Samsung PS51D550C Wont play .mkv and some .avi to my tv
pistolpete
Post Sun Jan 20, 2013 3:59 am
Hi all,
Im only new to serviio at the moment and i must say im loving the software but im having issues with the transcoding of some files.
Im trying to play some .mkv files over my server to my tv and im getting "codec not supported" on my tv. Was wondering what i can do in my profile.xml file or anything to fix this issue or is transcoding only designed for audio ??
any help or profile settings would be great appreciated
cheers
peter
Post Sun Jan 20, 2013 8:04 am
Re: Samsung PS51D550C Wont play .mkv and some .avi to my tv
HowTo: Provide details of a video file that doesn't play : http://wiki.serviio.org/doku.php?id=file_np
pistolpete
Post Sun Jan 20, 2013 10:15 am
Unique ID : 206418978541226701405226076534603823913 (0x9B4AD96444EE2D87A65A890E6870BB29)
Complete name : F:\Movies Blu Ray\Dawn Of The Dead (2004)\Dawn Of The Dead (2004).mkv
Format : Matroska
File size : 7.95 GiB
Duration : 1h 49mn
Overall bit rate : 10.4 Mbps
Movie name : Dawn of the Dead (2004)
Encoded date : UTC 2010-09-30 14:08:54
Writing application : mkvmerge v4.3.0 ('Escape from the Island') built on Sep 5 2010 10:30:51
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Format : AVC
Format profile : High@L5.0
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 49mn
Bit rate : 8 915 Kbps
Width : 1 920 pixels
Height : 816 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.237
Stream size : 6.64 GiB (84%)
Writing library : x264 core 98 r1649 c54c47d
Encoding settings : cabac=1 / ref=9 / deblock=1:-2:-1 / analyse=0x3:0x133 / me=hex / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=4 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=8915 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.50
Language : English
Format : DTS
Codec ID : A_DTS
Duration : 1h 49mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.15 GiB (14%)
Title : Movie Audio Track: DTS 5.1 @ 1.5 Mbps
Language : English
Text #1
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Codec ID/Info : The same subtitle format used on DVDs
Language : English
Text #2
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Language : Thai
Menu
00:00:00.000 : en:A Nice Day
00:04:29.352 : en:Lock All Doors
00:10:38.888 : en:Main Titles
00:13:15.586 : en:Refuge
00:19:43.224 : en:Intruders
00:23:27.281 : en:Cj's Turf
00:26:35.594 : en:S.O.S.
00:33:07.027 : en:No More Room
00:42:28.045 : en:New Arrivals
00:47:35.853 : en:Kill Tucker, Too
00:56:29.511 : en:Sickness Rising
01:01:36.526 : en:Blackout
01:08:48.416 : en:Family Man
01:15:22.643 : en:Taking Action
01:20:17.104 : en:Saving Andy
01:24:15.133 : en:Nicole's Rescue
01:30:03.523 : en:Run!
01:33:27.560 : en:Escape
01:39:47.690 : en:Valor
01:44:36.770 : en:End Titles/Hope
Post Sun Jan 20, 2013 10:38 am
pistolpete wrote:General
Format profile : High@L5.0 => not supported in native format
Muxing mode : Header stripping => not supported in native format
This video stream should be transcoded by serviio/ffmpeg, could you check on detailed logging if this is the case (see signature link) ?
pistolpete
Post Tue Jan 22, 2013 12:03 am
i read your instructions i did that then my serviio came up with erros etc and i had to reinstall software and rebuild database :(
jarkor
Post Fri Jan 25, 2013 4:51 am
Change profil to 4.1 and header in tsmuxer and mkvtoolnix
