Samsung BD-E6500, MPEG4 not supported
rajko
Post Sat Jan 19, 2013 5:08 am
Serviio 1.1
E6500 with the latest updates
Transcoding profile is "Samsung TV/Player (C/D/E Series)"
With some movies I get the "This file format is not supported. Video Codec: MPEG4" error. The files are definitely playable in VLC and MediaBrowser. Any reason why I get this error, then?
Thanks and sorry if this was asked before; I looked but I couldn't find a concrete answer anywhere.
rajko
Post Mon Jan 21, 2013 2:20 pm
Re: Samsung BD-E6500, MPEG4 not supported
Any idea? :?:
slyguy42o
Post Mon Jan 21, 2013 9:08 pm
so everything works except mp4's?
rajko
Post Mon Jan 21, 2013 9:49 pm
Not every MP4. Most of them work. I tested a few other servers (mezzmo, wild media) and those files play quite fine. I still prefer Serviio. By a large margin. Love it, in fact. I think your smart tagging puts you waaay ahead of any other competing product. I'm just afraid that I'll need an additional server to make sure that all my files play okay, if you know what I mean.
Is there anything I can provide you with to help you debug this issue?
slyguy42o
Post Mon Jan 21, 2013 9:56 pm
run through this for two files, one that will play and one that wont.
viewtopic.php?f=5&t=1123
sounds like your profile may need to be tweaked for your device.
rajko
Post Tue Jan 22, 2013 3:09 am
Here it is and thanks a lot for your time.
From mediainfo: attached.
From ffmpeg:
>"c:\program files\serviio\lib\ffmpeg" -i "movie.avi"
le-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --pkg-config=pkg-config
[avi @ 003DD400] non-interleaved AVI
Input #0, avi, from 'movie.avi':
encoder : VirtualDubMod 1.5.10.1 (build 2366/release)
Duration: 01:41:33.46, start: 0.000000, bitrate: 965 kb/s
Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (DX50 / 0x30355844), yuv
420p, 636x346 [SAR 1:1 DAR 318:173], 23.98 tbr, 23.98 tbn, 23.98 tbc
Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16, 112 kb /s
movie.xml
(2.12 KiB) Downloaded 811 times
slyguy42o
Post Tue Jan 22, 2013 3:40 pm
Make a backup copy of profiles.xml
change this section under the samsung c/d/e profile
         <Video targetContainer="m2ts" targetACodec="ac3" targetVCodec="mpeg2video">
            <Matches container="flv" />
            <Matches container="ogg" />
            <Matches container="rm" />
to this
            <Matches container="avi" />
Restart serviio and try that to see if it makes a difference.
rajko
Post Wed Jan 23, 2013 5:11 am
Thanks. Just tried it, still the same thing. Though, my [original] profile.xml segment looked a tad different than what you posted. Here's what I found:
<Matches container="asf" vCodec="wmv2" />
<Matches container="mp4" vCodec="dvvideo" />
I don't know if that makes any difference.
Thanks!!
alfista
Post Wed Jan 23, 2013 12:00 pm
Try disabling transcoding (untick the checkbox in the Serviio console). My experience is that recent Samsung BDs accept pretty much any commonly available format and work better without transcoding.
rajko
Post Wed Jan 23, 2013 1:18 pm
You won't believe it - same problem!
Okay, let's forget it for now. If I run into more of these (3, so far), I'll contact you again. Don't wanna waste your time.
Thanks a lot.
