Re: Subtitles on Sharp Aquos TV
built on Jun 18 2013 11:47:55 with gcc 4.0.1 (GCC) (Apple Inc. build 5493)
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-librtmp --enable-libfreetype --enable-fontconfig --enable-libass --enable-pthreads --enable-libx264 --enable-gpl --disable-mmx --extra-ldflags=-L/Users/MacAdmin/Desktop/build/target/lib --extra-cflags=-I/Users/MacAdmin/Desktop/build/target/include --extra-libs='-lpolarssl -lfreetype -lexpat -liconv'
Input #0, matroska,webm, from '/Volumes/Green/Shared Media/1. Anime/Kill la Kill/kill.mkv':
creation_time : 2013-10-03 18:38:16
Duration: 00:24:27.13, start: 0.000000, bitrate: 3195 kb/s
Stream #0:0: Video: h264 (High), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 23.81 fps, 23.81 tbr, 1k tbn, 47.95 tbc (default) (forced)
Stream #0:1: Audio: aac, 44100 Hz, stereo, fltp (default) (forced)
Stream #0:2: Subtitle: ssa (default) (forced)
Codec 0x18000 is not in the full list.
Stream #0:3: Attachment: unknown_codec
filename : OpenSans-Semibold.ttf
mimetype : application/x-truetype-fontzip wrote:The Win installation already includes the proper FFmpeg. Just enable burned-in subtitles in the console and follow instructions here: http://www.serviio.org/index.php?option ... icle&id=33
jaruzek wrote:Better?
- Code:
siuka wrote:- External subtitles solution (file.mkv + file_en.srt) (not the burned-in subtitle)
- Embedded subtitles (file.mkv that included several srts)
zip wrote:Try to put 'default' in the preferred language section in the console.
jaruzek wrote:zip wrote:Try to put 'default' in the preferred language section in the console.
I gave that a try and ensured that subtitles are always burned-in. Still didn't work
Users browsing this forum: No registered users and 88 guests
