Sony 2011 - MKV - wrong aspect and weired bricks
soundcheck
Post Fri Jan 18, 2013 3:21 pm
Hi.
I tried to play an mkv the other day on my Bravia (2011 Profile). I think it worked on Serviio 1.0.
Now on 1.1 (Linux) it plays, but the aspect ratio looks weired ( 50% of the screen height) and on the right side I see colored bricks.
Sound is OK.
Any hint is appreciated.
Below the ffmpeg -i
Cheers
  libpostproc    52.  2.100 / 52.  2.100
Input #0, matroska,webm, from 'test.mkv':
    creation_time   : 1970-01-01 00:00:02
  Duration: 01:30:40.47, start: 0.000000, bitrate: 6638 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x1088, SAR 1:1 DAR 30:17
 23.97 fps, 23.97 tbr, 1k tbn, 180k tbc (default)
    Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s (default)
Post Fri Jan 18, 2013 3:39 pm
Re: Sony 2011 - MKV - wrong aspect and weired bricks
soundcheck wrote:...but the aspect ratio looks weired ( 50% of the screen height) and on the right side I see colored bricks.
colored bricks ?? could you explain?
Could you also check that you use an updated ffmpeg : http://wiki.serviio.org/doku.php?id=build_ffmpeg_linux
What is your region, US, UK ?
What is the profile selected on serviio console ?
soundcheck
Post Fri Jan 18, 2013 3:54 pm
its non-us and sony 2011
i use ffmpeg git, roughly 3 weeks old
Post Fri Jan 18, 2013 4:48 pm
Oh I see, the h264 video stream is remuxed and delivered in native to the Sony device, but as you cann see the original DAR is not compliant :
1920x1088 => The compliant is 1920x1080
Post Fri Jan 18, 2013 4:50 pm
soundcheck
Post Fri Jan 18, 2013 5:05 pm
How do i force transcoding to 1920*1080 ?
If the dar is not compliant with the chosen profile, Serviio shouldn't deliver the native format!? Bug??
There seems to be a hole in the rule set.
soundcheck
Post Sat Jan 19, 2013 9:41 am
I think it is about this:
viewtopic.php?f=5&t=5403
Post Sat Jan 19, 2013 9:51 am
There were an old ticket about that : https://bitbucket.org/xnejp03/serviio/i ... resolution
You can add comment on it.
You can also create a custom profile to transcode h264 video that you'll manually select on serviio console for files not compliant.
