[SOLVED] Philips NP2500 Streamium (Audio device)
juanito
Post Mon Jan 21, 2013 9:57 am
Hi
A have installed Serviio server on an Ubuntu machine.
It works fine and does all the things I wanted except one thing:
I have a huge collection of bootlegs which are all FLAC files and when I try to play them I get a message on my Philips device : Server not ready. MP3 are played correctly.
If I try the same Flac files on my Iphone using PlugPlayer it works fine.
I have run Intel Upnp spy and you will find the protocol infos in the attached file. I hope this will help.
Should you need any other info's, I will be more than happy to give them 8-)
Thanks in advance
Juanito
np2500.txt
(618 Bytes) Downloaded 1038 times
slyguy42o
Post Mon Jan 21, 2013 4:52 pm
Re: Philips NP2500 Streamium (Audio device)
what profile are you using for this device?
juanito
Post Mon Jan 21, 2013 5:26 pm
I am using the generic Dlna profile
Post Mon Jan 21, 2013 8:31 pm
Your device should support FLAC with http-get:*:audio/x-flac:* mime-type.
The mime-type used by Generic Profile was "audio/flac", so you have to edit a profile to change mime-type.
Could you edit the profile.xml and add this profile section just before the </Profiles> element.
Then restart serviio service or reboot your system and retry by selecting the profile on serviio console.
   <Profile id="PhilipsA" name="Philips NP2500 Streamium (Audio device)" extendsProfileId="1">
      <MediaFormatProfiles>
         <MediaFormatProfile mime-type="audio/x-flac" name="">FLAC</MediaFormatProfile>
      </MediaFormatProfiles>
juanito
Post Mon Jan 21, 2013 8:59 pm
BIIIIIIINNNNNNNGGGGGOOOOOOOOOO ;) :D
Thank you so much .. It works now as I was expected.
This is fantastic !!!
Juanito
Post Mon Jan 21, 2013 9:04 pm
Great !!
With INTEL SPY tools, could you provide the device description xml result.
We could edit the new profile to automatically detect your device and select the proper profile.
juanito
Post Tue Jan 22, 2013 7:42 am
I Will do this tonight
Thanks again.
juanito
Post Tue Jan 22, 2013 6:39 pm
Hi and good evening
Here is the xml file you requested.
If you need something else or want me to test anything, just let me know
All the best
Juanito
PhilipsNP2500.xml
(1.64 KiB) Downloaded 1226 times
Post Tue Jan 22, 2013 7:45 pm
With this following, your device should be automatically detected and the proper profile will be selected:
   <Profile id="PhilipsA" name="Philips NP Streamium (Audio device)" extendsProfileId="1">
      <Detection>
         <UPnPSearch>
            <FriendlyName>Philips NP.*</FriendlyName>
            <Manufacturer>Royal Philips Electronics</Manufacturer>
         </UPnPSearch>
      </Detection>
So now if you have problem with some sample file, please post information about the media, and we will try to modify/update the profile.
juanito
Post Tue Jan 22, 2013 9:01 pm
I have installed this and it works perfectly.
Merciiiiiiii
:D
Juanito
Return to Philips
