Subtitles
salsa
Post Sun Dec 23, 2012 3:22 am
Subtitles
Hi guys,
Im new here and I wanna know if have any way to load a video url like:
www.mywebsite.com/myvideo.mp4
and get the srt file
www.mywebsite.com/myvideo.srt
and load the video with subtitle?
Post Sun Dec 23, 2012 12:28 pm
Re: Subtitles
Plugins don't support subtitles yet, but will in the next version.
ottomatic
Post Mon Jan 28, 2013 10:18 pm
Re: Subtitles
zip wrote:Plugins don't support subtitles yet, but will in the next version.
Will this support be implemeted as a burn-in on the transcoded video stream, or as a DLNA container property which the client can elect to activate?
Post Mon Jan 28, 2013 11:54 pm
Re: Subtitles
It would be both. I currently haven't hooked subs into the plugin structure yet. I looked at 2 plugins and they both (youtube, iplayer) use a format that FFmpeg cannot decode, so i left it for now. I would either have to build some functionality to convert them to SRT or leave it up to the plugin devs.
What format do subs come in your plugin?
ottomatic
Post Tue Jan 29, 2013 9:13 am
Re: Subtitles
zip wrote:It would be both. I currently haven't hooked subs into the plugin structure yet. I looked at 2 plugins and they both (youtube, iplayer) use a format that FFmpeg cannot decode, so i left it for now. I would either have to build some functionality to convert them to SRT or leave it up to the plugin devs.
"Both" sounds great. I take it you mean that the plugin can decide (by using a flag?) if it wants the subs burned in?
Client toggling is obviously sweeter for the user, in case the DLNA client supports it.
My plugin, SvtPlay, (or rather the source service http://www.svtplay.se) uses WSRT, e.g.:
http://media.svt.se/download/mcc/wp3/un ... 79169.wsrt
The corresponding high quality stream url is:
http://svtplay7k-f.akamaihd.net/i/world ... e1bf661c32
Post Tue Jan 29, 2013 9:31 am
Re: Subtitles
ottomatic wrote:"Both" sounds great. I take it you mean that the plugin can decide (by using a flag?) if it wants the subs burned in?
No, it's up to the client to enable hardsubs (burn-in) in the console. It then can encode them either always or when required by the profile (another setting). If we do burn-in, the text softsubs resource is not served.
So it'll be totally transparent to the plugin.
mqojdn
Post Tue Jan 29, 2013 9:41 am
Re: Subtitles
Post Tue Jan 29, 2013 11:45 am
Re: Subtitles
I've thought about it before, but created the actual ticket now - https://bitbucket.org/xnejp03/serviio/i ... btitlesorg
ottomatic
Post Tue Jan 29, 2013 12:37 pm
Re: Subtitles
Even better.
Will this be in 1.2 or the following release?
Post Tue Jan 29, 2013 12:46 pm
Re: Subtitles
Currently out of scope for 1.2 (plugin subs), but will have a look if I have some time during the beta testing stage.
ottomatic
Post Wed Sep 25, 2013 7:32 am
Re: Subtitles
Hi, I'm curious about what happened with this?
I don't see anything about subtitle support in the latest plugin development guide.
Regards!
/ O
Post Wed Sep 25, 2013 8:31 am
Re: Subtitles
ottomatic
Post Wed Sep 25, 2013 9:32 am
Re: Subtitles
OK.
Any chance to bump the priority?
Anything I could do to help out?
/ O
Post Wed Sep 25, 2013 12:30 pm
Re: Subtitles
the problem is that most of the sites I was looking at were either using their own formats or something FFmpeg doesn't support, so the plugin devs would have to write some code to transform the sub files to .srt.
ottomatic
Post Wed Sep 25, 2013 3:27 pm
Re: Subtitles
zip wrote:the problem is that most of the sites I was looking at were either using their own formats or something FFmpeg doesn't support, so the plugin devs would have to write some code to transform the sub files to .srt.
OK, I understand.
Return to Plugin development
