TED.com (Web Resource)
qanatoz
Post Wed Apr 04, 2012 3:12 pm
TED.com Web Resource plugin
Source type: Web Resource
Media type: Video
Version: 2.1
Plugin allows to watch custom talks from Ted.com
Release Notes for version 2.0:
  • Fixed fetching talk URL error
  • Added playlist support
  • Added original thumbnail and release date for each talk
Changes for version 2.1:
  • Fixed bug with media extraction
URL example:
Playlist :
To create talks playlist just connect all URLs inline using “;” and set them as "Source URL"
Playlist example:
*Note: The URLs must be configured as a Web Resource.
TED.groovy
TED.com Web Resource plugin v2.1
(4.58 KiB) Downloaded 1767 times
venkatpartha
Post Sun Aug 05, 2012 3:01 pm
Re: TED.com (Web Resource)
I get the following message when I try out this plug-in with this URL http://www.ted.com/talks/taylor_wilson_ ... actor.html or this URL http://www.ted.com/talks/malte_spitz_yo ... ching.html
================[ Error ]==================
2012-08-05 20:30:55,395 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-05 20:30:55,396 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2012-08-05 20:30:55,399 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2012-08-05 20:30:55,399 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 4)
2012-08-05 20:30:57,560 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (TED): index is out of range 0..-1 (index = 0)
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:171)
Caused by: java.lang.IndexOutOfBoundsException: index is out of range 0..-1 (index = 0)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.getAt(DefaultGroovyMethods.java:6202)
at org.codehaus.groovy.runtime.dgm$310.invoke(Unknown Source)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:271)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:53)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
at TED.extractItems(TED.groovy:26)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
at java.util.concurrent.FutureTask.run(FutureTask.java:166)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:636)
====================[ End of Error ]====================
ttguy
Post Sun Sep 09, 2012 1:51 pm
Yes. This plugin is broken. I am seeing if I can fix it.
linux/Humax HDR-3000T
qanatoz
Post Wed Sep 26, 2012 1:02 am
The plugin is fixed.
ttguy
Post Tue Oct 02, 2012 7:00 am
qanatoz wrote:The plugin is fixed.
Awesome. Cool idea about the playlist functionality
venkatpartha
Post Sat Oct 06, 2012 3:31 pm
Hello qanatoz,
Thank you for your update to the TED plugin.
However, I still get the same index out of bounds error when I use this plugin. I am at present using Serviio 1.0. Is this an issue. I will try after upgrading to 1.0.1.
Thanks and regards,
Venkat.
==================[ Error ]======================
2012-10-06 20:55:19,434 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
at java.lang.Thread.run(Thread.java:679)
2012-10-06 20:56:23,043 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
qanatoz
Post Sun Oct 07, 2012 1:06 pm
Hi Venkat,
Can you please share links you are trying to load and you system details (Platform, OS and etc.)?
venkatpartha
Post Sun Oct 21, 2012 3:26 am
Hi qanatoz,
Thank you for your efforts. Your plugin works.
My Serviio details:
Serviio version - 1.0.1
OS - Linux Mint 13 - Cinnamon
Device - Panasonic Viera - P42X30D
Profile - Panasonic Viera With AVI Support
I am now able to see the TED folder with the following videos listed:
1. http://www.ted.com/talks/benjamin_zande ... ssion.html
2. http://www.ted.com/talks/robert_gupta_b ... icine.html
I now face a task of debugging a ffmpeg/avconv issue where mp4 files are not being transcoded.
Regards,
Venkat
qanatoz
Post Sun Jan 20, 2013 10:10 pm
The plugin updated
Xmantium
Post Mon Jan 21, 2013 12:22 am
Hi qanatoz, thanks for the update. Will you be updating the plugins with Plugin versioning?
This way users can check if theres a new plugin update with current 3rd party apps
I read something today that ffmpeg are doing something cool with TED.com - http://ffmpeg.org/ffmpeg-formats.html#tedcaptions
- JSON captions for TED talks decoding support
TED provides video downloads for their talks. Not all of these are available with subtitles and when they are the subtitles are burnt into the video. Now with this new FFmpeg feature you can download the subtitle files and just display them on the fly when playing the video with ffplay:
ffplay ted.mp4 -vf subtitles=ted.json
Think this will fully work with Serviio 1.2 which has subtitles support
qanatoz
Post Mon Jan 21, 2013 11:00 pm
Hi Xmantium,
Yes I will update plugins with this functionality. The getVersion() method come with 1.1 API and I missed it somehow.
This is really interesting thing. Did subtitles support also planned at API level?
Xmantium
Post Tue Jan 22, 2013 12:27 am
I'm not entire sure but zip should answer how subtitles will work with upcoming Serviio... All I know it's gonna be awesome!! :)
Definately think a conference website like this, subtitles will be important for few.
nicksson
Post Tue Jul 02, 2013 1:56 pm
Xmantium wrote: ... Definately think a conference website like this, subtitles will be important for few.
I tried this plugin and yes, it is good and working, but yet no subtitles.
qanatoz, can we have TED subtitles somehow, even "burned" into video?
qanatoz
Post Sat Jul 06, 2013 8:52 am
@nicksson,
Subtitles not supported on level of Serviio plugins API. Once this feature will be added to plugins API I"ll add subtitles support for this plugin.
Namelles_One
Post Fri Apr 17, 2015 7:04 am
Sorry, don't working now(
turquoisesky
Post Sun Apr 19, 2015 10:02 am
I'm waiting for the subtitles :/
freshmelon
Post Mon May 11, 2015 7:34 am
Anything changed in this case?
shine789
Post Sat May 30, 2015 8:48 am
Still no subtitles :/
king990
Post Mon Jun 01, 2015 4:44 pm
Maybe I can make them :)
Return to Available plugins
Users browsing this forum: Google [Bot] and 23 guests
