audio out of sync when transcoding..
thenamelessthing
Post Fri Jan 11, 2013 3:31 am
Hi all, when transcoding is used. The audio became out of sync after few second. The profile used is the Panasonic Viera E/S/ST/VT (2011).
Here is the command used by ffmpeg:
2013-01-10 22:20:04,413 DEBUG [ProcessExecutor] Starting ffmpeg -threads auto -i /data/Teleseries/Jekyll.S01.FRENCH.PDTV.XViD-NYJ/Jekyll.S01E05.FRENCH.PDTV.XViD-NYJ/Jekyll.S01E05.FRENCH.PDTV.XViD-NYJ.avi -y -copyts -c:v mpeg2video -qscale:v 3 -r 25 -g 15 -c:a ac3 -b:a 128k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts /tmp/Serviio/transcoding-temp-6434-viera2011-ORIGINAL.stf
I also try with Best video quality and downmix to stereo without any success. I also select to use 4 core on the 6 my cpu have. And I have 2.4gb of free ram when transcoding and enough space disk.
Here is the info if the file played:
media@mediastation:/data/Teleseries/Jekyll.S01.FRENCH.PDTV.XViD-NYJ/Jekyll.S01E05.FRENCH.PDTV.XViD-NYJ$ ffmpeg -i Jekyll.S01E05.FRENCH.PDTV.XViD-NYJ.avi
built on Dec 27 2012 00:44:49 with gcc 4.6.3
configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-libvpx --enable-librtmp --enable-libxvid
Input #0, avi, from 'Jekyll.S01E05.FRENCH.PDTV.XViD-NYJ.avi':
encoder : MediaCoder 0.6
Duration: 00:51:30.08, start: 0.000000, bitrate: 941 kb/s
Stream #0:0: Video: mpeg4 (Simple Profile) (XVID / 0x44495658), yuv420p, 640x352 [SAR 183:178 DAR 1830:979], SAR 11264:10955 DAR 4096:2191, 25 tbr, 25 tbn, 25 tbc
Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16, 128 kb/s
Thanks for your help!
Last edited by thenamelessthing on Tue Jan 15, 2013 3:35 am, edited 1 time in total.
My Setup : BDT220 Panasonic Bluray player, TC-L55ET5 and TC-L42ET5 Panasonic TV. My home media server run Serviio 1.4.2 Pro under GNU/Linux Ubuntu 14.04 LTS server x64 and the hardware is Amd 1045t Phenom II X6, 6Gb DDR3 1333 mhz on SSD and data on soft raid 5 (3x1tb).
Post Sat Jan 12, 2013 5:55 pm
Re: audio out of sync when transcoding..
It you run the ffmpeg command and rename the .stf file to .g, add it to your library, does it play correctly?
thenamelessthing
Post Sat Jan 12, 2013 9:50 pm
Sorry for this "noob" question, but how I add it to the library? And what happen by only renaming .stf file to .g ? ( i want understand how serviio works in the background)
Post Sun Jan 13, 2013 3:56 pm
sorry, was a typo.. rename it to .mpg and copy to a shared folder, then play (without transcoding)
thenamelessthing
Post Sun Jan 13, 2013 9:56 pm
I have do what you have asked. When I play the mpg on my computer it work fine. On tv I always have the audio sync problem. ;-(
EDIT: even .mkv have the audio sync problem!!!!!!!!!
thenamelessthing
Post Tue Jan 15, 2013 3:48 am
So, I think with this info maybe it's not a transcoding problem...
thenamelessthing
Post Tue Jan 15, 2013 4:30 am
Maybe the router is my problem? ( linksys wrt54gl ) But the load seem to be okay..
Post Tue Jan 15, 2013 5:19 pm
so the .mpg file, when played on TV has the problem, right?
