Extract json from Zip archive
Post Thu Jan 24, 2013 4:59 pm
For pluzz plugin, I need to extract json information from archive :
http://webservices.francetelevisions.fr ... x_main.zip
How to extract them with groovy plugin ?
Post Thu Jan 24, 2013 6:44 pm
Re: Extract json from Zip archive
I have
org.serviio.util.ZipUtils.unZipSingleFile(InputStream stream)
But use on your own risk as it's not a shared method and might be renamed/moved in future
Otherwise you can do it manually like this
ZipInputStream zis = new ZipInputStream(is);
ZipEntry entry = zis.getNextEntry();
if( entry == null ) {
   throw new IOException("Invalid zip file");
// now read bytes from the InputStream zis
Post Fri Jan 25, 2013 2:43 pm
This will not be easy for me.
I am not a Java developer.
This is a new challenge.
Post Tue Jan 29, 2013 9:47 am
It has not been easy, but it works, I create my own method. Will be implemented in the next pluzz.groovy plugin
Return to Plugin development
