the file has wrong aspect ratio?
spectre73
Post Sun Jan 02, 2011 2:28 am
I tried adding it to the library has FILE.MPG and it was grayed out so I added mpeg in the matches container function and was able
to play it but with same results of wrong aspect ratio
I tried forcing my bd player to display in 4:3 and played the polar express in mkv and the top and bottom
black bars where there buy the aspect ratio was still wrong even if I tried 16:9 and 16:9 full
Also I have to switch my sound settings in the bluray player from bitstream to pcm or there is no sound and some mkv
files stutters alot and still no pause or fast forward or the file just stops and I have to press stop
spectre73
Post Fri Jan 07, 2011 2:13 am
will all that be fixed in next release and when will that be ?
Return to Panasonic
