Playback stops
• Page 1 of 1
I have problems playing files, some files of 300MB each little time for reproduction and must carry, but others do not stop 4GB.
Re: Playback stops
would be helpful if you posted your logs...
also what are you viewing the video on?
does it show an error?
Re: Playback stops
I will explain:
wifi connection
* Watching an episode of a series about a resolution of 720x400 400mb 35min duration and, stops and "loading", after a while, just so ...
* Watching a movie of a 720p a duration of 1h: 35m and 4GB in size there is no problem
I thought it was the wifi problem, but I guess more information is relayed to the movie with chapter
wifi connection
Re: Playback stops
may depend on file type, for some types the device makes many requests and you need a quality connection for those (ie wired)
Petr
Help translate Serviio
Re: Playback stops
zip wrote:may depend on file type, for some types the device makes many requests and you need a quality connection for those (ie wired)
ok, but in this case the difference is very large and the small file with a lower resolution should go left because with larger and higher resolution does not pass
Re: Playback stops
i see the problem, the files of 1900 to 2000 kbps not working, very rare problem, more kbps than 2000 work, less than 1900 work.
• Page 1 of 1
Users browsing this forum: Baidu [Spider] and 8 guests
