Toshiba 32RL938G
Nushu
Post Mon Dec 17, 2012 9:21 am
Toshiba 32RL938G
Hi, I have the old problem with "media playback error" on dlna server over my Toshiba 32RL938G
I tried several DLNA server, my tv it seeing all the files but it can't play it. (on picture it has even thumbnails visible but also no play on it)
Please help me.
I attached the DLNA Test Certificate
.....no one can help me?
REG50126845.pdf
(142.38 KiB) Downloaded 2447 times
slyguy42o
Post Tue Jan 08, 2013 7:08 pm
Re: Toshiba 32RL938G
post your logs
viewtopic.php?f=5&t=7
also what profile is selected on the status tab?
Nushu
Post Sun Jan 13, 2013 8:15 am
Profile is Toshiba regza...
(295.1 KiB) Downloaded 2170 times
Nushu
Post Sat Jan 19, 2013 8:29 am
Thank you for nothing serviio.......try another dlna server.
Why exist this forum?
Erase it!!!
Bye
Post Thu Jan 24, 2013 3:18 pm
hmmm, maybe because you didn't provide the info we requested?
Nushu
Post Wed Jan 30, 2013 7:44 am
Nushu wrote:Profile is Toshiba regza...
and also i uploaded the log file......this mean i didn't provide the information?
Post Sun Feb 17, 2013 4:16 pm
it's not the detailed logs, see the link
ulo
Post Sat May 18, 2013 11:59 am
Hello, i have a problem with my TV Toshiba 32RL938G too - opposite to post above i cannot see my list of any media (video and pictures) what i shared in Serviio.
In Serviio Console (v1.2.1) is TV active (green icon and correct ip address with correct name RL938 - i can ping on it). My DLNA profile is Toshiba REGZA and transcoding is enabled (but even when i transcoding disable or use Generic DLNA profile the list of media doesnt appear too).
Please could you advise me what can i try to do for using Serviio with this TV? Thanks a lot.
List of netstat command:
tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN
tcp        0      0 127.0.1.1:44331         0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN
tcp        0      0 127.0.1.1:44332         0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:7634          0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:8895            0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:23423           0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:23424           0.0.0.0:*               LISTEN
tcp6       0      0 :::139                  :::*                    LISTEN
tcp6       0      0 :::80                   :::*                    LISTEN
tcp6       0      0 :::22                   :::*                    LISTEN
tcp6       0      0 ::1:631                 :::*                    LISTEN
tcp6       0      0 :::445                  :::*                    LISTEN
Sink log and the detailed Serviio log are attached (with enabled DEBUG in log4j.xml).
OS: Linux Mint 13
pc5dczc_detailed.log
Detailed log (enabled DEBUG in log4j.xml)
(280.81 KiB) Downloaded 2077 times
sink_Toshiba_32RL938G.txt
Sink log from IntelTool UPnP Tech.
(2.51 KiB) Downloaded 2101 times
Post Wed May 22, 2013 1:50 pm
So your server is 10.0.0.2 and the TV 10.0.0.5 ?
I can see incoming request from 10.0.0.5, but there is no communication after that - I assume you can't see even the server (let alone it's folders) on the TV?
Looks like a firewall issue, check that you have TCP 8895 open on the PC.
ulo
Post Fri May 24, 2013 5:52 pm
Thank you, now connection is ok and you were right - it was firewall issue and allow incoming 8895/tcp port fixed it.
Return to Toshiba
