[SOLVED] subtitle off the screen
aka399
Post Sat Jan 26, 2013 12:35 pm
I can't read subtitles (srt) on the Panasonic Viera TX-L32E5E, they are positioned off the screen at the bottom and are unreadable (I can see just the top of the letters). Can I modify the conf file to move up the text?
Tnx
Post Sat Jan 26, 2013 12:48 pm
Re: subtitle off the screen
Not on serviio.
Serviio only delivered the srt file in native format, this is the Pana device that does not display on the proper area.
So check on Pana device settings, and post on Panasonic support forum.
aka399
Post Sat Jan 26, 2013 1:13 pm
you're right, I found the solution on Pana settings. Thank you again.
thenamelessthing
Post Wed Feb 20, 2013 3:41 am
Re: [SOLVED] subtitle off the screen
What is the solution?
My Setup : BDT220 Panasonic Bluray player, TC-L55ET5 and TC-L42ET5 Panasonic TV. My home media server run Serviio 1.4.2 Pro under GNU/Linux Ubuntu 14.04 LTS server x64 and the hardware is Amd 1045t Phenom II X6, 6Gb DDR3 1333 mhz on SSD and data on soft raid 5 (3x1tb).
thenamelessthing
Post Fri Mar 01, 2013 6:16 pm
@zip I can test twonky and catch my network traffic with wireshark. Do you need another data to debug this?
Return to Panasonic
