Failed to retrieve feed item... It might not play
Post Sun Dec 18, 2011 2:12 pm
Re: Failed to retrieve feed item... It might not play
OK..thanks again..that makes the situation much clearer..and provides more info for a wiki... Since these rtmp rss feeds will be mostly user created its no problem using enclosure or using a generic groovy, like my LiveFeeds to change media:content into enclosure and add type.
mqojdn
Post Mon Jan 21, 2013 7:03 pm
There is actually a way to tell that an RSS item is live http://www.rssboard.org/media-rss.
<media:content expression="nonstop">
Btw., zip, what's the point transcoding non live items to file?
Post Thu Jan 24, 2013 11:42 am
1) because of protocols (e.g. rtmp)
2) because not all web servers support byte range requests
3) to save bandwidth in a case there are more clients watching the same file
mqojdn
Post Tue Jan 29, 2013 10:10 am
The same is true for RAM transcoding that you do for live streams, well, except for when multiple clients are watching the same non live file.
And no problems with running out of HDD space.
Previous
Users browsing this forum: No registered users and 316 guests
