Adding the ability to update a resource via http
It woul be great if I could update a resource in the library with an http put. Say, for example the naming convention on new content is wrong, it would be nice if I could update it via a third party tool once I've found the info. This would be in much the same way as your http gets, but we could have the content body containing the new data item for that unique resource. I'd suggest that you restrict updates to ITEMS only though... Thoughts?