Try this:
ffmpeg -threads auto -i "/data/Teleseries/Jekyll.S01.FRENCH.PDTV.XViD-NYJ/Jekyll.S01E05.FRENCH.PDTV.XViD-NYJ/Jekyll.S01E05.FRENCH.PDTV.XViD-NYJ.avi" -y -copyts -async 1 -c:v mpeg2video -qscale:v 3 -r 25 -g 15 -c:a ac3 -b:a 128k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts /tmp/Serviio/test.mpg
Then try to play test.mpg on your TV.
thenamelessthing
Post Tue Jan 15, 2013 5:23 pm
Yes the fila has the problem on tv.
Ok I will do it this evening...
Thanks you for your help.
thenamelessthing
Post Wed Jan 16, 2013 2:36 am
I have do the test you suggest. The problem is still here! I also tried to put the file on an usb stick and play it directly on the tv. Same problem occur. With these test at least I can say it's not a network problem!
Post Wed Jan 16, 2013 1:41 pm
does it play out-of-sync in VLC?
thenamelessthing
Post Wed Jan 16, 2013 4:18 pm
I have checked this yesterday with mplayer (ubuntu) and the audio was ok. I can check this evening in vlc if it's really important.
Post Wed Jan 16, 2013 5:01 pm
do ll your files have this problem? It looks like a problem of the TV. Do you have the latest firmware?
thenamelessthing
Post Wed Jan 16, 2013 6:11 pm
I will check this evening if a new firmware is available I will try to contact Panasonic too . I have updated the firmware in november. It's not ALL files who have the problem but most of all. If I remember correctly (i'm not at home) I have mkv files in 720p who work fine. The problem seem to affect some avi file (HD or not) who are transcoded and some mkv (1080p) who are not transcoded.
To be continued
thenamelessthing
Post Thu Jan 17, 2013 2:44 am
Shit happen! It really look a tv problem!
I have some file who play correctly like:
media@mediastation:/data/Dessins_Animes/Young.Justice.Saison.01.FRENCH.HDTV.XViD-KENT/Young.Justice.S01E01.FRENCH.DVDRIP.XviD-KENT$ ffmpeg -i Young.Justice.S01E01.FRENCH.DVDRIP.XviD-KENT.avi
[avi @ 0x1fbb160] non-interleaved AVI
[mpeg4 @ 0x1fc15c0] Invalid and inefficient vfw-avi packed B frames detected
Input #0, avi, from 'Young.Justice.S01E01.FRENCH.DVDRIP.XviD-KENT.avi':
encoder : FairUse Wizard - http://fairusewizard.com
Duration: 00:22:40.44, start: 0.000000, bitrate: 1077 kb/s
Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 624x352 [SAR 1:1 DAR 39:22], 23.98 tbr, 23.98 tbn, 23.98 tbc
and :
Input #0, matroska,webm, from 'Transformers.Prime.S01E01.Darkness.Rising.Part.1.FR.LD.720p.WEB.DL.AC3.H264.REPACK.splanck-BaLLanTeAm.mkv':
title : Transformers.Prime.S01E01.Darkness.Rising.Part.1.720p.WEB.DL.DD5.1.AAC2.0.H264.BluZilla.mkv 6089
creation_time : 2011-11-20 19:37:32
Duration: 00:21:06.56, start: 0.000000, bitrate: 4801 kb/s
Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 1k tbn, 2k tbc (default)
Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), s16, 448 kb/s (default)
Versus these files who have the out of sync audio problem:
media@mediastation:/data/Films/HD$ ffmpeg -i The.Expendables.2.2012.FRENCH.1080p.BluRay.x264.AC3.DECISION.mkv
Input #0, matroska,webm, from 'The.Expendables.2.2012.FRENCH.1080p.BluRay.x264.AC3.DECISION.mkv':
creation_time : 2012-11-17 18:49:58
Duration: 01:42:18.30, start: 0.000000, bitrate: 11397 kb/s
Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
title : The Expendables 2 2012 FRENCH 1080p BluRay x264 AC3-DECISION
