Disconnect
peterpm
Post Tue Jan 15, 2013 9:45 am
Disconnect
I run serviio 1.0.1 and Samsung UES6300.
I have a problem with disconnect.
1. When some file/stream does not play for some reason, e.g ffmpeg returns error 137 and serviio returns error 500 to Samsung Samsung disconnect and serviio disapperas for 15-20 seconds.
is there a way to change this behaviour ? Just for example to say , cannot play this file, but not throw me out ? Is there some workaround ?
2. I installed a few plugins e.g youtubetop100 & reuters. Clips play just fine. However when a clip finish ffmpeg returns 137 and I go in the above described case and I am kicked out.
Any ideas how can I resolve the issue ?
Thanks,
Peter
Post Tue Jan 15, 2013 6:06 pm
Re: Disconnect
if you are on Linux, make sure to install the latest FFmpeg
peterpm
Post Tue Jan 15, 2013 6:12 pm
Re: Disconnect
I am on FreeBSdD does it look ok ?
root@serviio101:/ # ffmpeg1
ffmpeg version 1.0.1 Copyright (c) 2000-2012 the FFmpeg developers
built on Jan 6 2013 17:35:51 with gcc 4.2.1 (GCC) 20070831 patched [FreeBSD]
configuration: --prefix=/usr/local --mandir=/usr/local/man --incdir=/usr/local/include/ffmpeg1 --libdir=/usr/local/lib/ffmpeg1 --shlibdir=/usr/local/lib/ffmpeg1 --datadir=/usr/local/share/ffmpeg1 --build-suffix=1 --progs-suffix=1 --enable-shared --enable-gpl --enable-postproc --enable-avfilter --enable-pthreads --enable-memalign-hack --disable-libstagefright-h264 --disable-libutvideo --cc=cc --extra-cflags='-msse -I/usr/local/include/vorbis -I/usr/local/include' --extra-ldflags='-L/usr/local/lib ' --extra-libs=-pthread --disable-debug --enable-libaacplus --disable-indev=alsa --disable-outdev=alsa --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libass --enable-libcdio --disable-libcelt --enable-libfaac --enable-libfdk-aac --enable-fontconfig --enable-libfreetype --enable-frei0r --enable-gnutls --disable-libgsm --enable-libmp3lame --enable-libbluray --disable-libv4l2 --disable-libmodplug --disable-openal --enable-libopencv --enable-libopenjpeg --disable-libpulse --enable-librtmp --enable-libsc libavutil 51. 73.101 / 51. 73.101
libavcodec 54. 59.100 / 54. 59.100
libavformat 54. 29.104 / 54. 29.104
libavdevice 54. 2.101 / 54. 2.101
libavfilter 3. 17.100 / 3. 17.100
libswscale 2. 1.101 / 2. 1.101
Use -h to get full help or, even better, run 'man ffmpeg'
peterpm
Post Tue Jan 15, 2013 11:07 pm
Re: Disconnect
I actually found a thread for my exact problem:
viewtopic.php?f=10&t=7854
is there a solution ? Or still serviio + Samsung + online content - mission impossible ?
peterpm
Post Wed Jan 16, 2013 9:10 am
Re: Disconnect
This file:
root@serviio101:/usr/local/etc/serviio-1.0.1/log # ffmpeg1 -i /var/winshare/unsorted/vreme-2013-01-15_1.flv
built on Jan 15 2013 23:50:01 with gcc 4.2.1 (GCC) 20070831 patched [FreeBSD]
configuration: --enable-x11grab --prefix=/usr/local --mandir=/usr/local/man --incdir=/usr/local/include/ffmpeg1 --libdir=/usr/local/lib/ffmpeg1 --shlibdir=/usr/local/lib/ffmpeg1 --datadir=/usr/local/share/ffmpeg1 --build-suffix=1 --progs-suffix=1 --enable-shared --enable-gpl --enable-postproc --enable-avfilter --enable-pthreads --enable-memalign-hack --disable-libstagefright-h264 --disable-libutvideo --cc=cc --extra-cflags='-msse -I/usr/local/include/vorbis -I/usr/local/include' --extra-ldflags='-L/usr/local/lib ' --extra-libs=-pthread --disable-debug --enable-libaacplus --disable-indev=alsa --disable-outdev=alsa --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libass --enable-libcdio --disable-libcelt --enable-libfaac --enable-libfdk-aac --enable-fontconfig --enable-libfreetype --enable-frei0r --enable-gnutls --disable-libgsm --enable-libmp3lame --enable-libbluray --enable-libv4l2 --disable-libmodplug --enable-openal --enable-libopencv --enable-libopenjpeg --enable-libpulse --enable-librtmp libavutil 51. 73.101 / 51. 73.101
Input #0, flv, from '/var/winshare/unsorted/vreme-2013-01-15_1.flv':
metadatacreator : Yet Another Metadata Injector for FLV - Version 1.8
hasKeyframes : true
hasVideo : true
hasAudio : true
hasMetadata : true
canSeekToEnd : false
datasize : 25333216
videosize : 23738484
audiosize : 1548404
lasttimestamp : 183
lastkeyframetimestamp: 183
lastkeyframelocation: 25296948
Duration: 00:03:03.01, start: 0.000000, bitrate: 1107 kb/s
Stream #0:0: Video: flv1, yuv420p, 720x576, 1035 kb/s, 25 tbr, 1k tbn, 1k tbc
Stream #0:1: Audio: mp3, 22050 Hz, stereo, s16, 64 kb/s
Does not display connect duration and disconnect 1 minute before its end - BOTH when served ONLINE and from the local filesystem.
It is not just one file - I have plenty of like this which does exactly the same: wrong duartion, then disconnect around 1 - 1.5 minutes before end of video.
On Samsung E series...
peterpm
Post Thu Jan 17, 2013 10:24 am
Re: Disconnect
More information:
ALL files that serviio transcodes show duration of 5 hours 32 minutes and 16 seconds(or very similar).
However:
The fisrt time it plays serviio disconnects around 1 minutes before end. Although I see in logs - trans code succesffull/.
Second time I play, looks like already transcoded, reports duration of 23 seconds(always)(normal duration is around 3 minutes) but file PLAYS like charm, no disconnectect or anything.
Looks like some problem between serviio and samsung. any ideas ?
Post Thu Jan 17, 2013 2:51 pm
Re: Disconnect
samsung ignores the duration that Serviio sends and displays one based on a fake file size. Not sure why it disconnects early though.
peterpm
Post Fri Jan 18, 2013 6:21 am
Re: Disconnect
Hi Petr,
I adore Serviio and will contiue use it. However I tried "wild media server". It cannot compare with Serviio - Serviio is much better, but strangely timing works VERY Welll with Samsung and transcoding with same files. Maybe you can check how they do it and make a patch for Serviio 1.2 ?
Thanks,
Peter
Post Fri Jan 18, 2013 4:02 pm
Re: Disconnect
Do you mean it also shows the right duration in WMS?
peterpm
Post Fri Jan 18, 2013 4:06 pm
Re: Disconnect
Yes right duration on WMS 1.59.2 on windows 7 64 bit.
Post Sat Jan 19, 2013 4:41 pm
Re: Disconnect
Try to remove both lines that start with
<Matches container="flv"
from your profiles.xml C/D/E profile
peterpm
Post Sat Jan 19, 2013 6:56 pm
Re: Disconnect
If I do this I get video codec FLV1 not supported..
