Video playback on Panasonic DMR-PWT520 Blu-ray player
simonmcg
Post Mon Dec 31, 2012 6:01 am
Hi. I have a Panasonic DMR-PWT520 Blu-ray player and a Windows XP installation of serviio.
It all seems to be set up properly except only music and pictures works on the device
When I try play video I get an error message 'Cannot play video'
Can anyone assist with this? I have tried the Panasonic Viera profile.
Thanks in advance.
slyguy42o
Post Tue Jan 08, 2013 7:02 pm
Re: Video playback on Panasonic DMR-PWT520 Blu-ray player
try the "Generic DLNA profile" and see if that works.
In some cases the profile provided doesn't cover all models and some tweaking may be required.
DT79
Post Sat Jan 12, 2013 10:58 am
slyguy42o wrote:try the "Generic DLNA profile" and see if that works.
Simonmcg - if you've had a chance to try this, then please provide an update, I'm thinking of buying one of these!
Cheers
satraver
Post Tue Jan 22, 2013 12:02 pm
I picked up one of these units recently and it is the only device on the network giving me grief.
I have transcoding on and did not have much luck with the panasonic profiles, but the sony bravia 2011 profile works best with mkvs and the aspect ratio looks ok. Unfortunately it does not play avi's.
Ive uploaded the sink info for this bd player to the wiki and below is the log error i see when trying to playack an avi.
2013-01-22 13:32:16,607 WARN [LibraryAdditionsCheckerThread] Cannot add file zx.tsukikage-ran.12.divx505.ogm because of an unexpected error. Message: String index out of range: -13
java.lang.StringIndexOutOfBoundsException: String index out of range: -13
at java.lang.String.substring(Unknown Source)
at org.serviio.library.metadata.FFmpegMetadataRetriever.getVideoFourCC(FFmpegMetadataRetriever.java:359)
at org.serviio.library.metadata.FFmpegMetadataRetriever.getParametersMap(FFmpegMetadataRetriever.java:185)
at org.serviio.library.metadata.FFmpegMetadataRetriever.updateMetadata(FFmpegMetadataRetriever.java:261)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:86)
at org.serviio.library.local.metadata.extractor.embedded.VideoExtractionStrategy.extractMetadata(VideoExtractionStrategy.java:49)
at org.serviio.library.local.metadata.extractor.embedded.EmbeddedMetadataExtractor.retrieveVideoMetadata(EmbeddedMetadataExtractor.java:216)
at org.serviio.library.local.metadata.extractor.embedded.EmbeddedMetadataExtractor.retrieveMetadata(EmbeddedMetadataExtractor.java:120)
at org.serviio.library.local.metadata.extractor.MetadataExtractor.extract(MetadataExtractor.java:46)
at org.serviio.library.local.LibraryManager.extractMetadata(LibraryManager.java:224)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.addNewMediaFile(LibraryAdditionsCheckerThread.java:178)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:145)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:134)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.run(LibraryAdditionsCheckerThread.java:83)
Post Tue Jan 22, 2013 2:28 pm
First, this is not your avi file and it's not a playback error, but library adding error
Secnd, could you post ffmpeg -i for this file? (zx.tsukikage-ran.12.divx505.ogm)
satraver
Post Tue Jan 22, 2013 9:28 pm
Thanks for clearing that up. I should have realised that when reading the log :)
Here is the ffmpeg info from the ogm fiile, thanks for taking the time to look at it.
C:\Program Files\Serviio\lib>ffmpeg.exe -i e:\anime\Kazemakasetr\zx.tsukikage-ra
n.12.divx505.ogm
g-config
Input #0, ogg, from 'e:\anime\Kazemakasetr\zx.tsukikage-ran.12.divx505.ogm':
Duration: 00:23:45.67, start: 0.000000, bitrate: 1347 kb/s
Chapter #0.0: start 0.000000, end 89.400000
title : Intro
Chapter #0.1: start 89.400000, end 758.000000
title : Part 1
Chapter #0.2: start 758.000000, end 1373.000000
title : Part 2
Chapter #0.3: start 1373.000000, end 1425.677000
title : Credits
Stream #0:0(Episode 12: I Was So Crucified, I Didn't Know What To Do): Video
: mpeg4 (DX50 / 0x30355844), yuv420p, 640x480, 23.98 fps, 23.98 tbr, 23.98 tbn,
23.98 tbc
TITLE : Tsukikage Ran - 12 - I Was So Crucified, I Didn't Know W
hat To Do
DESCRIPTION : Ripped by Danners
LANGUAGE : Episode 12: I Was So Crucified, I Didn't Know What To Do
ARTIST : Zhentarim DivX
COPYRIGHT : Zhentarim.cjb.net | #zhentarim @ irc.chatsociety.net
Stream #0:1(English): Audio: vorbis, 48000 Hz, stereo, s16, 112 kb/s
Stream #0:2(Japanese): Audio: vorbis, 48000 Hz, stereo, s16, 112 kb/s
Stream #0:3(English (Formatted)): Subtitle: text
Stream #0:4(English (Unformatted)): Subtitle: text
Post Thu Jan 24, 2013 3:10 pm
thanks, fixed adding this file for 1.2
Regarding the AVI, the 2011 profile transcodes them. Do they play with the 2011/2012 profile?
satraver
Post Thu Jan 24, 2013 9:42 pm
HI Zip
Here are the results from the panasonic BD player with the following profiles
Panasonic viera 2010
does not play avi
plays mkv
Panasonic viera e/s/st/vt/2011
plays avi
does not play mkv
Panasonic Viera G/GT/DT/UT/VT 2011
does not play avi
does not play mkv
Sony Bravia 2011
Does not play avi
MKV plays
Sony Bravia 2012
Does not play avi
MKV plays
Post Mon Jan 28, 2013 2:13 pm
Change this in the 2010 profile
to
        <Matches container="avi" />
and use that profile
Return to Panasonic
Users browsing this forum: Bing [Bot] and 5 guests
