Audio sync problem with 40EX500
pedros
Post Fri Jan 25, 2013 7:21 pm
hello
I use Serviio 1.1 vith a sony bravia 2010 connect with W7.
I have upgrade the firmware (PKG4.077EUL-0108)
When I launch à MKV file i have a problem of sync between audio and video.
The problem increase with the time.
thanks for your help
Post Fri Feb 01, 2013 8:17 am
Re: Audio sync problem with 40EX500
You can try to remux the mkv file with TsMuxer tool.
Phil.cdtpixel
Post Mon Feb 11, 2013 7:40 am
I got the same problem with my 46Ex500 (with a lot of mkv), I try to remux mkv to m2ts and ts but still the same audio problem (what settings must i use in tsmuxer ?)
But if i fastforward or stop and replay the movie, the problem seems to be solved.
Any idea ?
tested on 1920x1080 mkv/m2ts/ts
Post Mon Feb 11, 2013 8:39 am
Could you enable serviio detailed logging, try to play this mkv file? we will analysed the ffmpeg command line.
Phil.cdtpixel
Post Mon Feb 11, 2013 12:42 pm
Hi Illico,
I already look at the detailled logs and nothing wrong here. Perhaps it's due to my CPL link for the TV. All my lan is wire (cat 6) except for that TV, i will try on another TV (same model) with a good wire lan.
Stay tuned...
Phil.cdtpixel
Post Sat Mar 02, 2013 7:33 pm
Try on another renderers and everything is ok : playstation 3 - sony 32CX520
But on the two 46EX500 (one wired and the other with CPL) - the sound is desync after a while, and it's getting worst...
It seems to happend on every mkv i play on this TV : 1080p, 720p, and less resolution...
I don't know why... any idea ?
Users browsing this forum: Bing [Bot] and 5 guests
