CBS.com (US Only)
josiok
Post Thu Oct 11, 2012 10:15 pm
Re: CBS.com (US Only)
OK- it's really quiet here! Let me try another question- Is anyone else having trouble with the CBS feed? Or is it just me?
George_L
Post Thu Oct 11, 2012 11:55 pm
josiok wrote:OK- it's really quiet here! Let me try another question- Is anyone else having trouble with the CBS feed? Or is it just me?
I am accessing about 4 CBS shows and all are currently working fine. Be sure you are using the lastest plug in shown in the 1st comments section
mikeyboyuk
Post Sun Oct 14, 2012 3:35 pm
It looks like some of the news & current affairs programmes are now being made availalbe via the http://www.cbsnews.com/ site, rather than the http://www.cbs.com/ site.
So, for programmes like 60 Minutes or The CBS Evening News, a new plug-in is needed.
The feed I was using to get The CBS Evening News (via the http://www.cbsnews.com/ site) did work with the plug-in from this post, but the feed is no longer being updated by CBS, as they are obviously pushing this kind of content through their http://www.cbsnews.com/ site now.
If someone in the know could create a plug-in for the http://www.cbsnews.com/ site, that would be greatly appreciated.
Cheers
lushess255
Post Tue Nov 13, 2012 5:59 am
I can watch CBS shows on a Panasonic TV using this plugin, but the audio goes out periodically (about every 45 seconds in one case). In order to get the audio back, I have to rewind a little bit and start playing again. Unfortunately, I have to do this repeatedly.
Any idea why the audio is going out again and again?
olfudydudy
Post Mon Dec 10, 2012 7:12 pm
I am new to Serviio and am running version 1.0.1 successfully. I have also downloaded this plugin and have changed it to show NCIS successfully. What I would like is to modify it to be able to select from several shows on CBS. Specifically, NCIS, NCIS: Los Anglese, and Hawaii Five O. Is there a way to do this.
DrJay
Post Tue Dec 11, 2012 5:03 pm
mikeyboyuk wrote:It looks like some of the news & current affairs programmes are now being made availalbe via the http://www.cbsnews.com/ site, rather than the http://www.cbs.com/ site.
Cheers
I have also posted a request for a cbsnews.com plug-in. Is there any possibility of getting a groovy for this in the near future?
olfudydudy
Post Thu Dec 13, 2012 7:09 pm
Does that mean that you can select one of the 4 shows on your TV? How do you change the CBS.groovy plugin to be able to select more than one show? I am new to Serviio and the plugins. Any help would be appreciated.
DrJay
Post Mon Jan 14, 2013 1:44 am
You have to add/create a new online source for each program in your library. Example below:
http://www.cbs.com/shows/csi/video (for CSI - Crime Scene Investigation)
http://www.cbs.com/shows/blue_bloods/video (for Blue Bloods)
http://www.cbs.com/shows/elementary/video (For Elementary)
You don't have to change the groovy. Hope this helps.
J
lexluthor
Post Wed Jan 16, 2013 12:22 pm
What's the stream for Survivor?
http://www.cbs.com/shows/survivor/video doesn't work.
Edit: Nevermind. Had to do it as a web resource. I guess I have to figure out when to do it as an online feed and when as a web resources.
WildRushSykes
Post Wed Jan 16, 2013 12:43 pm
mike metros first post clearly states it has to be configured as a web resource :D
Xmantium
Post Sat Feb 09, 2013 10:03 pm
To make things easier, all shows with full episodes have been added to ServiiDB
Seems like some shows dont have full episodes such as 2 Broke Girls
Use the Apps in my forum signature to add these shows to your Online Sources without the need for worrying about web recourse types ;)
headputty
Post Fri Apr 05, 2013 12:04 am
The CBS plugin is currently broken. Any possibility of a fix?
See:
viewtopic.php?f=5&t=9843
DrJay
Post Fri Apr 05, 2013 9:44 pm
Yes, the CBS.com plug-in is still not working. Any ideas on what may be the problem? It has been broken since the beginning of April.
rss_newb
Post Tue Apr 09, 2013 3:46 am
DrJay wrote:Yes, the CBS.com plug-in is still not working. Any ideas on what may be the problem? It has been broken since the beginning of April.
I am also having the same issue, yeah since the beginning of April the plugin stopped working. It doesn't appear that the videos moved to another location breaking the link. I am using the latest serviio package 1.2.1 as well as the latest cbs plugin. Provided is the error message in the logs
2013-04-07 23:27:57,343 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (CBS.com): index is out of range 0..-1 (index = 0)
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:171)
Caused by: java.lang.IndexOutOfBoundsException: index is out of range 0..-1 (index = 0)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.getAt(DefaultGroovyMethods.java:6202)
at org.codehaus.groovy.runtime.dgm$310.invoke(Unknown Source)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:271)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:53)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
at CBS.extractItems(CBS.groovy:53)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Xmantium
Post Wed Apr 10, 2013 10:16 pm
Anyone up for fixing issue, i was enjoying 48 Hours (works in the UK natively without DNS tricks)
mike_metro
Post Fri Apr 12, 2013 10:18 pm
Xmantium wrote:Anyone up for fixing issue, i was enjoying 48 Hours (works in the UK natively without DNS tricks)
Work has been crazy. I'll take a look when have some time.
DrJay
Post Fri Apr 12, 2013 11:00 pm
Thanks, Mike. We appreciate anything you can do.
iheartninjas
Post Sat Apr 13, 2013 8:40 am
I'm crossing my fingers on this as well. gratitude to those trying!
leo1981
Post Sat Apr 13, 2013 5:48 pm
I am new to plugin development.
I modified the original CBS.groovy and I got it to work.
Thanks,
Leonardo
UPDATE:
Please download the new version here: viewtopic.php?f=20&t=5401&start=40#p68080
DrJay
Post Sat Apr 13, 2013 6:57 pm
leo1981 wrote:Hi,
Thanks,
Leonardo
Thanks, Leonardo. I'll give it a try later today. BTW, my great-grandfather's name was Leonardo.
Jay
Return to Available plugins
Users browsing this forum: Baidu [Spider] and 5 guests
