Problem with Serviio for Mac
ikk1987
Post Tue Jan 29, 2013 8:13 am
Hi
I installed Serviio 1.1 on Mac 10.7.5 yesterday and worked fine with a Samsung 6-Series for most of the day. However, it stopped updating the library later on and started showing an unexpected error 500. I tried to correct it but it did not work and eventually uninstalled it and installed it again. However, now the only message it shows is that the Serviio server is not running and cannot connect. I think it is something to do with files from the previous installation somewhere in the Library but I cannot find anything. I was unable to retrieve a log so far. It would be appreciated if someone game be some advice how to sort it out.
Thanks in advance
Post Tue Jan 29, 2013 8:52 am
Re: Problem with Serviio for Mac
ikk1987 wrote:... I think it is something to do with files from the previous installation somewhere in the Library but I cannot find anything. I was unable to retrieve a log so far. It would be appreciated if someone game be some advice how to sort it out...
You can try to delete the library folder (after a backup), then restart serviio services. Serviio will rebuild the library from scratch.
Users browsing this forum: Baidu [Spider] and 37 guests
