Online stream works in 0.6.2 but not in 1.1
SysBeh
Post Tue Jan 29, 2013 11:07 am
Can anyone help me with the following issue:
I would like to use a view specific live streams with Serviio which I cannot get to work with the latest versions of Serviio.
The streams do work with online resources in Serviio 0.6.2, but not in version 1.01 and 1.1.
The links also work when tested in VLC.
Thanks in advance.
SysBeh
Post Tue Jan 29, 2013 12:04 pm
Re: Online stream works in 0.6.2 but not in 1.1
For testing. This is one of the streams.
mmsh://wms.pmedia09.kpnstreaming.nl/Twe ... Extern500k
Post Tue Jan 29, 2013 3:02 pm
If you are on Linux, install latest FFmpeg
Post Tue Jan 29, 2013 3:25 pm
zip wrote:If you are on Linux, install latest FFmpeg
http://wiki.serviio.org/doku.php?id=build_ffmpeg_linux
SysBeh
Post Tue Jan 29, 2013 3:39 pm
OK, on zip's post I tried experimenting with the FFMpeg versions as described in:
http://wiki.serviio.org/doku.php?id=win_ffmpeg
Serviio is running on Windows 7-64
The following results came out of that:
Serviio 0.6.2 and FFMpeg 4.4.2 --> Works like a charm (It's the way Serviio 0.6.2 was distributed)
Serviio 0.6.2 and FFMpeg 4.7.2 --> Online source does show up client side, but is not played
Serviio 1.1 and FFMpeg 4.4.2 --> Serviio does test it as a valid source, but is not played
Serviio 1.1 and FFMpeg 4.6.3 --> Serviio does test the source as invalid (It's the way Serviio 1.1 was distributed)
Serviio 1.1 and FFMpeg 4.7.2 --> Serviio does test it as a valid source, but is not played
Any suggestions?
Users browsing this forum: No registered users and 53 guests
