[SOLVED] Does Servio work with Mountain Lion?
brian532
Post Wed Jan 30, 2013 4:43 pm
I recently upgraded my Mac from 10.6.8 to 10.8.2 (Mountain Lion). Serviio still worked fine and streamed to my Samsung TV, but when I updated it to the new version, 1.1, I got a message when I opened it that Serviio was damaged and should be moved to the Trash. I recovered the old version from backup and that does still work. Does v 1.1 work for anybody with OS 10.8?
Post Wed Jan 30, 2013 5:30 pm
Re: Does Servio work with Mountain Lion?
It does work, but you need this work around first, or disable gatekeeper during the first launch if it still doesn't work http://www.serviio.org/component/conten ... ?id=21#q13
brian532
Post Wed Jan 30, 2013 11:25 pm
I have got it to work now, but with a very different approach, as your method produced the same 'damaged file' message. It seems there's a problem with how Archive Utility unpacks the zip.gz file. I tried using Stuffit Expander instead and then Serviio worked. Weird!
Return to User experiences
