[solved] Playlist m3u - no playback [serviio 1.1]
greg4b
Post Thu Jan 24, 2013 8:33 am
Thanks for the dlna server - especially that it features a playlist for images!
Unfortunatly this feature does not work - neither for the DLNA Client SONY KDL 755 nor in the Android MediaHouse.
The serviio 1.1 is running on a DS111 Synology DSM 4.1
Images and Music is being served from Servio without complaints - through folders etc.
Below a excerpt of the Log-File (a greater Log see Attachment)
2013-01-24 00:05:18,212 DEBUG [MediaItemDAOImpl] Getting file of media item 635
2013-01-24 00:05:18,213 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 635) and extractor EMBEDDED
2013-01-24 00:05:18,214 DEBUG [LibraryAdditionsCheckerThread] Found playlist file 'gregor.m3u', checking if it's already in the Library
2013-01-24 00:05:18,215 DEBUG [PlaylistDAOImpl] Checking if DB already contains playlist gregor.m3u
2013-01-24 00:05:18,217 DEBUG [MediaItemDAOImpl] Getting file of media item 636
2013-01-24 00:05:18,218 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 636) and extractor EMBEDDED
2013-01-24 00:05:18,221 DEBUG [MediaItemDAOImpl] Getting file of media item 637
2013-01-24 00:05:18,222 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 637) and extractor EMBEDDED
2013-01-24 00:05:18,225 DEBUG [PlaylistDAOImpl] Playlist gregor.m3u already exists in DB
2013-01-24 00:05:18,225 DEBUG [LibraryAdditionsCheckerThread] Found file 'DSC00048.JPG', checking if it's already in the Library
2013-01-24 00:05:18,225 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item DSC00048.JPG
2013-01-24 00:05:18,225 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /volume1/homes/serviio/../../photo/test/DSC00048.JPG, ignore case: false
2013-01-24 00:05:18,229 DEBUG [MediaItemDAOImpl] Media item DSC00048.JPG already exists in DB
2013-01-24 00:05:18,229 DEBUG [LibraryAdditionsCheckerThread] Found file 'DSC00047.JPG', checking if it's already in the Library
2013-01-24 00:05:18,229 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item DSC00047.JPG
2013-01-24 00:05:18,230 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /volume1/homes/serviio/../../photo/test/DSC00047.JPG, ignore case: false
2013-01-24 00:05:18,232 DEBUG [MediaItemDAOImpl] Media item DSC00047.JPG already exists in DB
2013-01-24 00:05:18,232 DEBUG [LibraryAdditionsCheckerThread] Found file 'DSC00045.JPG', checking if it's already in the Library
2013-01-24 00:05:18,232 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item DSC00045.JPG
The photo-playlist is simple - contains only 2 entries. I made those in an text editor - UTF-8 coded. The plalist is being played without problems in the windows media player
Any hints for getting the imageplaylist to work is greatly apreciated.
Thx,
Gregor
log file.txt
(22.17 KiB) Downloaded 506 times
Post Thu Jan 24, 2013 9:31 am
Re: Playlist m3u - no playback [serviio 1.1]
your image file names are different (.JPG vs .jpg) in the playlist and on the NAS.
greg4b
Post Fri Jan 25, 2013 9:06 am
SOLVED!
Thank's for the hint - I'm new to Linux and did'nt recognize this difference.
Let me note, that the "simple" form of m3u (image-)playlist didn't work out (just the Filenames as playlist).
It worked with the m3u-Linux formatting - see http://de.wikipedia.org/wiki/M3U#Unix_.28Mac_OS_X.2FLinux.29
My Setup:
Synology Diskstation DS 111+ / DSM 4.1
Sony KDL-40HX756
