PandaboardES Support
paniko
Post Tue Jan 22, 2013 2:47 pm
Hi Guys,
is possible to install serviio on pandaboard hardware?
Pandaboard ES is a dual core and it support Ubuntu 11.
some of you have already bought and did a bit of experience on this type of hardware "PandboardES"?
this is an example of what PandaBoard can do:
Pandaboard run Ubuntu 11.04 with LCD and Touch
http://www.youtube.com/watch?v=R9rsPAHnk-c
PandaboardES run Android 4.0,support 3G(WCDMA) and GPS
http://www.youtube.com/watch?v=5ziPkUZV ... e=youtu.be
Paniko
Sumsung EU46D6500 | XBox 360 | Samsung Galaxy S 6 Edge | Windows 10 - i7 64bit | Serviio 1.5.2 Pro
Beta Tester
paniko
Post Fri Jan 25, 2013 4:05 pm
Re: PandaboardES Support
anyone have any update?
Paniko
Beta Tester
NX3
Post Mon Jan 28, 2013 8:31 pm
Can you install Java on the Pandaboard ? That would semi answer your question