Stream #0:1(fre): Audio: ac3, 48000 Hz, 5.1(side), s16, 384 kb/s (default) (forced)
Stream #0:2(fre): Subtitle: text (default) (forced)
title : force
and
media@mediastation:/data/Films/HD/Looper.2012.FRENCH.1080p.BluRay.x264-AUTOPSiEHD$ ffmpeg -i Looper.2012.FRENCH.1080p.BluRay.x264-AUTOPSiEHD.mkv
[matroska,webm @ 0x2694160] max_analyze_duration 5000000 reached at 5005000
Guessed Channel Layout for Input Stream #0.1 : 5.1
Input #0, matroska,webm, from 'Looper.2012.FRENCH.1080p.BluRay.x264-AUTOPSiEHD.mkv':
creation_time : 2012-12-22 19:13:44
Duration: 01:58:53.12, start: 0.000000, bitrate: 13044 kb/s
Stream #0:0: Video: h264 (High), yuv420p, 1920x816, SAR 1:1 DAR 40:17, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
Stream #0:1: Audio: ac3, 48000 Hz, 5.1, s16 (default)
title : FRENCH AC3 5.1 @ 448 Kbps
and
media@mediastation:/data/Teleseries/Jekyll.S01.FRENCH.PDTV.XViD-NYJ/Jekyll.S01E01.FRENCH.PDTV.XViD-NYJ$ ffmpeg -i Jekyll.S01E01.FRENCH.PDTV.XViD-NYJ.avi
Input #0, avi, from 'Jekyll.S01E01.FRENCH.PDTV.XViD-NYJ.avi':
encoder : Lavf52.18.0
Duration: 00:51:51.88, start: 0.000000, bitrate: 1479 kb/s
Stream #0:0: Video: mpeg4 (Simple Profile) (XVID / 0x44495658), yuv420p, 640x352 [SAR 11:15 DAR 4:3], 25 tbr, 25 tbn, 25 tbc
Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16, 194 kb/s
I have contacted Panasonic, the first thing they suggest is the Factory reset the TV. Done without any good result.
I can confirm i'm at the latest firmware version.
Any other advices? (transcoding into a file format who play fine like file at the top of this post??)
Post Thu Jan 17, 2013 9:46 am
Did you try disabling transcoding?
thenamelessthing
Post Thu Jan 17, 2013 1:35 pm
I will try this this evening.. (disabling transcoding)
I have obtained the supported file format supported by the tv:
Media Player Supported Formats AVCHD 3D / Progressive, SD-VIDEO / MotionJPEG (Lumix) / MKV / MP4 / MOV / M4v / FLV / 3GPP / VRO / VOB / TS / PS, MP3 / AAC / FLAC, JPEG / MPO
Do you know if AC3 and AAC is the same thing?
Post Thu Jan 17, 2013 2:01 pm
they are not
thenamelessthing
Post Fri Jan 18, 2013 1:29 am
With transcoding disable same problem. I have open a ticket on panasonic. 2-4 working day before having news from technical support (level 2). I think it's a bug in her firmware. on my 2 tv I have the same problem and they are from the same series... I will poste the panasonic answer/solution when I obtain it.
Thanks you zip for helping me to debug this weird case!
thenamelessthing
Post Wed Jan 23, 2013 2:24 am
Hi, I think I have found something!
I have used handbreak to convert one of my file we have use on our test (. And I have re-encoded the audio in the same format but with a little change. The original audio used was AAC (faac) and I changed it for: AAC (ffmpeg) and the mpeg to mkv and the audio are now sync!! maybe this info can us to solve the problem?
Here is the result of the file who play fine now...
Input #0, matroska,webm, from 'test2.mkv':
Duration: 00:51:30.00, start: 0.000000, bitrate: 766 kb/s
Stream #0:0(eng): Video: h264 (Main), yuv420p, 640x352 [SAR 1:1 DAR 20:11], 25 fps, 25 tbr, 1k tbn, 180k tbc (default)
Stream #0:1: Audio: aac, 48000 Hz, stereo, s16 (default)
Users browsing this forum: capitain_jack and 29 guests
